| WULFSTAN |
 WULFSTAN World Chat Champion
 Posted: 16:01 - 04 Dec 2013 Post subject: Kawasaki gt 550 cylinder head. |
How hard would it be to change the engine barrel ie this https://www.ebay.co.uk/itm/kawasaki-gt-550-barrels-/400567372187?pt=UK_Motorcycle_Parts_13&hash=item5d43ad099b and what would it involve. Would it be just as easy with a whole new engine thanks. ____________________ Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
| nowhere.elysium |
 nowhere.elysium The Pork Lord
 Posted: 16:13 - 04 Dec 2013 Post subject: |
It's a pain in the arse. Swapping the engine out completely would be faster and easier, but it's down to whether you like a challenge or not. You could always strip the original engine for parts afterwards, too.
However, in swapping an engine, you've got to take the seller at their word with regards to how well it runs, and the veracity of its history.
Is this the gt550 that's burning oil? I haven't read your previous thread anytime recently, but couldn't it just be knackered rings? That's gotta be a cheaper fix than a whole new set of barrels/replacement engine, surely? ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| cdzr |
 cdzr Derestricted Danger
| WULFSTAN |
 Posted: 16:29 - 04 Dec 2013 Post subject: |
| nowhere.elysium wrote: | It's a pain in the arse. Swapping the engine out completely would be faster and easier, but it's down to whether you like a challenge or not. You could always strip the original engine for parts afterwards, too.
Is this the gt550 that's burning oil? I haven't read your previous thread anytime recently, but couldn't it just be knackered rings? That's gotta be a cheaper fix than a whole new set of barrels/replacement engine, surely? | Wish it was just about it burning a bit of oil no. i took the exhaust off to put some new gaskets in as it was blowing and half the lug? is that the word? came out with the bolt. Ive been a few places see if i could get it welded but no. any ideas what else could be done thanks. ____________________ Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England |
| nowhere.elysium |
| WULFSTAN |
| cdzr |
| cdzr |
 Posted: 17:03 - 04 Dec 2013 Post subject: |
| WULFSTAN |
| 69chris |
 69chris Trackday Trickster
| WULFSTAN |
 Posted: 17:32 - 04 Dec 2013 Post subject: |
| 69chris wrote: | | WULFSTAN wrote: |
i took the exhaust off to put some new gaskets in as it was blowing and half the lug? is that the word? came out with the bolt. |
so is it the barrels or the cylinder head you need to change ??
whichever, im going to go against the grain here and say fix what you have,
swapping the top end is (imo) easier to do than change the entire engine, shouldnt take any longer to do either, esp as you wont have to be dealing with crusty engine bolts that will most prob be seized in and faffing about with the shaft gubbins,
go for it, it might even be fun  | Yes sorry its the cylinder head god knows what i thought. So what does changing the head involve. ____________________ Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England |
| nowhere.elysium |
 Posted: 17:42 - 04 Dec 2013 Post subject: |
| WULFSTAN wrote: | So what does changing the head involve. | Well, I'd personally advise against doing it in situ, so you'd be looking at dropping the engine, at the very least, which would constitute removing the tank, carbs, carb rubbers, driveshaft and engine mounts. From there, plugs out, cam cover off, cams out, don't drop the camchain, replace gasket, fit new barrels, reverse of the above.
I'd also think carefully about whether or not you have to replace the little things, like gaskets, vitron o-rings, the state of your piston rings and the like. If it's gone bad, it can get expensive. If it goes well, it can be laborious, but relatively painless. ____________________ '10 SV650SF, '83 GS650GT (it lives!), Questionable DIY dash project, 3D Printer project, Lasercutter project |
| WULFSTAN |
 Posted: 17:52 - 04 Dec 2013 Post subject: |
| nowhere.elysium wrote: | | WULFSTAN wrote: | So what does changing the head involve. | Well, I'd personally advise against doing it in situ, so you'd be looking at dropping the engine, at the very least, which would constitute removing the tank, carbs, carb rubbers, driveshaft and engine mounts. From there, plugs out, cam cover off, cams out, don't drop the camchain, replace gasket, fit new barrels, reverse of the above.
I'd also think carefully about whether or not you have to replace the little things, like gaskets, vitron o-rings, the state of your piston rings and the like. If it's gone bad, it can get expensive. If it goes well, it can be laborious, but relatively painless. | If i have to drop the engine then might as well just get a new engine in there i feel a lot more confident doing that. Now ive done a cbr 600 engine swap before how much harder is the gt to swap ie being shaft an all that? ____________________ Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England |
| nowhere.elysium |
| WULFSTAN |
| ZRX61 |
 ZRX61 Victor Meldrew
| WULFSTAN |
| cdzr |
| Ichy |
 Ichy World Chat Champion
| WULFSTAN |
| mentalboy |
 mentalboy World Chat Champion
| WULFSTAN |
| nowhere.elysium |
| WULFSTAN |
| davebike |
 davebike World Chat Champion
 Posted: 12:10 - 10 Dec 2013 Post subject: |
Send it back
The will be a pain to repair
Dave ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
The last post was made 12 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
