| j.silvs |
 j.silvs World Chat Champion
| Musketeer |
 Musketeer World Chat Champion
 Posted: 13:58 - 01 Dec 2013 Post subject: |
There is no toolbox for 50 quid that will come with everything you need.
I bought 150 piece Halfords set, then more sockets, more wrenches, more of everything.. and I keep buying more  ____________________ Current Bike: Yamaha XSR900 Previous bikes: Honda CBR1000RR Fireblade, Kawasaki ZX-6R Ninja, Aprilia RS125 2-stroke |
| Skudd |
 Skudd Super Spammer
| j.silvs |
 Posted: 14:04 - 01 Dec 2013 Post subject: |
| Al |
 Al World Chat Champion
 Posted: 14:09 - 01 Dec 2013 Post subject: |
Your going to be looking at something around the draper/halfords price range but doubt you get a complete decent set of everything.
Maybe buy a socket set with the common metric sizes, a few useful screwdriver and a range of allen keys then just add any extra bits as you need them. ____________________ Yamaha FZR400RR 3tj
My Instagram Thingy |
| The Artist |
 The Artist Super Spammer
 Posted: 14:21 - 01 Dec 2013 Post subject: |
| Musketeer |
I personally would spend a bit more to get a decent set. Later you will have to live with what you've got
But saying that I haven't used some sockets from my set at all.. I probably used only about 75%.
But even with decent set you will find quickly that you may need some more tools... i.e. my 150 pc set come with 6mm and 8mm hex Allen socket, but in order to sort brake calipers in my Vauxhall Astra I needed to get 7mm one... Or standard 5mm hex Allen key socket was too short to use it with my torque wrench when playing with intake manifold bolts, so I got a long version
And that's how you eventually build your own perfect set of tools  ____________________ Current Bike: Yamaha XSR900 Previous bikes: Honda CBR1000RR Fireblade, Kawasaki ZX-6R Ninja, Aprilia RS125 2-stroke |
| clancy |
 clancy World Chat Champion
| Northern Monkey |
 Northern Monkey World Chat Champion
| Teflon-Mike |
 Posted: 15:39 - 01 Dec 2013 Post subject: |
With £50 the best place to start is the humble hand tool.
Forget socket sets; forget multi-bit screw-drivers; forget anything 'posh'.
NUMBER ONE most used tool in the box... the 10oz ball Hammer.
2/ TWO Decent sets of metric sized 'combination' (ring one end, jaw t'other) spanners. 8-17mm is most used range.
Why TWO sets? well when you are twizzling the nut on the end of something.... whats going to be holding the bolt head still?
Go machine-mart and get thier pro-grade life-time warranty type stuff, and so far you will have spent about half your budget.... which would have just about got you a cheap socket set that would laugh at anything particularly stubborn, and or be as likely to let you slip of fasteners and round them, and or chew heads up, and or skin knockles, and or... well list goes on....
THREE - screwdrivers. In fact, three, is probably about the right number... three cross head, three flat. Small, Medium and Large.
Chuck the rest of your budget at these, get as good as you can get, and IF possible, get Japanese Standard Cross heads... you'll probably struggle, but a propper phillips head is close enough... WARNING not all cross-heads are equal! And using the WRONG cross-head on motorbike screws is Second top reason for them getting chewed... first of course is ham-fisted mechanics not taking care to keep them straight in the screw and or using brute force over ignorance.
Last on the list, if you have any money left in your budget....
IMPACT DRIVER... its a heavy screw-driver type thing; usually with a socket head to take the sockets you don't yet have, or the usually supplied screw-driver bits. Handle is a chunk of metal, but the shaft is on a very mild spiral, so when you BASH the handle with... Number One tool, the 10oz ball hammer... it gives it a little tweek in the right direction, as well as bang the bit hard into the screw and apply a little shock to the shaft. BRILLIANT tool for the more stubborn and or chewed fastener. Saves a lot of cussing and swearing and skinned knuckles, and even Cheapo £5 jobbies can do a decent job.
Next on the list when you have some more money, is a box to put them in. Till then... well, any old recepticle will do...
I bought my first tools over thirty years ago; and it was SPANNERS, I still have most of them, and they are STILL the most used tools in the box.
People reach straight for the socket set, and SO many believe that sockets is the be-all and end all of tools, but SPANNERS, are wonderful devices.
Force is applied directly; you learn feel through them.
They are sized to the bolt-heads they fit, so that bigger fasteners get more leverage, littler ones less, so you dont struggle undoing big-uns and end up stripping your fancy ratchet smacking it with No1 Tool or hanging a six foot scaffold pole on the end; nor do you end up shearing small studs, wacking them up as tight as you can with the ratchet that has handle long enough to do up stuff three times the size!
