flywheel
daz|n00by
The Internet
PostPosted: 23:20 - 23 Dec 2004    Post subject: flywheel Reply with quote
anybody got any ideas how best to get the flywheel of on a rs 123 rotax engine without a flywheel puller i need to change the genny and i,m not paying £35 for a puller , none of the shops by me will let me hire one either, i,m thinking of going in my shed with the old welder and some bar and bits and knocking up somethingunless any bodt wants to lend me one and they live in the oldbury area
PostPosted: 01:17 - 24 Dec 2004    Post subject: Reply with quote
By flywheel I assume you are actually meaning the alternator as opposed to the wieghts on the crank.
Try screwing the rear wheel spindle in there, they often are the same thread and will gradually pull it off with the assistance of a deadblow hammer.
Or try this at £14.99:
https://www.mandp.co.uk/productInfo.aspx?catRef=530912
Which is this kind of thing (but not necessarily the same size):
https://www.hondaminitrail.com/gifs/magpuller.jpg
gsxrboy
PostPosted: 10:44 - 24 Dec 2004    Post subject: Reply with quote
There is a way of doing it if your very careful, get a small tyre lever or a big screwdriver behind the flywheel or at least as best wedged behind it as you can, apply quite a bit of pressure and give the crankshaft a good whack. I wouldnt recommend doing this a lot as it might damage the internals but it works enough to get you out of a spot of bother. Dont forget leave the nut on so you dont damage the threads.
Are there any threads in the face of the flywheel? some have a couple of around m10 m12 ideal for making a puller. simply bolt a steel bar bridging the crank and screw a bolt towards the crank, it'll pop right off no bother!!
PostPosted: 11:07 - 24 Dec 2004    Post subject: Reply with quote
Very surprised they are that expensive. Speak to Peter Knight on 0176 141 4106.
If this is a Rotax 123 engine (early engined RS125) then from memory the thread in the centre is a 26mm thread with a 1.5mm pitch. I could not find a suitable one except from Rotax (and I have half a dozen unsuitable ones at home).
I do have a puller and I am only up in Stafford. Not sure when I will be around in the next few days but I can certainly pop down to Oldbury with it, probably before the New Year.
I would advise against other ways of removing the flywheel. The teeth on the outside for the starter motor are not that rigidly in place, and if you damage the magnets on the inside of the flywheel then it is scrap. And they cost something like £125 new.
Why do you need to remove it? Changing the crankshaft main bearing seal or adjusting the ignition timing would be the main reasons (short of an engine rebuild). And for the second of these you need a dial gauge and adaptor as well.
daz|n00by
The Internet
PostPosted: 13:24 - 24 Dec 2004    Post subject: Reply with quote
i need to change the genarator keith i got a new one just not able to remove the flywheel m8 thanks for the offer of popping down m8 if u want to add me to your msn then maybe we can work something out m8 just add [email protected]
PostPosted: 13:30 - 24 Dec 2004    Post subject: Reply with quote
Afraid I don't use MSN.
If you are changing the generator then you need o set the ignition timing properly, and to do that you need a dial gauge.
daz|n00by
The Internet
PostPosted: 13:42 - 24 Dec 2004    Post subject: Reply with quote
ok so now u totaly lost me keith, i thought it was just a case of swaping them over and that was that
,btw keith i,ll send u a pm m8
PostPosted: 14:18 - 24 Dec 2004    Post subject: Reply with quote
Few pics to help out.
This is the stator:-
https://www.alfa-pages.co.uk/TempPicture/aprilia_stator.jpg
As you can see there are 3 mounting holes. The holes are sloted to allow you to adjust the ignition timing. Basically once in place you slightly slacken off the screws and turn it a tiny amount then retighten the mounting screws.
This is the flywheel:-
https://www.alfa-pages.co.uk/TempPicture/aprilia_flywheel_one.jpg
https://www.alfa-pages.co.uk/TempPicture/aprilia_flywheel_two.jpg
And this is what happens when the magnets come off Shocked .
https://www.alfa-pages.co.uk/TempPicture/aprilia_flywheel_three.jpg
This is a dial gauge with an adaptor for a spark plug so that you can check the piston postion to set the timing (1.84mm btdc).
https://www.alfa-pages.co.uk/TempPicture/dial_gauge.jpg
This is what the puller looks like:-
https://www.alfa-pages.co.uk/TempPicture/aprilia_flywheel_puller.jpg
Final bit of the ignition system, the coil:-
https://www.alfa-pages.co.uk/TempPicture/aprilia_coil.jpg
The last post was made 21 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 59.74 Kb
