KX125 CRANKSHAFT
ste.cameron25
PostPosted: 19:13 - 14 Dec 2013    Post subject: KX125 CRANKSHAFT Reply with quote
Does anyone know what other kx125 crankshafts fit a 1987 modle they all look the same to me but obviously ther not...
If you carnt make it then buy it..
Paddy Blake
PostPosted: 19:38 - 14 Dec 2013    Post subject: Re: KX125 CRANKSHAFT Reply with quote
I don't know but would you not be better off buying a new big end and Conrod and get them put into the crank.
ste.cameron25
PostPosted: 19:40 - 14 Dec 2013    Post subject: Reply with quote
Hmm could do that but this cranks seen it's days probs never been changed in its life plus ther a bearing stuck to the shaft
Nobby the Bastard
Harley Gaydar
PostPosted: 19:42 - 14 Dec 2013    Post subject: Reply with quote
You do know that rebuilding a crank isn't something you can do in a shed?
I'm pretty sure that if you take it to someone with the correct kit to rebuild it, they will be able to remove the stuck bearing. It probably just needs a bit of heat.
Oh, and you'll need new seals as well.
Triumph Sprint ST 1050
Paddy Blake
PostPosted: 19:47 - 14 Dec 2013    Post subject: Reply with quote
https://www.wemoto.com/bikes/kawasaki/kx_125_k4/97/picture/con_rod_kit/
A workshop would have the bearings off in seconds.
Paddy Blake
PostPosted: 19:56 - 14 Dec 2013    Post subject: Reply with quote
I don't see why not if you had the tools.
dangerousdave
PostPosted: 20:25 - 14 Dec 2013    Post subject: Reply with quote
Quite a bit of equipment needed to rebuild a crank
Splitting and joining is a specialist job, as the tolerances involved are tiny.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
bladerunner
PostPosted: 00:07 - 15 Dec 2013    Post subject: Reply with quote
Fly press,datum table,dti clock,V blocks and a copper hammer......job done Smile do you know any machine shop engineers?
andys675
PostPosted: 00:39 - 16 Dec 2013    Post subject: Reply with quote
first of all you have to make sure it is an 87 model by checking the frame and engine numbers with a dealer, a lot of people don't actually know what model they really have as they told by the previous owner who often bullshits prospective buyers to demand a higher price
however
rod kit from 1980 to 1987 are all the same, for mitaka £40.84 from here, plus main bearings at £20 the pair, fugging bargain
https://www.pjme.co.uk/acatalog/copy_of_Kawasaki_KX_100_Engine_Parts_Bottom_End.html
misscrabstick
PostPosted: 01:09 - 16 Dec 2013    Post subject: Reply with quote
When you split the crank to change the bearing journal and the con rod and bearings it is super important the two halves of the crank web are as perfectly aligned as possible when it goes back together, if they are not then your going to get vibrations, tight spots, and bearing failure.
Take your crank to a specialist and have it reconditioned properly.
bladerunner
PostPosted: 23:18 - 16 Dec 2013    Post subject: Reply with quote
As above^^^^ it's actually quite a simple job so long as you have the gear...getting the right big end side clearance is also important. Labour for the rebuild in a kitted workshop is not much...you want to use someone who does plenty of them and most shops that do MX bikes will take less than an hour to do the job
The last post was made 12 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 72.57 Kb
