Oh, for F***'s SAKE!!! (EDIT: sorted, thanks)
meyrick
PostPosted: 12:01 - 24 Dec 2004    Post subject: Oh, for F***'s SAKE!!! (EDIT: sorted, thanks) Reply with quote
The weather has really cleared up down here so, as I had my last 'lesson' with my dad yesterday, I decided to go for my first ride on my own.
Put on my suit of armour Wink , boots, flourescent tabbard thingy. Went out to the garage, pulled out the ramp, unlocked the bike and popped it off the center stand and.......oooooooh.....crunch. Dropped it....again!!!!
Back brake lever mangled, again! Front brake lever also buggered. No idea how I'm going to fix that, because it's attached to the hydraulics, which I know nothing about. What a way to spoil a nice, sunny day.
Just had to vent that so my nerves aren't so shattered while I'm pulling the poor dear to bits. Crying or Very sad
Paul Evil or Very Mad
instigator
PostPosted: 12:35 - 24 Dec 2004    Post subject: Reply with quote
Sorry to ehar about that mate, happens to everyone the same way as everyone leaves their disck lock on once. *cough* Embarassed
centre stand work.
See when you're pushing your bike off its centre stand, do it like this. One hand on the left handlebar(closest to you) and the other on the back of the bike, if there is a pillion grab rail, use that.
Then, put your right foot onto the centre stand foot bit which should be on the ground. Don't apply any weight to it yet. The, with both arms, push the bike forward(its forward, not yours) and as soon as you feel it moving forward, apply some of your weight to the centre stand. Once the bike is forward enough, you should be pushing down sufficiently on the stand so that you can basically let go of the bike and it can stay there, so that its not on its centre stand fully, but if you take any mass at all of the stand, it will fall. At this point you can pull the bike slightly to you when you are releasing weight from the stand. Do it very gradually of course.
Infact, if you want, put the side stand down and you can put it down on that.
The key is practise. I pratised with the company of my dad, he stayed on the other side of the bike and was there if I was going to drop it. And drop it I did (my 125) but no damdage was done because he caught it. Push the bike around yourself more, get used to its weight, its centre of gravity.
My bike mechanic can walk a bike backwards fairly quickly with just one hand on the closest handlebar. He can do it because of how much time he's spent getting used to bikes and their weight and the best way to handle them carefully.
If you wish, I can make a small video clip to show you how I do it.
Frost
PostPosted: 12:47 - 24 Dec 2004    Post subject: Reply with quote
From now on, stand astride it, push the bars forwards and grab the front brake once its off the stand, no way to drop it! Very Happy
Brake lever is np to fix.
I thought the rear brake levers were pretty strong on CB125's? Confused
meyrick
PostPosted: 12:59 - 24 Dec 2004    Post subject: Help, please :-) Reply with quote
Thanks for the tips, guys, I will definitely try those out. Up until now I have been holding both the handlebars and just throwing the bike forwards Shocked That's how I was taught in CBT Thinking
The back brake lever is sorted (I'm getting good at fixing that Smile Sad Shifty ) The front lever I need some help with. It's a front disc brake so it's a lever attached to one of those silver boxes, seemingly full of liquid for the hydraulics(?). Basically I want to know what will happen if I take it off. I have no idea. If I take it off will a) nothing happen, b) brake fluid start spraying out everywhere, c) something else?
Cheers,
Paul Smile
Laura
Playboy Bunny
PostPosted: 13:44 - 24 Dec 2004    Post subject: Reply with quote
You only need to take the lever of and get a new one not the hydraulics system :O
Good girls ride motorcycles bad girls thrash them.
meyrick
PostPosted: 13:57 - 24 Dec 2004    Post subject: Reply with quote
Yeah, I know. I just want to know what to expect when I take the lever off the hydraulic box thingy, as I've only ever taken the brake lever off a push bike, which has cables, not liquid Confused In other words, is the brake lever itself holding anything important in place, or can I just take it off with no worries?
Paul Smile
Hex
Party Boy
PostPosted: 14:28 - 24 Dec 2004    Post subject: Reply with quote
Just take it off with no worries.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
swampy
PostPosted: 15:41 - 24 Dec 2004    Post subject: Reply with quote
All the brake lever does is to acuate a piston in the master cylinder, which in turn pushes brake fluid into your caliper. This then moves the piston(s) in the caliper onto the brake pad (although the piston and pad are in constant contact they are not fixed together) and pushes the pad onto the disc causing friction which should then slow you down (hopefully Smile ). So in answer to your question the brake lever doesn't come into contact with any brake fluid, and you're ok to remove it at your leisure without buggering anything up Very Happy Thumbs Up
meyrick
PostPosted: 17:47 - 24 Dec 2004    Post subject: Reply with quote
Cheers guys, I just went and did that. I was surprised how simple it was, really. Only problem was that when I tried to straighten out the lever it snapped in two Shocked Don't know my own stength Very Happy Sad
I filed the end and polished it and it now looks like it's supposed to be like that. It looks quite good actually, just the clutch lever still has a blob on the end sort of gives it away. I can't really bring myself to chop off the end of my clutch lever so they are matching though Laughing
Paul Smile
ts50x0
PostPosted: 19:40 - 24 Dec 2004    Post subject: Reply with quote
dont worry about how it looks mate, dont buy a new lever untill your sure u aint gonna drop it again
meyrick
PostPosted: 19:45 - 24 Dec 2004    Post subject: Reply with quote
No, my thoughts exactly. Laughing
DanceLikeAMon...
