A2 KLE500 grinding noise between 4500-5500 revs
jimbob92
PostPosted: 19:59 - 20 Dec 2013    Post subject: A2 KLE500 grinding noise between 4500-5500 revs Reply with quote
Hi,
Just a quick one really, had an A2 kle500 for about 6 months now, about 45,000 on the clock but been well maintained and has been running smoothly. BUT the past couple of times I've taken it out it's been making a strange grinding noise between 4500-5500 revs. It doesn't effect the acceleration or performance in any way and only happens when the bike's in gear. It's bloody irritating and it's got my dad baffled who's owned and worked on bikes for 35 years. Any ideas or advice greatly appreciated.
Cheers.
tomh
PostPosted: 08:38 - 21 Dec 2013    Post subject: Reply with quote
It's sounds like something is loose on the bike, going over most major bolts checking they are fully torqued out will help.
A loose swing arm pivot bolt caused a horrible grinding noise for me at higher rpm that I was convinced was coming from the engine.
PostPosted: 09:11 - 21 Dec 2013    Post subject: Reply with quote
So always at the same rev speed?
In every gear?
Never when in neutral?
What about if it's in gear with the clutch pulled in?
jimbob92
PostPosted: 17:57 - 22 Dec 2013    Post subject: Reply with quote
It does it in neutral as well I've found, but i think I've found the problem, the header pipe is cracked right round underneath and seems to be blowing out at them revs, hopefully once I've sorted that it'll be gone.
Benjamin_Breeg
PostPosted: 15:51 - 07 Jan 2014    Post subject: Reply with quote
Did you sort this out?
Just my GPZ500 has developed a similar sounding noise at about 6500 rpm.
It happens in all gears, as well as with the clutch pulled in, but also happens in neutral.
I think I've tightened all major blots, but to no success.
Cheers.
jimbob92
PostPosted: 17:33 - 09 Jan 2014    Post subject: Reply with quote
The cracked header pipe was the problem, got it welded up and the noises stopped! thanks for suggestions everyone Smile
The last post was made 12 years, 312 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.19 - MySQL Queries: 13 - Page Size: 45.71 Kb
