| Ribenapigeon |
 Ribenapigeon Super Spammer
| stinkwheel |
 Posted: 12:52 - 23 Dec 2013 Post subject: |
The way I always heard it is it is more expensive to produce, has more wearable componants, a higher unsprung weight and is trickier to adjust.
It is better if done well but it is difficult to do well cheaply. Add in a degree of "We've always done it like that." and you get forks and yokes.
Most bikes still use chain drive for broadly similar reasons (ie. cost to produce and fear of change).
You could say the same for telescopic forks. Well made girder forks are superior but cheap telescopics are ok enough to make it not a worthwhile exercise. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| MarJay |
 MarJay But it's British!
| Kickstart |
 Kickstart The Oracle
 Posted: 13:16 - 23 Dec 2013 Post subject: |
Telescopic forks have had well over half a century of development and it takes a long time to catch up with that.
There have only been a few hub centre steered production bikes (Bimota Tesi, Yamaha GTS1000, a scooter or 2, and maybe one or 2 more). Problem is cost, limited steering lock, wear, etc. With a conventional hub centre system you can widen the front swinging arm, but then you land up limiting the lean angle.
If you look at a Tesi there is a VERY large wheel bearing required, plus the steering within that. There are 6 rose joints just on the suspension and steering arm (all of which wear), plus any in the linkage from the bars to the steering arm. A requirement for a high quality shock (cheaper than forks, though) but then trying to find somewhere to hide the shock without it getting too hot. All adds up to the cost.
The system BMW are using these days is probably better for production use. But get the design of that wrong and you have a potential issue with the suspension doing odd things when you brake suddenly. The suspension (rather than steering) works similarly to that used on Vincents (with 2 suspension arms), and if you brake suddenly the arm moves the wrong way and the suspension locks solidly.
| lihp |
 lihp World Chat Champion
 Posted: 13:45 - 23 Dec 2013 Post subject: |
| stinkwheel wrote: |
You could say the same for telescopic forks. Well made girder forks are superior but cheap telescopics are ok enough to make it not a worthwhile exercise. |
An engineer on PBMagForum has developed a girder front end for both an R1 and Fireblade, which involved chopping the headstock off and building from there.
It works exceptionally well, far better performance in every way over the telescopic forks, but only when it's hot.
When it is cold or wet, because the suspension is so effective, he can't work the tire hard enough to get adequate heat into it, and that is where he's stuck with his development.
I think this is the stumbling block, tyres are made for use with telescopic forks, if girder forks, and hub central steering became more mainstream, especially on performance bikes, there'll be a massive cost in tyre development to make something that works properly. ____________________ covent.gardens: lihp is my most favourite member ever |
| Walloper |
 Walloper Super Spammer
| Ribenapigeon |
| Walloper |
| Kickstart |
 Posted: 14:05 - 23 Dec 2013 Post subject: |
A single shock is a saving (although a complex shock, with forks if you want you can put compression damping in one fork and separate rebound damping in the other), but the linkage for it adds to the cost. And nobody has yet come up with a way of having a nub centre steering system without going around the tyre horizontally (after all, that is where a large part of the advantage comes from), and it is there that you lose the steering lock.
Forks are cheap to machine up. A swinging arm is a bit complex to fabricate.
| lihp |
| Ribenapigeon |
| lihp |
| Snorty |
 Snorty World Chat Champion
| lihp |
| Ribenapigeon |
| stinkwheel |
| Snorty |
| stinkwheel |
| MarJay |
| G |
 G The Voice of Reason
| orac |
 orac World Chat Champion
| MarJay |
| Slacker24seve... |
 Slacker24seve... World Chat Champion
| stinkwheel |
| G |
The last post was made 12 years, 312 days ago. Instead of replying here, would creating a new thread be more useful? |
