Man truck buying advice
Fowlersrs
PostPosted: 16:31 - 01 Dec 2013    Post subject: Man truck buying advice Reply with quote
I've never owned a 4x4 but my recent job and my other halfs pending redundancy means we need to get something practical we can both use.
It will be predominantly my vehicle but the mrs may have to use it. We will be living in quite a rural location and want something practical but reliable. Something we can just throw stuff in the back of, be it shopping, the dogs, or even my work tools for the odd private job.
I've been looking at older discoverys or pick ups but not sure what's good tbh, never owned a 4x4. We have no need for serious off road, muddy tracks and lanes and of course the odd bit of snow so it doesn't have to be a mega machine..
There is another angle too this as well, I work for one of the largest LPG companies in the country and can get good discounts on fuel if I get a conversion as well so that's something else I'd consider doing..
Would prefer to avoid newer stuff as I'm told the fancy electronics can make repair costs heavy if they go wrong.
Anyone got any advice?
Hetzer
PostPosted: 17:17 - 01 Dec 2013    Post subject: Reply with quote
I had an old Shogun for a few years. It handled everything but cost a fortune to run (3.5lt gasoline engine).
billytwomirro...
PostPosted: 17:39 - 01 Dec 2013    Post subject: Reply with quote
Older 300tdi defender bullit proof engine.
Cunnington
PostPosted: 17:45 - 01 Dec 2013    Post subject: Reply with quote
My colleague had a Jeep Cherokee which was converted at this garage . They tend to have a lot of Jeeps but there are a couple of Vitaras at the moment. I'd find out who does conversions locally and see what they have, if LPG is important. That will give an indication of what can be converted - not all engines can.
My first 4x4 was a Discovery 300TDi (old L reg), which I got because it didn't have any ABS or fancy electronics to go wrong. It was a proper mechanical drive train with a centre diff lock, and you knew your were driving a vehicle with an agricultural pedigree. Mrs C drove it, but it was not her first choice.
I also had a Ford Kuga as a company car, which is part time 4WD, using a haldex clutch to manage the power distribution and the ABS as an electronic diff lock, which all happens seamlessly. It drove quite like a car and but was still pretty capable off road. I was very impressed with it and would consider another.
Single cab pickups can be a PITA if you want to carry something, unless you have a hard top / load cover, so consider a double cab if you go down this route. The majority are RWD, with little weight over the driven axle, so can be tail happy on wet roundabouts etc. Their size can make them difficult to fit in a supermarket car park.
From what you described, I'd have a look at the mid size options such as freelander, Rav 4, or a Vitara - they are fine for daily use, not quite as agricultural as a discovery, and less to go wrong than the modern electronically controlled stuff being produced.
'82 C50, '81 CB100, '84 GS125, '95 NTV650, '00 Bandit 600, '06 SV650, '56 Z1000, '89 NTV600
The Shaggy D.A. wrote: "You are invisible. Those who can see you are trying to kill you."
Fowlersrs
PostPosted: 17:50 - 01 Dec 2013    Post subject: Reply with quote
Cheers guys. It really is difficult, been looking at a Mitsubishi l200 locally with a hard top that already has LPG conversion, it's just been so long since I've had the hassle of having it own and repair a car I'm a bit lost as to what to buy tbh...
PostPosted: 18:32 - 01 Dec 2013    Post subject: Reply with quote
Why do you need a 4x4?
If you just want space, what's wrong with (for example) a Zafira with winter tyres on it?
Fowlersrs
PostPosted: 18:36 - 01 Dec 2013    Post subject: Reply with quote
If you just want space, what's wrong with (for example) a Zafira?
It's mainly the rural places we go with the dog, that and I just get the impression there tougher and will stand up to more abuse?
Maybe I need to consider capable cars too, if I'm honest I begrudge having to buy a 4 wheeled vehicle but needs must I guess.
