Electrical accessories, how do you keep the battery tidy?
Yamaha Jim
PostPosted: 21:09 - 23 Dec 2013    Post subject: Electrical accessories, how do you keep the battery tidy? Reply with quote
I've added lots to my bike from the battery such as:
alarm feed,
optimate feed,
air horn feed,
hot grips feed,
12v socket feed,
each with inline fuses.
Problem is as you can imagine, I've now 5 wires coming off the batter terminals and its looking messy!
I'm wanting now to hard wire some cameras to the bike too.
How have you guys done similar or are there any products out there which may help?
Thanks
conker
PostPosted: 21:17 - 23 Dec 2013    Post subject: Reply with quote
https://www.ebay.co.uk/itm/Relay-3-Fuse-Base-Kit-4-5-PIN-Flasher-Relays-ATO-Fuses-Holder-Socket-Box-/180739111864?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a14e3fbb8
Added benefit, prevents forgetting to switch something off from flattening the battery. Wire it up so that coming off from each fuse a tail with a bullet connector.
Yamaha Jim
PostPosted: 21:24 - 23 Dec 2013    Post subject: Reply with quote
Would the relay be for letting the battery live through when switched through the relay by the ignition?
Thanks I'll check this out Karma Thumbs Up
conker
PostPosted: 21:34 - 23 Dec 2013    Post subject: Reply with quote
Oui. Pretty easy really.
stonesie
Yep, the relay is wired between the battery + and fuses with an ignition live and earth to either the battery or frame. It is an automatic switch Thumbs Up
I use one on the heated grips so I can't forget to turn them off.
A really good place to get an ignition live is the rear brake light switch, you just need a test light to find out which of the 2 wires is the power and which goes off to the bulb (you don't want it only working when you've got the back brake on) If you cut into the wire then do it on the wire between the switch and connector so the main wiring loom stays untouched.
PostPosted: 21:49 - 23 Dec 2013    Post subject: Reply with quote
Looks like a good solution, but remember not to wire up the Optimate through the relay.
conker
PostPosted: 22:05 - 23 Dec 2013    Post subject: Reply with quote
Alarm too.
Full kit here https://www.simtekuk.co.uk/product.php/fused_relay_holder_incl_relay_and_3_fuses/?k=:::1264322
c-m
PostPosted: 22:59 - 23 Dec 2013    Post subject: Reply with quote
Never really understood how the frame completes the circuit. The resistance must be massive.
Why doesn't it drain the battery?
Kind of like when you connect a battery to a piece of metal. It heats the metal and discharges the battery.
fraser2312
PostPosted: 12:46 - 24 Dec 2013    Post subject: Reply with quote
You could use on of these;
https://www.nippynormans.com/products/f650stcsgsdakar/item/fuzeblock-switchable-fuse-panel-fuz-fz1
It would certainly tidy things up but you could buy your own relay and bus bars and do it for less £ Thumbs Up
conker
PostPosted: 13:14 - 24 Dec 2013    Post subject: Reply with quote
Wow, that is very expensive for what it is.
darrel15
PostPosted: 08:00 - 25 Dec 2013    Post subject: Reply with quote
I will keep it in mind thanks for sharing the information.
sdf
smegballs
PostPosted: 09:07 - 25 Dec 2013    Post subject: Reply with quote
Steel might not conduct as well as copper, but in a frame there is a massive amount of it. For a conductor, the resistance will be a based on the cross-sectional-area of the conductor, and the specific resistivity for the material.
It's like the difference between a pipe with a large bore and one with a small bore: the greater the area to flow the lower the resistance to the liquid.
Obviously you get "bad earths" when the connectors from the various electrical fittings get corroded where they bolt to the frame, which results in a high resistance and all manner of weirdness can happen.
Next time you have the multimeter out check it if you like, from pretty much any point of bare metal on the frame to the battery negative terminal shouldn't be more than a couple of ohms.
The last post was made 12 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 72.42 Kb
