| tyler_jrn |
 tyler_jrn Two Stroke Sniffer
 Posted: 18:07 - 30 Nov 2013 Post subject: ignition coil modifications? |
I'm changing my CDI and ignition coil on my bike as the CDI basically fell off and ground into my wheel and the ignition coil is cracked in places and i have noticed sparks coming from the cap on the spark plug to the engine, most likely the reason behind power drops ive been having.
Also my bike is a 125cc zontes bike, i know Chinese but all i had the choice to get or a 50cc moped. besides its never broken down.
My questions are the ignition coil with cable i have is about 450-500mm long, whereas the performance one im looking at is around 350mm long so will be a very tight fit, there are no ones longer than this.
Is there any way say to remove the cable from the ignition coil and replace with a longer one with a better NGK ignition cap on the end?
It has an ngk cap on the end atm so im guessing the cap can be changed but can the cable length be increased? So it will fit comfortably onto my bike.
i have a good week off soon so wanting to get carb set up, ignition all set up before my holidays run out.
if it cannot be increased im guessing ill have to get the stock one, and put a new NGK ignition cap on the end. How do i do this also, does it just pull off or has to be cut off etc?
if the ignition coil cable can be increased, any help on how to do this will also help. im mechanical not electrical, but i do know bits and bobs.
Thanks, any help appreciated .
Tyler.b |
| Kickstart |
 Kickstart The Oracle
| tyler_jrn |
| Kickstart |
| WD Forte |
 WD Forte World Chat Champion
| Vincent |
 Vincent Banned
| tyler_jrn |
The last post was made 12 years, 221 days ago. Instead of replying here, would creating a new thread be more useful? |
