Buying a Lockup/Garage
wodge
PostPosted: 19:19 - 03 Dec 2013    Post subject: Buying a Lockup/Garage Reply with quote
Does anyone have any tips on buying lockups or garages.. I'm finding myself short of storage for man stuff and Self store places don't seem a cheap long term option.
What should I be looking out for? Any pitfalls to avoid?
nolidge iz pouwur.
Yamaha RXS100 RS100
syl
PostPosted: 00:37 - 04 Dec 2013    Post subject: Reply with quote
As nearby as possible and with electricity. Preferably in a not too scummy area and well lit. It's probably best that when you look around most of them have their doors still attached.
Current bike: Kawasaki Z750S
Benno
PostPosted: 01:20 - 04 Dec 2013    Post subject: Reply with quote
Install a ground anchor inside if you're getting one away from your house, because they are not as safe as you think!
PostPosted: 06:34 - 05 Dec 2013    Post subject: Re: Buying a Lockup/Garage Reply with quote
In Reading I was renting a garage for £60pm for storage. It was a few miles away, but this was purely a secondary storage as had a decent sized garage already.
Similar would have likely cost at least £10k to buy - so a decent lot of time for 'pay off'.
They were right next to the bloke who was renting them's house - he got annoyed with the bit being used for whoring right next to his garden when they were pretty much abandoned.
Do you have a garden or similar you could stick a shed up in?
BTTD
PostPosted: 10:26 - 05 Dec 2013    Post subject: Reply with quote
I bought one last year, and it should be pretty straight forward.
The structures are about as basic as you can get - usually concrete blocks with either a tin or fibrous cement roof.
Problems I had with mine.
1. Roof had been patched but not all that well. I went over the patches with a fibreglass kit from ebay £20.
2. The door is pretty shagged. I could get a service kit and new runners, but I'm going to get a new sectional door with better security, sealing and insulation.
3. Wooden beam across the top of the garage door was rotten, and side of garage door posts. I've replaced the beam, and will do the posts when I do the door.
4. Guttering was leaking. New black plastic parts £16.
5. Garage floor was just about lower than the shared area in front, due to tarmac resurfacing over the years making the drive way a bit higher each time. They'd countered this by putting a concrete berm a couple inches high behind the garage door, probably fine but if the roof leaks water inside the garage it won't drain out. I have a cement mixer, so a couple of weekends and a few hundred £ on concrete means I now have a lovely new concrete floor with a DPC underneath.
Other things I've done.
Painted the inside white, fitted shelving and slatwall type stuff as inspired by this:
https://americanwoodworker.com/blogs/shop/archive/2009/08/04/hyper-organize-your-shop.aspx
dydey90
PostPosted: 10:58 - 05 Dec 2013    Post subject: Reply with quote
The ones I've seen always seem to have the same problem. Decent swinging garage door, nice thick, sturdy walls... Corrugated steel roof bolted to some sparse pine 2x4's.
If somebody wants to get in, they can do quite easily and add that to the fact that every garage door I've ever seen can be unlocked and opened from inside means that you don't technically own the contents as soon as you've left.
BTTD
PostPosted: 15:06 - 05 Dec 2013    Post subject: Reply with quote
Everyone that I've seen also has extra padlocks and / or a garage defender fitted.
I don't think that's technically correct. Wink
map
Mr Calendar
PostPosted: 15:27 - 05 Dec 2013    Post subject: Reply with quote
dydey90 wrote:
...add that to the fact that every garage door I've ever seen can be unlocked and opened from inside ....
Even ones with bolts and padlocks on the outside?
I ask as my father's garage was broken into by removing the roof panels (well, smashing them really). Lawnmower removed same way as couldn't be got around/over car parked in garage.
So bolts and locks now discretely on outside as well. I'm of the opinion that fitting a garage defender, while probably effective, is like advertising there's something in there worth having.
dydey90
PostPosted: 11:25 - 06 Dec 2013    Post subject: Reply with quote
I knew that was coming... Bolt cropper are very quiet tools for the work they do!
The last post was made 12 years, 349 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 62.49 Kb