PostPosted: 20:37 - 24 Dec 2004    Post subject: Reply with quote
Sorry to hear about the drop mate. Third time lucky! Thumbs Up
On a similar note. Anyone got tips for putting the bike onto it's centre stand? Whenever I do it I feel like I am wrenching my spine out of place so I must be doing someting wrong! I have a SR125 if that makes a difference.
instigator
PostPosted: 22:27 - 24 Dec 2004    Post subject: Reply with quote
dancemonkey - just as I've said really, but reverse the order.
Put one hand on the closest handlebar to you, and the other on the grabrail/end of the bike.
With your right foot, push the centre stand down so that its pushing against the ground. If you're putting enough weight onto it, then you can let go of the bike with your hands and it'll stay vertical.
The, with your hands in the aforementioned position, put more weight onto the centre stand and try and pull up and to the left. That should be enough to get it up okay.
When I had a 125, and I was getting used to it, I found that rolling the bike backwards slightly made it easier as you're building up momentum to make it easier to mount onto the centre stand. With practise, you can do it without rolling the bike back at all. When going from a 500(mine) to a 125 and putting it on the stand, I find I do it far too quickly and I apply too much force to pull back.
If you can perfect the technique on a 125, then it'l help hugely with bigger bikes.
DanceLikeAMon...
PostPosted: 22:28 - 24 Dec 2004    Post subject: Reply with quote
Cheers matey, I shall practise that tomorrow (when I'm a bit more soberer (is that a word?) Very Happy
dodsi
Dirty Carny
PostPosted: 03:53 - 25 Dec 2004    Post subject: Reply with quote
center stand on that thing! light as a feather!
I used to pick that bike up and move it! cant do that nowerdays
Missing the SR's fuel ecomomy and lightness and ease of use in town!
I have to be all responsible with the throttle now Sad
with the SR just put your foot on the lever and stand up on the lever and it flies onto the stand!
Frost
PostPosted: 04:12 - 25 Dec 2004    Post subject: Reply with quote
It may seem hard to put the bike on its center stand now, but after doing it for a few ceeks you can do it without any effort at all.
On the CBT you are taught to push it off the stand stood by the side of it. The only time's i ever dropped my CB was doing it that way. If the thing lurches to one side you're fucked, all your strength will just pull the grip off the bar.
Sitting on it and bumping it forwards means you have a foot down on either side at any time, you don't really need the front brake, but i allways coverd it out of habbit anyway.
mchaggis
PostPosted: 04:39 - 25 Dec 2004    Post subject: Reply with quote
The way we were taught on CBT to take it off the centre stand is the only cause of my static drops other than moving 130kg by brute force rather than with wheels. Shifty Why they teach it like that is anybody's guess... Question
Similarly with taking the side stand off. I just get on and worry about the side stand when I'm about to pull off. For a bigger bike, having the side stand down when getting on is a huge help. It's also useful if you're wheeling a heavy unfamiliar bike about, as you don't have to worry about letting it go on the left hand side.
I must not be a troll...
Mmmm, Guinness
Frost
PostPosted: 05:33 - 25 Dec 2004    Post subject: Reply with quote
Why they teach it the wayt hey do i don't know.
Getting someone who has never been on a bike before to do it isnt exactly a gentle confidence building start is it? especially if they drop the thing, i should imagine doing that has reduced the condidence of a fair few people to zero before they have even got on the damn thing! Razz
meyrick
PostPosted: 14:01 - 25 Dec 2004    Post subject: Reply with quote
Yup, I had to do it that way with a CG125 for my CBT and I dropped it. The instructor caught it and had a giggle. Not much of a confidence boost, you're right. Confused
Paul Smile
EDIT - Hey DLAM. If you are still having trouble getting your bike onto the centre stand, try this tip from the world of weight lifting. Use the method described above by instigator, but rather than looking down at the bike (as I suspect you are) try looking straight ahead when you do the lifting. When you look down you will likely be looming over the bike and a proportion of your body weight will go towards forcing the bike downwards. When you look straight ahead, you will reflexively stand up straighter and your spine will arch correctly for lifiting, both increasing your strength. You will also avoid the looming effect that works against you. However, as you won't be looking at what you are doing I suggest you have someone there to catch the bike the first time you try this. HTH Smile
JonB
Afraid of Mileage
PostPosted: 15:50 - 25 Dec 2004    Post subject: Reply with quote
Even on my ped I found it hard to push it off the centre stand the way they taught me at the CBT at first. Now all I do is sit on it and rock it forward. Smile
pipnet11
PostPosted: 00:51 - 26 Dec 2004    Post subject: Reply with quote
When your putting it on the stand theres usually a rail to grab onto. Looks like a pillion grab-rail but further forward, this helps a lot. Im quite sure theres one on the CG, there was one on all GSs.
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
Frost
PostPosted: 01:19 - 26 Dec 2004    Post subject: Reply with quote
Most CG's have a granny rack on the back. pull up and slightly back on this, and push down hard with your right foot. the left hand ont he bars is purely for stability
The last post was made 21 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 117.15 Kb
