Bearing shell stuck in wheel?
reed
PostPosted: 14:39 - 16 Dec 2013    Post subject: Bearing shell stuck in wheel? Reply with quote
Well I am in the process of removing the wheel bearings from my brothers 50cc bike, and I am stuck!
Any one have any ideas at all on how I can get the outer shell of a destroyed bearing out if the wheel? I can't get a decent grip on it with anything and it is very irritating. Evil or Very Mad
https://i41.tinypic.com/t97i2w.jpg
Generic XOR 50, Gilera SMT 50, GSXR 400 GK73A, Ducati Monster 600, Honda Hornet 600.
Sold. Stolen. Written off. Sold. Current.
Whosthedaddy
PostPosted: 14:40 - 16 Dec 2013    Post subject: Reply with quote
Oversized socket and a length of threaded road with some nuts on to tighten down and push out the bearing?
MarkJ
PostPosted: 14:41 - 16 Dec 2013    Post subject: Reply with quote
Bearing puller, or putting a bead of weld on the race face which might shrink it and let it drop out?
SQL
PostPosted: 14:49 - 16 Dec 2013    Post subject: Reply with quote
I tend to knock these out from the other side using longer drift.
pics?
Islander
PostPosted: 15:05 - 16 Dec 2013    Post subject: Reply with quote
pics?
This. You'll probably have to knock the spacer out of the way. Make sure that you drift it out evenly around the circumference of the shell to keep it square otherwise it'll jam. Thumbs Up
Mjolnir
PostPosted: 15:11 - 16 Dec 2013    Post subject: Reply with quote
I remember reading another thread about the same problem, albeit with a sprocket carrier bearing rather than a wheel bearing.
Pete had some great advice:
Pete. wrote:
That's an easy one. Re-build the bearing without the cage by putting all the balls in one side, offering up the centre part and then moving the balls around to distribute them evenly. Use grease to make them stick in place. You need to use a minimum of three balls but six or more would be better.
Now you can whack out the bearing using a drift on the inner race.
It still means getting in behind it and bashing it out with a drift though.
reed
PostPosted: 15:44 - 16 Dec 2013    Post subject: Reply with quote
The balls from the bearing are long gone, their wasn't a single one left when I took the wheel off and had a look, I've just taken it to my local garage, it shall be picked up in an hour and cost me less than £10 so problem solved. Smile
Ariel Badger
PostPosted: 00:45 - 17 Dec 2013    Post subject: Reply with quote
Run a bead of weld around it, it will cool and shrink the bearing and it will just drop out.
reed
PostPosted: 00:48 - 17 Dec 2013    Post subject: Reply with quote
I do not own a welder, as much as I'd enjoy welding stuff for funzies.
My local garage did it for £5 that I haven't actually paid for yet as he had no change. Laughing so technically at the moment it was free. Wink
The last post was made 12 years, 273 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.54 - MySQL Queries: 13 - Page Size: 61.21 Kb
