| dandelion |
 dandelion Nitrous Nuisance
| Benno |
 Benno World Chat Champion
| MC |
 MC Banned
 Posted: 17:19 - 02 Dec 2013 Post subject: |
More worried about front slides than rear tbh. Are you going over the white lines? They can be slippy, think someone on here crashed going over a painted arrow (although that was in the rain). ____________________ Yamaha MT-03 '08 (crashed)
Honda XR-125L '04 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 17:31 - 02 Dec 2013 Post subject: |
Could be diesel, could be that you're taking an unswept line and hitting accumulated crud.
I don't mind the roundabouts so much as the mongtards that tailgate right on your arse, not knowing or caring what the conditions are like, or that if you bin it they'll go right over your skull. ____________________ Biking is 1/20th as dangerous as horse riding.
| map |
 map Mr Calendar
 Posted: 17:35 - 02 Dec 2013 Post subject: |
Treat winter when near freezing as like riding in the wet.
That's wet as in absolutely pouring down. Increase distance to vehicle in front (that 4 secs gap sort of thing)
Ride in lower gear than you would normally.
Ride smoother. Don't snatch at the brakes. Use engine braking and match revs to speed on the ups and down shifts.
Use a little more rear brake than you would in the dry / summer.
Short shift, that is change up earlier than you would normally (as in when riding with pillion).
Look out for rainbow colours on the road and avoid or if not possible go over as upright as possible. Roundabouts are notorious for this, especially near petrol stations.
Keep as upright as possible around corners/roundabout. This might involve some planning on the entry. Keep a constant throttle. Only accelerate when you exit and can see corner's vanishing point going away from you.
If it's wet I ride in wheel track of car in front on the basis that they have cleared some water (thinking bit like when F1/racing cars create a dry line). However, for icy conditions this not good as weight of car compacts the frost/ice and can be more slippery. Others may disagree with this though so do what you feel comfortable with.
Also wrap up warm and get good warm gloves/muffs/heated grips/furry kittens/etc. Feeling cold can affect your concentration.
Not sure if all that helps or answers your query  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Matt B |
 Matt B World Chat Champion
| charrington96 |
 charrington96 Borekit Bruiser
| Dave70 |
 Dave70 World Chat Champion
| -Matt- |
 -Matt- World Chat Champion
 Posted: 14:08 - 03 Dec 2013 Post subject: |
The larger roundabouts with painted lines i find are particularly bad.
Roulette of diesel and leaves is far worse though as you often don't see it coming until you're on top of it  |
| iooi |
 iooi Super Spammer
 Posted: 14:13 - 03 Dec 2013 Post subject: |
Also watch out for the joins between the surfaces. Where it cannot be laid in one section.
One near me is so bad that its breaking up between them.
So stick to the middle of your lane and do not attempt to cut the corner. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| dandelion |
| Howling TerrorOutOfOffice |
 Posted: 18:09 - 03 Dec 2013 Post subject: |
What map said.
The following is something you can do when you've gained a little more confidence (experience).
On corners, roundabouts etc you can keep the bike more upright by having your bodyweight leaning to the inside of the corner. It doesn't have to be bum-cheek hanging off style, just a small shift in your whole body position before the turn. Dropping the inside shoulder will help, keeps the body straight.
For some when they first try this it will feel strange. Persevere, keep relaxed keep the throttle gently pulling....and if the back should move a little (it always feels a lot but rarely is) don't change a thing. Same body position same throttle. <<< That is a tough one to overcome..well it is for me, although the last year or so I have got better at doing nothing.  ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Slacker24seve... |
 Slacker24seve... World Chat Champion
 Posted: 20:34 - 03 Dec 2013 Post subject: |
If you see a car that looks even remotely French (the little white flags are a giveaway) assume they will NOT actually remember what country they are driving in, assume that they WILL look in completely the wrong direction and pull right out in front of you. ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
Banger rallies are ace |
| metalangel |
 metalangel World Chat Champion
 Posted: 03:25 - 04 Dec 2013 Post subject: |
I always rode through the winter (unless there was snow) and would leave for work when the stars were still twinkling above... so the road would likewise be twinkling with frost.
Take it as gently as possible... smooth, gentle everything. Watch for everything you're normally cautious of being slippery when it's wet.
Get some anti-fog spray for your visor, and keep your lights clean. ____________________ Previous: 2002 Honda CB500 (sold), 2007 Suzuki SV650SK6 (crashed), 2005 Yamaha FZ6 Fazer (sold). Currently bikeless
"A faired bike will get you 10x more clunge than a unfaired one." -Marlboro Matt |
The last post was made 12 years, 309 days ago. Instead of replying here, would creating a new thread be more useful? |
