I'm not very good at downshifting :( - CBF 125
shaungeo
PostPosted: 18:10 - 01 Dec 2013    Post subject: I'm not very good at downshifting :( - CBF 125 Reply with quote
When I approach lights I down shift gear by gear like I was taught in the CBT(clutch in, throttle off, down shift and then release the clutch), the problem is everytime I downshift e.g. go from 3rd to 2nd gear (mostly at stop lights) and the light turns green again i give it some gas and the bike goes crazy. I also downshift at corners and when i give it some gas after downshifting the bike goes crazy.
Could you please advice me on what i'm doing wrong.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:22 - 01 Dec 2013    Post subject: Reply with quote
What do you mean by 'crazy' on the throttle?
I consider 'crazy' to mean the back wheel spinning and front end going light. I can't really square this sort of behaviour with the CGs lack of power...
Triumph Sprint ST 1050
shaungeo
PostPosted: 18:24 - 01 Dec 2013    Post subject: Reply with quote
Oh sorry, what I meant was the bike screams and pulls me back.
misscrabstick
PostPosted: 18:26 - 01 Dec 2013    Post subject: Reply with quote
You need gears to be appropriate to your speed and situation, if the bike is going "crazy" then I would think you have the wrong gear, stop trying to exactly do what they said on the CBT and try and develop some feel/empathy for your machine, try different gears, work out what feels right.
Nobby the Bastard
Harley Gaydar
What she said. You are changing down too soon.
misscrabstick
PostPosted: 18:27 - 01 Dec 2013    Post subject: Reply with quote
You are changing down the box one too many I would think.
yampug
PostPosted: 18:34 - 01 Dec 2013    Post subject: Reply with quote
doesn't sound like you matching engine speed to wheel speed before releasing the clutch.
just closing throttle kicking it down a gear and letting the clutch out will make the bike suddenly try to slow down with each down change, you want to try and match engine speed to wheel speed before releasing the clutch by increasing engine speed slightly matching the revs then releasing the clutch.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:36 - 01 Dec 2013    Post subject: Reply with quote
Or alternately, blip the throttle when the clutch is disengaged so that the engine speed is increased before you release the clutch.
yampug
PostPosted: 18:39 - 01 Dec 2013    Post subject: Reply with quote
sort of what i meant Thumbs Up
if you can match the engine speed and wheel speed it's a smoother ride than randomly blipping on each down change.
although i must admit when i've got my race can fitted you can't beat a blip and a down change and a few pops and bangs being fired out of the can. Thumbs Up
shaungeo
PostPosted: 18:54 - 01 Dec 2013    Post subject: Reply with quote
Ah alright thanks guys, I'll try and be more patient.
I guess it's only my 2nd day and i'll get it right eventually Smile
PostPosted: 19:30 - 01 Dec 2013    Post subject: Re: I'm not very good at downshifting :( - CBF 125 Reply with quote
https://media1.giphy.com/media/PIknZVpUYRGqQ/giphy.gif
I genuinely have no idea what you're on about. Can you try and describe exactly what the problem is, in terms of inputs and precisely what happens to the bike?
dydey90
PostPosted: 21:15 - 01 Dec 2013    Post subject: Reply with quote
When you downshift, the engine speed (on the rev counter) will go up. To do this, it has to get energy from somewhere to speed up. As you're not opening the throttle, it has no fuel to burn to achieve this and therefore uses the kinetic energy from the forward motion of the bike to speed up the engine, thus slowing down the bike as a whole.
By "going crazy" I assume you refer to the way it seems more responsive to the throttle. This is just down to how gear ratios work. Lower gears have higher acceleration and a lower top speed. Higher gears mean the bike struggles to accelerate but has a higher speed.
blurredman
PostPosted: 21:46 - 01 Dec 2013    Post subject: Reply with quote
Until you get this technique right, don't down shift on a corner either, you could end up flying off if you don't have the proper control. Do it before the corner. Providing we're talking about town type corners.
Nope.
PostPosted: 22:34 - 01 Dec 2013    Post subject: Reply with quote
Much as above, you're likely selecting a gear which is too low for your current road speed resulting in the engine trying to catch up. Don't change down so far.
PostPosted: 10:13 - 02 Dec 2013    Post subject: Reply with quote
That's the obvious answer, but he says that whatever is happening is happening when he opens the throttle, not when he lets the clutch out.
On an 11bhp 125, you'd have to knock it into 1st and twist it full on to discombobulate it. OP says that it's happening in 2nd, which seems fairly unlikely.
Is the chain tensioned correctly? Do the tyres have tread on them?
dreamevil
PostPosted: 14:16 - 02 Dec 2013    Post subject: Reply with quote
what about the posibility that hes been ridding around in a too high gear and when he lowers it he has more acceleration?
CBFcarl
PostPosted: 16:29 - 03 Dec 2013    Post subject: Reply with quote
I read this as when you release the clutch the engine revs up and the bike jerks forwards a bit? If so allow the bike to slow down a bit first, and maybe release the clutch a bit slower, I found the gear changes smoother when doing this.
PostPosted: 19:48 - 03 Dec 2013    Post subject: Reply with quote
Several folk are making that very reasonable assumption, but that's not what he actually wrote.
Is probably dead now. We barely knew ye. Crying or Very sad
The last post was made 12 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 99.27 Kb