You can SEE what you are working on in the jaw, and SEE when the spanners not straight to it, or if the bolt is spinning in the nut you're doing, etc.
You cant erroniousely switch the ratchet the wrong way mid undoeyuppey.... wonderful way to waste an afternoon... ratchet alternating between doing and undoing at half turn intervals!
NOR do you spend ages trying to work out which way is doey-upey, and which way undoey-upey, turning the wratchet round and getting it all inside out and back to front between putting socket on and getting it on the bolt!
Ratchet wont slip, or strip... you dont have a ratchet!
They are simple; and they do the job, without fuss and are HUGELY under-rated!
And GOOD ones are cheap, as in £10 a set cheap; and good ones are accurately sized and have the strength in the jaws not to bend open so they chew stubborn fasteners.
BEST place to start on limited budget. SIMPLE SPANNERS. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| WD Forte |
 WD Forte World Chat Champion
| yampug |
 yampug Nova Slayer
| Teflon-Mike |
 Posted: 15:55 - 01 Dec 2013 Post subject: |
Multim-Meters are a gawdsend... but on tight budget, even though you can get a very serviceable analogue one for under a fiver.... for most automotive electrics?
A spare bulb and a couple of bits or wire woks very well as a 'volt-meter'
No light = No Volts
Dim = less than 6v
Bright = Good 12v
For continuity? Add a two more bits of wire to take volts from car/bike battery, or battery charger... which would be the tool I put ahead of multi-meter in the priority list TBH... propper 4A charger, not a mA optimate type conditioning unit, but good battery charger.
High Tension Electrics? Yeah... thats what you have 'mates' for init? "Ere, Bob, can y' just hold this spark-=plug lead for me while I kick it over?"..... if they jump.... you got High Tension Well it worked in my day... got em nearly every time!
On your own? Spare-Spark-Plug and a jump lead. Clip metal bit of spare sparker in the jumpers crock-clip; other end on a good earth; then watch for a spark... much better than trying to lay the plug against the engine casing, or as so often, waved around in thin air, unearthed, "Oh I have no spark..." and lots of worrying over coils and electrics when in fact the carb was clogged! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| ninja_butler |
 ninja_butler World Chat Champion
 Posted: 16:09 - 01 Dec 2013 Post subject: |
Looks like a good deal - from 5 weeks ago! ____________________ a.k.a 'Geri'
| MC |
 MC Banned
| yampug |
 yampug Nova Slayer
 Posted: 16:41 - 01 Dec 2013 Post subject: |
| Pete. wrote: |
Looks like a good deal - from 5 weeks ago! |
never know might still be some in stores, still listed on website in the hurry while stocks last section. |
| WD Forte |
 Posted: 16:55 - 01 Dec 2013 Post subject: |
You can get one that's adequate for basic bike checks for three quid new. No sense paying more for something seldom used. Other than that a good used analogue meter can be had quite cheap. ____________________ a.k.a 'Geri'
| G |
 G The Voice of Reason
 Posted: 16:58 - 01 Dec 2013 Post subject: |
I'm glad I spent extra on on VC99 (fluke copy) - about £25, but the capacitor tester alone has saved me a whole load of hassle when compared to the cheap ones.
But yes, for the majority of bike stuff, the £3 are probably fine.
Hell, a battery and a spare 12v bulb are probably fine too . |
| iooi |
 iooi Super Spammer
 Posted: 17:57 - 01 Dec 2013 Post subject: |
I still use the 1/2" Draper set I got back in 1978. Think it cost me all of £5. Has all the metric and imperial size's needed.
Except of the + 20 m/m which you only need once in a blue moon.
Yes its been added to with a 3/8" drive set.
So get what you want and just add as you need. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Scythe |
 Scythe Crazy Courier
| crazymotorbik... |
 crazymotorbik... Nearly there...
 Posted: 18:11 - 01 Dec 2013 Post subject: |
Hey,
What i did was to buy a large tool box then bought quality tools for the jobs i came across. Slowly you build up all the tools you'll ever need and even some obscure tools you'll use once in a blue moon.
I now have a couple of fairly comprehensive and quality tool kits. One for electrical work and one for mechanical work.
Try to stay away from silverline, am-tek etc IMHO and experience these tools are nothing but use once and throw away items.
PS Xmas is on the horizon add a good set of spanners etc to your list
Cheers,
Shaun. |
| G |
The last post was made 12 years, 330 days ago. Instead of replying here, would creating a new thread be more useful? |
