Sticky indicator switch?
teech
PostPosted: 21:16 - 01 Dec 2013    Post subject: Sticky indicator switch? Reply with quote
Hi all,
I have a problem which has been getting progressively worse. When I switch the left indicator on it takes several seconds to actually come on. It does this a little bit on the right too.
I'm guessing that the switch may be filthy and I need to get the switch cowling off and give it a clean. Thought I would post here first to see if any of you know whether that is really the issue or not? Can't say I relish the job as it's bound to be annoyingly fiddly...
Your wisdom would be greatly appreciated.
In everyday life good people do good things, bad people do bad things. It takes religion to make a good person do bad things.
RhynoCZ
PostPosted: 21:19 - 01 Dec 2013    Post subject: Reply with quote
Take it apart, use WD40 to clean all parts that should move, inside of the switch. Thumbs Up
teech
PostPosted: 21:22 - 01 Dec 2013    Post subject: Reply with quote
That's my thinking. Ta mate.
If anybody has anything else to add?
teech
PostPosted: 22:11 - 01 Dec 2013    Post subject: Reply with quote
Thanks mate, very helpful.
Just what I suspected, bit of a pain in the arse. Thanks for the advice.
Islander
PostPosted: 22:15 - 01 Dec 2013    Post subject: Reply with quote
Spray some decent switch cleaner (Servisol or similar) in through the slot and work the switch back and forth. Repeat this a few times - you may just get lucky and not have to dismantle anything. Thumbs Up
Walloper
PostPosted: 01:43 - 02 Dec 2013    Post subject: Reply with quote
Islander wrote:
Spray some decent switch cleaner (Servisol or similar) in through the slot and work the switch back and forth. Repeat this a few times - you may just get lucky and not have to dismantle anything. Then dump it to some random unsuspecting on e-bay/gumtree Thumbs Up
IFTFY Thumbs Up
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 8.34 - MySQL Queries: 13 - Page Size: 53.66 Kb
