delay reving
blahheed
PostPosted: 19:37 - 12 Dec 2013    Post subject: delay reving Reply with quote
srad 600,
has problems when reving from tickover,
there seems to be a delay in the engine picking up/
similar prob when taking off from stand still,
throttle and choke cables all loose and fine.
any ideas i should be checking
Big
Fizzer Thou
PostPosted: 20:30 - 12 Dec 2013    Post subject: Reply with quote
Worn spark plugs
Dirty air filter
Dirty TPS track
Tight valve clearances
Unbalanced carbs
Leaking inlet manifold rubbers
Always have a 'Plan B'
Musketeer
PostPosted: 21:27 - 12 Dec 2013    Post subject: Reply with quote
I would check inlet manifold from engine to carbs for air leaks.
Did you remove the carbs recently?
jack_ellis
PostPosted: 22:21 - 12 Dec 2013    Post subject: Reply with quote
How's your fuel mix?
'78 Honda CB125J
Kawasaki W650
blahheed
PostPosted: 11:30 - 13 Dec 2013    Post subject: Reply with quote
am checking it today,
also anybody know engine numbers for srad models?
this one starts 715-******
Big
blahheed
PostPosted: 18:05 - 13 Dec 2013    Post subject: Reply with quote
carbs cleaned
pipes cleaned
airbox checked and secured,
seems to be better,
now to test it
thanks for tips
Big
The last post was made 12 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.04 Sec - Server Load: 0.11 - MySQL Queries: 13 - Page Size: 46.09 Kb
