A little sprocket advise needed
askew
PostPosted: 15:50 - 22 Dec 2004    Post subject: A little sprocket advise needed Reply with quote
If I buy a sprocket for my bike that has the same pitch (428) and the new number of teeth fit the range allowed, would it matter that the sprocket was not specific to my bike?
Cheers! Smile
What's ya name? What av' ya taken? Chase the lasers, safe as f*ck!
Guest
PostPosted: 16:09 - 22 Dec 2004    Post subject: Reply with quote
As long as it fits to the wheel ok, is the right pitch and roughly the standard number of teeth, then no problems.
You'll find that a lot of Suzuki sprockets are inter-changable between models, same with most makes as they tend to use the same basic wheel castings. I don't know about swapping between brands though, you'd have to make sure it fits over the cast boss correctly and the bolt centres are the same.
askew
PostPosted: 16:13 - 22 Dec 2004    Post subject: Reply with quote
They're both Yamaha sprockets, and they're both from the same sized engine bikes. Do you think that the fixings will be in the same place?
I'm looking at getting less teeth than I have now (vain and silly attempt to improve speed. Smile)
Cheers by the way!
Ninja
Caption Abuser
PostPosted: 16:17 - 22 Dec 2004    Post subject: Reply with quote
(not vain or silly at all! It's the number one 'tuning' step - you can markedly affect your bike's performance by simply altering its gearing)
'course, to go faster you'd need to be able to 'pull' the extra gearing ...
James
4 wheels transport the Body ... 2 wheels transport the SOUL
TiN
Pocket Tin
PostPosted: 16:19 - 22 Dec 2004    Post subject: Reply with quote
Probably the best thing to do is to look at the part numbers for each bike...if they're the same, then they are clearly compatible, but just because they are from the same manufacturer and have the same size engine doesn't mean that they'll be the same.
TiN
dotgems.net
askew
PostPosted: 16:25 - 22 Dec 2004    Post subject: Reply with quote
Thanks guys you're all quite helpful. Just checked and the part number for my current sprocket is 13208+ and the new one is 13210+. I'm guessing they're not compatable. I was only planning on losing 3 teeth too.
Hmm... Continue the research Smithers. Smile
PostPosted: 17:16 - 22 Dec 2004    Post subject: Reply with quote
Which bikes do you want the sprocket from / to.
The old M&P catalogues listed the part numbers of sprockets as 6 digit numbers, the last 2 digits of which were the number of teeth. Think the first 4 digits referred to the fitting, so from that you can work out which other sprockets can be used.
Frost
PostPosted: 20:54 - 22 Dec 2004    Post subject: Reply with quote
Typically as keith said they have 2 indintifiers, fitting type and tooth count.
i put a sprocket off a different bike onto the old CB, fitted perfectly.
Be careful dropping teeth though, sometimes the chain may drag alot on the swingarm, or the chain will have worn to the old sprocket and will not work well with the new one
askew
PostPosted: 09:17 - 23 Dec 2004    Post subject: Reply with quote
My chain is almost brand new. It's one of the reasons why I thought this would be a good idea right now.
What exactly is the 'pitch' of a sprocket? If the two sprockets have the same pitch are they likely to fit?
Also, would reducing the teeth on the front sprocket have the same effect? I'm guessing that front is harder to fit than the back?
Thanks again guys. Smile
PostPosted: 10:20 - 23 Dec 2004    Post subject: Reply with quote
The pitch is the "428" or "520" bit.
There are other important considerations. For example the sprocket might not be flat so you have to consider the offset. There is also the number and pcd of the mounting bolts / stubs.
Often a maker will keep to a standard fitting for quite a while (Yamaha seem to be particularly good at having interchangeable parts).
Front sprockets are often cheaper. The other advantage is that if you add a couple of teeth at the back then the existing chain might not be long enough, but it you go down one at the front then you do not have this problem (although you might have to shorten the chain).
As mentioned above there is the possible problem that smaller sprockets will reduce the clearance from the chain to the swinging arm, etc, quite possibly resulting in it cutting into the swinging arm. Larger ones might not fit under the chain guard.
I would also say that you are best off replacing the chain and sprockets at the same time.
askew
PostPosted: 11:47 - 23 Dec 2004    Post subject: Reply with quote
Cheers Keith, that was a great help. I've been into contact with a few people and have had confirmed each time that the rear sprocket from an XT125/350 is exactly the same as what I'm looking for. I don't want to make too much of a difference to the top speed as I'd rather not reduce acceleration so much. So I think I'll knock 2 teeth from the back (50t - 48t) rather than adding one to the front and making a load of difference. Do you think a reduction of just 2 teeth to the rear will make a noticable difference?
Thanks again everyone! Thumbs Up
PostPosted: 12:36 - 23 Dec 2004    Post subject: Reply with quote
1 up at the front would be about the same as 3 down on the back, and for chain life a larger front sprocket is better.
At a guess you will probably gain around 2~3% top speed, if it will put that gearing (probably will).
askew
PostPosted: 13:16 - 23 Dec 2004    Post subject: Reply with quote
Ok, good stuff! Well, I'll get that ordered and I'll let you guys know how it all turns out. Smile
All the Best
Keith... whoops sorry, those words are too often read and imprinted in my mind hehe. Smile
The last post was made 21 years, 330 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 81.12 Kb
