Can someone help with college stuff?
Nemo
PostPosted: 22:48 - 01 Dec 2013    Post subject: Can someone help with college stuff? Reply with quote
So I'm on my next essay for college to go towards my level 3 diploma.
I've got to write about all of the components of a fuel injection system on a motorcycle of my choice, that being a TL1000R since I already have a damn good workshop manual for it.
All I would like the mass to help me with is the construction of a generic FI fuel hose, and how/if it differs from fuel hose used on carbed motorcycles, and also what the typical pressure value they can withstand (I know the system is pressurized at ~45-50psi ish), and also how they prevent vapour loss.
When I search im just finding companies blagging how their particular hose is mega awesome...
Pretty boring I know, but I have got 1500 more damn words to go.
Luckily I haven't got to reference so fire away.
Any help appreciated with thanks!
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
mic
PostPosted: 22:55 - 01 Dec 2013    Post subject: Reply with quote
Well here's my 2p worth
It won't have a manual choke
Hth
Edit.... actually it might have. Don't know.
Hth
zzr600
Nemo
PostPosted: 23:07 - 01 Dec 2013    Post subject: Reply with quote
Hth
Hth
Fast idle Wink
It's more the hose construction I need to know about, everything else is straight forward (at the moment).
Thanks though!
Jonathan A
PostPosted: 00:11 - 02 Dec 2013    Post subject: Reply with quote
This sounds like utter bollox. Glad I took Media Studies Wink
WD Forte
PostPosted: 00:13 - 02 Dec 2013    Post subject: Reply with quote
I'd guess its just pressure related
'normal' fuel hose has to handle virtually no pressure
FI hose has to withstand the system working pressure and the usual practise is to rate it well beyond expected
Its probably braided in the same way brake hoses are braided to prevent 'ballooning '
It may also have mechanical outer protection from chafing and heat
Materials:
early stuff may have been rubber but modern stuff uses synthetic
materials like Nitrile/Butyl/Silicon rubber all of which have slightly different characteristics
I'd try googling it and do some nifty plagiarism if I were you Smile
bikers smell of wee
PostPosted: 01:39 - 02 Dec 2013    Post subject: Re: Can someone help with college stuff? Reply with quote
It should have a part number on the side of it.
Whether you can find details without the hose in hand is another matter, as generally the bike companies don't want you to know you can get the same part for a tenth the price from a generic supplier Smile.
PostPosted: 12:36 - 02 Dec 2013    Post subject: Reply with quote
Presumably you'd want some sort of emergency cutout so it doesn't keep spraying loads of fuel all over your hot engine if you rupture a fuel line.
Used to happen with early car FI systems.
Northern Monkey
PostPosted: 16:36 - 02 Dec 2013    Post subject: Reply with quote
https://lmgtfy.com/?q=fuel+hose+manufacturing+process
https://www.hbdthermoid.com/images/automotive/Automotive%20Aftermarket%20Hose%20and%20Accessories%20(THB-198059_2012).pdf
Nemo
PostPosted: 16:52 - 02 Dec 2013    Post subject: Reply with quote
Northern Monkey wrote:
Thank you for being up yourself thinking you are awesome and everyone else are invalids.
It makes it so much sweeter to tell you it was no help since I don't need to know the manufacturing process, and none of the links told me anything I haven't already found through searches.
I was calling on people who may have the exprrience or knowledge of this, not someone who can do a google search of the wrong thing.
WD Forte
PostPosted: 19:31 - 02 Dec 2013    Post subject: Reply with quote
Whoa !!!!
Steady on there
Its only a couple of links not a personal attack
What if the guys just trying to help?
bikers smell of wee
PostPosted: 20:01 - 02 Dec 2013    Post subject: Reply with quote
WD Forte wrote:
Whoa !!!!
Steady on there
This may help you - https://lmgtfy.com/?q=what+is+lmgtfy Very Happy.
Northern Monkey
PostPosted: 20:18 - 02 Dec 2013    Post subject: Re: Can someone help with college stuff? Reply with quote
You said
And I sent you a link showing the construction of a generic FI fuel hose.
Its fucking exactly what you asked for.
WD Forte
PostPosted: 20:19 - 02 Dec 2013    Post subject: Reply with quote
Ahh I see
Thanks
LMGTFY wont load on my PC as I only load javascript on selected sites
I can see how it may have stung a wee bit
Ho hum, will back out and close the door quietly................
bikers smell of wee
PostPosted: 20:31 - 02 Dec 2013    Post subject: Reply with quote
Fuel injection hose normally has a spiral-wound aramid fibre reinforcement in the walls to cope with the extra pressure used to feed the injectors. Fuel hose for carburetors doesn't need any reinforcement as it's used at a few psi at most.
lihp
PostPosted: 20:35 - 02 Dec 2013    Post subject: Reply with quote
https://www.goodyearep.com/ProductsDetail.aspx?id=17700
Aff
PostPosted: 20:47 - 02 Dec 2013    Post subject: Reply with quote
You could have a read of SAE J30, it is the standard for oil and fuel hoses and lays out specifications and testing procedures.
I believe PTFE fuel hose is considered the dogs dangalies at the moment (probably better known by the brand name Teflon) purely for the fact that it doesn't really react with anything, so is virtually maintenance free. You can then also braid it to counteract deformation under pressure.
Fuel hose reacting with things is maybe a good point to talk about and will definitely use up some words.
Maybe go into the effects of the addition of Bio-Ethanol into fuel and the consequences on the materials used, and how specifications have had to change. Namely SAE J30R6 (the old standard) has had to be updated to SAE J30R9 which outlines the standards of fuel and oil hoses which must be able to hold a fuel with a 50% Ethanol content.
Here is a riveting read about the effects of ethanol on fuel hoses and carbs. Has some good graphs you can steal.
Electric Bike Project
Nemo
PostPosted: 20:53 - 02 Dec 2013    Post subject: Reply with quote
That's a good point! But I don't think there's any system other than "oh shit there's fuel everywhere!"
Cheers for the help guys!
lihp
PostPosted: 20:55 - 02 Dec 2013    Post subject: Reply with quote
Tip over switches on bikes do this, When the bike falls over the sensor shuts off the fuel pump and ignition.
Nemo
PostPosted: 21:15 - 02 Dec 2013    Post subject: Reply with quote
I was thinking the same, but he was talking more if the fuel pipe splits and fuel leaks everywhere rather than fall over.
SQL
PostPosted: 21:32 - 02 Dec 2013    Post subject: Reply with quote
Lack of fuel pressure/flow could be factored in#/
Nemo
PostPosted: 21:56 - 02 Dec 2013    Post subject: Reply with quote
Fuel pressure regulator can't tell though since its not electonic.
Bike wouldn't run too great though, if at all.
Nemo
PostPosted: 22:17 - 02 Dec 2013    Post subject: Reply with quote
This is epic, thank you!
The last post was made 12 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 117.34 Kb
