Dry cleaning leathers
-Matt-
PostPosted: 19:22 - 23 Dec 2013    Post subject: Dry cleaning leathers Reply with quote
Anyone had leathers (1 piece in this case) dry cleaned before? Figuring its a better option than washing them and having to reconditon, plus it will never dry this time of year Neutral
Never thought i'd care enough to bother washing them, but after 4 years sweat and a few months out of use in less then ideal storage, theyve begun to stink to high heaven and are slightly mouldy and covered in mould mites Thumbs Down
j.silvs
PostPosted: 19:46 - 23 Dec 2013    Post subject: Reply with quote
Just get a leather cleaner and give it a go yourself.
Remember dry cleaning is just a fresh sheet put in a tumble dryer with the garment.
I use muc off leather cleaner and a shammy. If it has removable lining then wash it in the machine
-Matt-
PostPosted: 19:50 - 23 Dec 2013    Post subject: Reply with quote
Ah, id figured it involved spraying some powder inside or something, maybe no use then.
The leather itself is fine, problem is the interior which seems unremovable, and as its mesh i cant just wipe it with something Evil or Very Mad
Aff
PostPosted: 19:52 - 23 Dec 2013    Post subject: Reply with quote
What? Confused
Electric Bike Project
Aff
PostPosted: 19:54 - 23 Dec 2013    Post subject: Reply with quote
Dry cleaning uses a solvent instead of a water based cleaner. I imagine you would still have to treat the leather after.
j.silvs
PostPosted: 19:59 - 23 Dec 2013    Post subject: Reply with quote
Yes as stated most uses solvents.
But, had an Insight to the thrilling world of dry cleaners at a young age as a friends family owned a chain of them.
Found out some tricks of the trade where most use something like this:
https://www.amazon.co.uk/Dr-Beckmann-Dry-Clean-Only/dp/B0037S2WQC
Then spot cleaning stains
-Matt-
PostPosted: 20:17 - 23 Dec 2013    Post subject: Reply with quote
Cheers. Perhaps even worse than water then depending on whatever this solvent is Thinking i'll have to pop down and ask the local one what they can do for leather stuff, if anything.
Would be easier to give it a warm wash with some leather-friendly soap in the bath but I can't see it drying out until spring, and by then it will be mouldy all over again Rolling Eyes
doggone
PostPosted: 21:42 - 23 Dec 2013    Post subject: Reply with quote
I have considered doing the lining with some kind of upholstery/carpet shampooing device Confused
The outside is not a problem, I suppose if you kept on top of it, sponging the inside with a damp cloth every few weeks - and most of all always let them air off and store dry - not in garage - it would help.
-Matt-
PostPosted: 21:53 - 23 Dec 2013    Post subject: Reply with quote
Its a real bugger because they are perforated, so even if i light-wash the inside and dry it im worried the remaining mould/mites will be back again in no time from some area i cant get to properly. Come summer leaving them in the sun should fix it, but considering how bad theyve got in a slightly damp room already, im not sure of theyll make summer without some damage Neutral
Helmets are covered in the little buggers too but i can wipe and wash the lining of those luckily. Need to move abroad somewhere warm Mad
Rockhopper
PostPosted: 13:10 - 24 Dec 2013    Post subject: Reply with quote
I asked Alec at Crowtree about this -
"febreeze on the inside then AUTO GLYMM LEATHER CLEANER and then AUTO GLYMM LEATHER BALM on the outside. What ever you do , do not leave a lot of the balm on, as when you go out the dust will stick to he suit and make it worse. Buff it off with dry cotton cloth .The zips, just clean with water, do NOT oil or put candle wax on them"
The last post was made 12 years, 300 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.05 - MySQL Queries: 15 - Page Size: 65.89 Kb
