Checking oil level - does temp matter?
James83
PostPosted: 17:37 - 16 Dec 2013    Post subject: Checking oil level - does temp matter? Reply with quote
Sometimes I check my oil after a ride, sometimes before, I've not noticed a difference. The question is, is there a 'right' way to do it and why?
arry
PostPosted: 17:40 - 16 Dec 2013    Post subject: Reply with quote
Depends on manufacturer. Some specify 'cold', some 'hot' and some have marks for both hot and cold on the dipstick. Check your handbook.
James83
PostPosted: 17:48 - 16 Dec 2013    Post subject: Reply with quote
ok, cheers. Next question - anyone got a handbook for a zx6r f3 (1997)?
Az
PostPosted: 17:52 - 16 Dec 2013    Post subject: Reply with quote
Not sure if this would be relevant to your bike, but with my little honda it has to idle for 3-5minutes, then switched off and left to cool for 2-3minutes and then you check the dipstick (after you've wiped it and put it back in).
I believe too hot means the oils too runny to get an accurate reading on the dipstick and when it's cold its too thick for an accurate reading.
Matt B
PostPosted: 17:53 - 16 Dec 2013    Post subject: Reply with quote
https://www.mediafire.com/view/vy4bjmnddb64ae7/ZX600-F3.pdf
raesewell
PostPosted: 17:58 - 16 Dec 2013    Post subject: Reply with quote
You need to take a look at the handbook some you do it cold others it's hot.
I have to check mine when its hot however if you take a reading hot and let it go cold and it still shows on the dipstick you then have a cold reference point
Yamaha FJR 1300 Normanton West Yorkshire
arry
Page 118
Doesn't specify hot or cold, just that if the bike has been run then you should wait 'several minutes' for the oil to drain back into the sump
arry
PostPosted: 17:59 - 16 Dec 2013    Post subject: Reply with quote
The man works fast Laughing
James83
PostPosted: 18:03 - 16 Dec 2013    Post subject: Reply with quote
Thanks, but thats what prompted the thread. It says to wait a few minutes to let the oil drain down if the bike has been run, but doesn't give a recommendation as to warm or cold being better. I've had a hunt for a PDF of the owners manual because I expect it will say in there, but I can't find anything but the service manual.
As do you arry Razz
arry
PostPosted: 18:06 - 16 Dec 2013    Post subject: Reply with quote
I'd just continue doing what you're doing TBH, and not worry too much about it.
My triumph book says the Sprint should be run up to temp. In practice, I rarely do that before checking the oil - I check the oil cold and then, occasionally after a run, I'll check the oil when the bike's still a bit warm.
I don't suspect there's ever a lot of difference in the two TBH.
raesewell
PostPosted: 18:07 - 16 Dec 2013    Post subject: Reply with quote
If the manual says run it I think it's safe to assume it doesn't mean run it for 30 secs so take your readings hot after letting the oil drain back there will be a difference between hot and cold readings
arry
PostPosted: 18:09 - 16 Dec 2013    Post subject: Reply with quote
The manual says 'IF' the bike has been run, not specifically that it has to have been run.
raesewell
PostPosted: 18:38 - 16 Dec 2013    Post subject: Reply with quote
you can interpret it that way if you wish however I think you'll find it needs to be hot
arry
PostPosted: 18:42 - 16 Dec 2013    Post subject: Reply with quote
Well I think I won't find anything, because it doesn't specify.
Interpreting 'If the motorcycle has just been used' in any other way than 'if the motorcycle has just been used' seems rather difficult.
I've always been under the impression its the quantity in the sump. You want what they state when the bike is cold.
Otherwise you'll still have oil flowing around etc making its way down. I always do it cold and check that its pretty much at the full mark.
Skudd
PostPosted: 18:45 - 16 Dec 2013    Post subject: Reply with quote
I run my engine until it is warm, then turn it off and leave it for 5 minutes, then check the oil. It is how I have been told to do it by many mechanics over the last 30 years.
Matt B
PostPosted: 18:48 - 16 Dec 2013    Post subject: Reply with quote
I can't understand what the confusion is here?
Check the oil with the engine cold and the bike fully upright.
If the bike has been running (i.e. it's hot) give it a few minutes for the oil to drain back down into the sump.
The manual says nothing about running the engine before checking so don't.
Hugh Farking Cant
PostPosted: 20:52 - 16 Dec 2013    Post subject: Reply with quote
Depending on the lubrication system of the engine.
A wet sump motor with either a dipstick or sightglass in the crankcase itself should ideally be checked from cold.
A dry sump engine that has a seperate oil tank with dipstick or sightglass in the tank should be checked after a period of running so that the pump has a chance to scavange any oil from the sump back to the tank. The owner should know there is at least the minimum amount of oil in the engine before starting though.
It was not unknown for older models of dry sump motors to allow all the oil from the tank to drain down to the sump at rest.(Known as wet sumping)
Consequently if a new owner added half a gallon of oil to the now empty tank and then set off for a run; the tank was overfilled and usually deposited the excess oil over the rear of the bike.
Quite discerning for the rider but at least entertaining for onlookers.
haroman666
PostPosted: 21:05 - 16 Dec 2013    Post subject: Reply with quote
The oil level wont change enough between cold and hot to matter.
Just so long as you check it when the engine hasn't been running in the last 5 mins.
I tend to check mine pre-ride, because it's better to know that you have oil before you go out and seize the engine.
There is a gap of 1 year, 153 days between these two posts...
jinks
PostPosted: 15:24 - 19 May 2015    Post subject: Reply with quote
gsr750 oil sight glass turns white when stood when i ride it it clears up. i drained the oil and the oil looks clean no sign of the oil being white
iooi
PostPosted: 16:10 - 19 May 2015    Post subject: Reply with quote
Your doing too many short runs and getting water (condensation) in the oil. Take it for a good long run to burn the moisture out of the oil. Thumbs Up
Copycat73
PostPosted: 17:14 - 19 May 2015    Post subject: Reply with quote
check engine breather pipe for blockages... Thumbs Up
caveat emptor
The last post was made 11 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 112.96 Kb
