zzr600 sticky rear brake light
mic
PostPosted: 12:13 - 12 Dec 2013    Post subject: zzr600 sticky rear brake light Reply with quote
Hellooooo
Seems when I use the foot brake that the brake light stays on. If i sort of push down on it a bit and side the foot off so the lever sort of springs back up, the light turns off. I've wd40d anything and everything around the foot pedal and it's not worked. Anything else I can try?
zzr600
DrSnoosnoo
PostPosted: 12:15 - 12 Dec 2013    Post subject: Reply with quote
There a spring which hangs down to your pedal which connects to the brake light switch, a black kind of cylinder shape. These can be adjusted by screwing in and out, effectively allowing you more room to press without the light coming on or the other way.
Take that out, give it a clean up and adjust so it's right.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:47 - 12 Dec 2013    Post subject: Reply with quote
Just replace the switch mechanism. They cost about £5...
Triumph Sprint ST 1050
The last post was made 12 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 35.1 Kb
