| Lord Percy |
 Lord Percy World Chat Champion
| sickpup |
 sickpup Old Timer
| Sable |
 Sable World Chat Champion
| sidewinder |
 sidewinder World Chat Champion
 Posted: 19:09 - 27 Dec 2013 Post subject: |
| Seigi |
 Seigi Nova Slayer
| c-m |
 c-m World Chat Champion
| -Matt- |
 -Matt- World Chat Champion
 Posted: 19:44 - 27 Dec 2013 Post subject: |
Can't see how this would work on a 2 wheeled vehicle, without any constant curve on the tyre would it not just constantly flat-face the road like riding with a huge puncture
Interesting design though |
| Walloper |
 Walloper Super Spammer
 Posted: 19:57 - 27 Dec 2013 Post subject: |
It has been around for ages.
Nothing to-date can compete with a Pneumatic tyre for performance.
That honeycomb wheel is only puncture proof.
You can make a pneumatic tyre puncture proof without having to go to all the bother of re-inventing the wheel.
No reason it can't be used on a motorbike. A Harley Dae-Anything would be an apt candidate for the technology as they can't corner very well anyway.
Useless on a proper bike as there is very limited lateral performance. ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair
| Rogerborg |
 Rogerborg nimbA
 Posted: 19:58 - 27 Dec 2013 Post subject: |
Seen them before, and I lulz at the tin foil hatters.
The issue I can see is fatigue in the plastic as it flexes. ""These are designed to last the life of the vehicle," claim Polaris. The same Polaris who made stuartt's Victory Hammer...
Nanny Brussels would have a fit if you tried using those on road in Europe. Polaris would likely need to partner with some German outfit in order to magically make them $uitabl€.  ____________________ Biking is 1/20th as dangerous as horse riding.
| Nick 50 |
 Nick 50 World Chat Champion
 Posted: 20:12 - 27 Dec 2013 Post subject: |
They will work well on slow moving vehicles, such as Army Hummers and such. They look like they are only designed to deal with a radial load. I would question the longevity of the wheel under an axial load (like cornering hard) on a car.
As for motorcycles, as soon as you lean past 0 degrees, you are changing from a Radial load to an Axial load. The more the lean, the more the axial load increases.
I highly doubt the wheel design would give a consistent flex with a motorcycle leaned over and guess it would try to buckle in on itself.
https://www.bwc.com/files/axial_radial.png ____________________ Current Bikes: ZX7r 97 (Black Beauty), VFR400 NC24 (The banana)
First bike: A GZ125 Lemon....... |
| Walloper |
| iooi |
 iooi Super Spammer
 Posted: 20:37 - 27 Dec 2013 Post subject: |
I should imagine that cost is a major factor.
Where a tyre is cheap to produce, as is a std wheel.
These will be expensive. Require a full replacement once the rubber has worn down.
Also how often will they be checked for cracks. Given the state of roads.
How often do we get punctures now?
Bike I have down 30K + and not had one in the last 4 years.
Car 40K + and only had one (did not go flat) that was a screw in a tyre that only come to light once it was changed  ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| Walloper |
 Posted: 20:44 - 27 Dec 2013 Post subject: |
| iooi wrote: | I should imagine that cost is a major factor.
Car 40K + and only had one (did not go flat) that was a screw in a tyre that only come to light once it was changed  |
As I sez, Pneumatic Tyre attributes haven't been advanced much since the air filled rubber tyre was invented. (by that Scotch cnut )
Cannot help masel sorry.
https://en.wikipedia.org/wiki/John_Boyd_Dunlop ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| _mjs_ |
 _mjs_ Could Be A Chat Bot
| Walloper |
| Lord Percy |
 Posted: 21:26 - 27 Dec 2013 Post subject: |
Interesting points so far
I'm not really for or against it, I just wondered what others thought about it. It does interest me though. I would be more than happy to try one.
About the shape of the tyre and suitability for motorbikes - see link at end of post. Or just see this image:
https://thekneeslider.com/images/michelinairless2.jpg
Nick50 - Regarding the radial vs axial load - I'm not sure what you mean there. Just by looking at the design of it, it looks like it wouldn't have any problem at all under an axial load. It is all the same material after all. What do you expect would happen under a large axial load?
Whoever said about the inner structure getting cracks - fair point. Although it would be interesting to see the stuff up close. I mean, we can sit here and worry about that honeycomb structure getting a crack in it, but maybe it's made of a material that has as much chance of 'cracking' as the rubber of a standard tyre.
Also about replacement of the tyre - I read somewhere (I think in one of the links below) that the whole wheel would not need replacing, as the 'tyre' surface material would just need to be stripped and relaid. It would actually use less material as it doesn't have a side wall.
Another benefit is that the tread could have plenty of proper holes put into it to greatly reduce the risk of aquaplaning.
Those are my thoughts so far
More info here:
Michelin Tweel - Benefits and Drawbacks.
Michelin prototype airless motorcycle tyre. |
| -Matt- |
| chickenstrip |
 chickenstrip Super Spammer
| -Matt- |
 Posted: 21:33 - 27 Dec 2013 Post subject: |
Potential then perhaps looks bloody precarious though, would of thought you have to fling yourself to get it to lean each time  |
| Walloper |
 Posted: 21:34 - 27 Dec 2013 Post subject: |
| Lord Percy wrote: | Interesting points so far
More info here:
The only 'advantage' is over rated puncture proofing. Apart from that it brings nothing new to the table. Which is why I'm out.  ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
| Islander |
 Islander World Chat Champion
| chickenstrip |
| Lord Percy |
| Walloper |
 Posted: 21:50 - 27 Dec 2013 Post subject: |
| Pete. |
 Pete. Super Spammer
The last post was made 12 years, 291 days ago. Instead of replying here, would creating a new thread be more useful? |