Nb
PostPosted: 19:01 - 01 Dec 2013    Post subject: Reply with quote
L200's are a tad fragile, would avoid personally.
stickybackbob
PostPosted: 19:18 - 01 Dec 2013    Post subject: Reply with quote
Rob Fzs wrote:
Everyone says a 300tdi discovery 1 that's very clean is the best you can get before buying something with electrical woes etc..
Agree with the above. The only thing to check for on the discovery is rust....and they hide it well. Sills, rear wheel arches (inside and out), boot floor, front bulkhead and body mounts.
Pitted my old disco against a diesel L200 at harvest time pulling trailers loaded with hay bales. The disco hardly noticed but the L200 really struggled
Also, a word of warning on the petrol disco's....don't. Unreliable and expensive to fix especially if the engine doesn't have the top hat liners
Teflon will be along in a bit to tell you that the stuff about the petrol version is all wrong Smile
Cunnington
PostPosted: 19:27 - 01 Dec 2013    Post subject: Reply with quote
We have a fleet of Ford Rangers, used for accessing construction sites up in the remote mountainous areas of Scotchland. Very rarely do they need to engage 4 wheel drive, and it is unheard of for them to go into low ratio.
If it is ground clearance that you are thinking of, you get 2WD versions of many of the 4x4s on the market - fewer things to go wrong, and less weight to lug about so more miles to the gallon.
I was relieved to get my Kuga up to the top of a hill on the side of Loch Awe in the winter a few years back - the forestry road was a solid sheet of ice - to find an Astra van parked up.
MattEMulsion
PostPosted: 19:42 - 01 Dec 2013    Post subject: Reply with quote
I'd have said that an early Disco is rather old hat and not really that comfortable. I would look for something more modern.
Do you really need a big 4x4 though. Not only is it going to be more expensive to run, but if it goes wrong - it will be more expensive to repair and you could quite easily end up with some eye watering bills...
Yamaha YZF-R6
stevo as b4
PostPosted: 21:25 - 01 Dec 2013    Post subject: Reply with quote
I'd be making the decision of if I needed a proper 4x4 or just a 4wd estate car instead first of all. I'd fancy a classic Subaru Impreza estate, or maybe an AWD Volvo estate etc.
The only 4x4 I'd driven and kind of enjoyed was a mk1 Freelander TD4. I've driven the L-series engine one as well and it was just a bit noisier and slower but still ok, and actually can have a few less issues than the BMW M47 lump.
Just don't buy a 1.8K Freelander unless you want to spend ££££'s re-engineering the engine internals and cooling system to make it reasonably reliable. The KV6 one's seem to have few issues, but are horrendous on fuel!
Fowlersrs
PostPosted: 21:51 - 01 Dec 2013    Post subject: Reply with quote
Imprezza estates have taken my fancy, are they as costly to run as a proper imprezza? Are they good cars?
Nexus Icon
PostPosted: 22:20 - 01 Dec 2013    Post subject: Reply with quote
The Forester is cheaper to insure than the Impreza yet shares the same chassis and running gear. It has more ground clearance and slightly different power delivery as a smaller turbo means it is less laggy, less peaky and it loses a bit of the brute force of the Impreza. A post 2003 manual turbo XT model is still good for 0-60 in 6 secs however.
On a budget, the model before is the one to go for. Better fuel consumption traded off against slightly less performance and the same very capable 4wd system.
Choose one that's had the 60,000 mile/5 yr interval cambelt recently done, as that's a £500 job, run it on Kumho tyres (they last forever) and it will treat you well. The early S turbo model will still surprise a hot hatch from the lights and should set you back less than 2k nowadays.
Greetings from Shitsville!
BTTD
PostPosted: 22:59 - 01 Dec 2013    Post subject: Reply with quote
Estate cars tend to be able to carry about 300kg as a maximum payload, or at least that's what I seemed to find when I was researching motors a few years ago.
The smaller off roaders - Freelander, Kuga etc don't seem to offer any additional loadspace or payload than decent size estate cars.
I ended up getting a Jeep Cherokee 2.8CRD because it could carry more weight. I quite fancied a double cab pickup, but at the time didn't want to spend what it would have cost me to get a 4 year old 40k miler. The Jeep isn't that big - loads more space in a Discovery for example, but at the time I bought it, it was the best compromise for me.
