| Baffler186 |
 Baffler186 World Chat Champion
| P.addy |
 P.addy Red Rocket
| Baffler186 |
| J.M. |
 J.M. World Chat Champion
| Baffler186 |
 Posted: 22:37 - 21 Dec 2013 Post subject: |
| J.M. wrote: | | Baffler186 wrote: | It was raining, and there was shit loads of surface water on some A-roads before I got to dual carriageway, but it only started after maybe 10 minutes at 70. After it died I managed to re-start it, and it revved in neutral just like it should, but under load it started dying again, not cutting out but only revving up to 4 or 5k, then getting worse and worse until it would only pull in 2nd gear with throttle open. |
Water can play havoc with the electrical system on a bike.
My GS500 used to drop a Cylinder in the wet, which caused symptoms exactly the same as yours. It wouldn't happen immediately, but rather gradually get worse. However with mine I had to keep the revs high or it would stall (but it did only have two cylinders).
A poor video of mine: https://www.youtube.com/watch?v=46tHWF-pic8 |
oh. It felt like it dropped more than 1 cylinder, but how would I know having only ever had a single. How did you sort it out? I don't really like the idea of not riding in the wet, as this is my only vehicle now! |
| J.M. |
| ZebraDriver |
 ZebraDriver Scooby Slapper
| Baffler186 |
| P.addy |
 P.addy Red Rocket
| Baffler186 |
| _Iain_ |
 _Iain_ Banned
 Posted: 03:59 - 22 Dec 2013 Post subject: |
Fire it up and keep touching the headers one by one to judge temp.
Bandits are very obvious to spot & the cold one isn't firing. Probbably a coil issue - I may have a few in a box somewhere. ____________________ Please be aware that the above post may be full of complete nonsense.
| J.M. |
| davebike |
 davebike World Chat Champion
 Posted: 19:46 - 22 Dec 2013 Post subject: |
For a bet Bought privet from Ebay Put a set Good plugs and a clean air filter and it will run fine Do an oil change as I don't expect that been done in awhile !!
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Baffler186 |
| Baffler186 |
 Posted: 20:34 - 22 Dec 2013 Post subject: |
Thanks all for taking the time to post. Taking it to garage now, want it done properly  |
| Nemo |
 Nemo Could Be A Chat Bot
 Posted: 23:19 - 22 Dec 2013 Post subject: |
Im gonna place bets on the carbs need cleaning out and setting up, sounds like the main jets are gummed up.
Carbs are a peice of cake to remove and clean out, but you'll need vacuum guages to sort the balancing, and a good ear to do the mixtures, so unless you're 100% cinfident, don't touch them.
Had the bike been sat for a while before you bought it? Petrol can go bad and gum up in as little as 1 - 2 weeks of not moving. ____________________ Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo |
| Baffler186 |
| haroman666 |
 haroman666 World Chat Champion
| yampug |
 yampug Nova Slayer
| Baffler186 |
 Posted: 12:52 - 13 Jan 2014 Post subject: |
Bit of an update: The garage balanced the carbs and said it was running fine (though they only took it for a 5 minute ride to test it). Took it out on Saturday and it was fine for 30 miles. Then after having been at 70/80 for 20 minutes it started to die again, then stalled at the end of a slip-road. I got it started again and got it home keeping in low gear at high revs.
I was convinced it was carb icing, as it had only up to now happened in the damp/cold and when doing prolonged rides with the throttle in the same place.
However, this morning I had only just warmed it up and it did the same thing after only doing 2 miles at 30mph. Also it wasn't wet (bike had been in dry garage with dehumidifier going all night, and it wasn't raining outside), so I think I can eliminate all of the problems caused by water.
So, here's what it has had done:
Carbs balanced
Electrics checked
New spark plugs
oil change + new oil filter
new air filter
New battery
I'm going to check all the wiring at the weekend, and the carbs, and the fuel breather pipe. Hopefully something obvious will need doing, but other than that if I can't get to the bottom of it will have to go back to the garage. Will also put some fuel system cleaner in, run it, and then check carbs.
If any of the above is not a sensible approach please shout! |
| haroman666 |
 Posted: 13:02 - 13 Jan 2014 Post subject: |
For carb icing, stick nearly a cap of THIS in each tank of fuel.
I have a bottle somewhere but fuck knows where.
Also check your plug leads... May be degrading or cracked. You can get 2 meters worth on ebay for a couple of quid and you can cut it to length and screw into your plug caps and coils to replace what you have there. ____________________ The mistresses: 2000 Honda CBR600f, 2000 Honda VTR1000 |
| P.addy |
 P.addy Red Rocket
| Baffler186 |
| chris-red |
| Baffler186 |
The last post was made 12 years, 282 days ago. Instead of replying here, would creating a new thread be more useful? |