Mate has got a petrol Shogun (Pajero in NZ where he is) as mentioned by Hetz. It came into it's own after the earthquakes out there and it keeps on going.
map
Mr Calendar
PostPosted: 23:50 - 01 Dec 2013    Post subject: Reply with quote
Depending on your budget I'd look at the Impreza Forester or the Volvo XC range, 60, 70 or if rich the 90. The Volvos tend to keep their value 2nd hand. The XC70 would be a good choice.
sickpup
Old Timer
PostPosted: 00:10 - 02 Dec 2013    Post subject: Reply with quote
You could always look at the rare Discovery Series 1 200Mpi. Built for the sub 2litre company car class they had enough power on road and once converted to LPG they become very cheap to run.
doggone
PostPosted: 08:34 - 02 Dec 2013    Post subject: Reply with quote
I wouldn't bother with 4x4 unless you need to tow, and we're in a wild part of North York Moors.
You want something with decent ground clearance and fit winter tyres.
The big pickups look good if you like that sort of thing but really no point unless you are farming, building, or towing 3 tons.
CaNsA
PostPosted: 08:55 - 02 Dec 2013    Post subject: Reply with quote
https://i.imgur.com/oMfXaOW.jpg
J4mes
PostPosted: 08:58 - 02 Dec 2013    Post subject: Reply with quote
300TDi Discovery - I paid £1K for one about 3 years ago with full tax and MOT, ran it for two years and all it cost me was £26 for a window regulator.
Parts are rediculously cheap and they are very easy to to work on.
Look out for rot on the boot floor, door pillars and the inner wings at the front.
Buy a poverty spec one with nothing electrical on it (mine had electric windows, that was it) and run it until it fails on rust.
Then sell it for a few hundred and buy another one.
I wanted a 300TDi defender, but for one of a similar age and condition they were fetching £5-6K, which is obscene. You're paying for the fact it's a defender, whereas 90% of the time the discovery will get you anywhere a defender will, and in more comfort too.
karoshi
PostPosted: 09:27 - 02 Dec 2013    Post subject: Reply with quote
The 3.5 - 3.9L v8 engines were much less problematic than the later 4.2 - 4.6L versions in the petrol discoverys.
If you've handy access to LPG at discount rates I'd look for an older 3.5L (1980s on carbs) range rover with single-point LPG, or possibly a slightly younger 3.9L (1990s on efi) one if you can find it with multipoint LPG injection.
Provided it's looked after and serviced the rover v8 is a lovely engine, and range rovers are lovely cars, Discoverys are basically the same car but with a much cheaper (uglier) body design but if you're wanting a disco the only thing I'd suggest is find one that doesn't have sunroofs, most Discoverys have two of them, and they both are guaranteed to leak, leads to rotten boot floors.
Well, I've wrestled with reality for 35 years, Doctor, and I'm happy to state I finally won out over it. - Elwood P. Dowd
map
Mr Calendar
PostPosted: 09:36 - 02 Dec 2013    Post subject: Reply with quote
J4mes wrote:
...ran it for two years and all it cost me was £26 for a window regulator....
So what's the road tax and insurance like on those? Or don't you know as you only got a window regulator?
Seriously, I have no idea if because of age road tax is the fixed maximum or what emission band/cost do they come in? Also I've no idea for insurance group. Are they a high theft/accident risk for example?
mudcow007
PostPosted: 11:34 - 02 Dec 2013    Post subject: Reply with quote
i bought a Suzuki SJ413 for the "lolz"
quite good off road an coudlnt kill it
https://i25.photobucket.com/albums/c81/mudcow007/29032008162-1.jpg
even when i burst the tank on a rock, it still got me home
https://i25.photobucket.com/albums/c81/mudcow007/Image048_zpsad72fc20.jpg
The last post was made 12 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.22 - MySQL Queries: 13 - Page Size: 133.43 Kb
