Help needed: sudden low power
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4  Next
Astandane
PostPosted: 16:51 - 29 Dec 2013    Post subject: Help needed: sudden low power Reply with quote
Bike: 1986 Kawasaki Z400 F2, 4 cylinder, carburetor.
Hello all,
Ok so here is my problem. My recent purchase (the above bike) has been running fine all day. I have probably done around 200 miles or so (today) (and have had it for a couple of days now). On my way back home, I stopped by the shop. As I set off all was fine, I turn a corner and as I begin to pull away I am suddenly low on power.
Opening the throttle more makes very little difference, though I did have a 'blip' where all was normal for a moment.
There is no smoke from the exhaust, no oil leaking and no strong smells. All of the lights and electrical systems appear fine.
Before this the bike started very well and warmed on the choke easily. After I limped home I let the bike settle for a minute or two and started it up again. There is still a lack of power, and is now harder to start, but will start although it now idles at much lower rev. Revving in neutral doesn't blip, stutter or whatever, but doesn't have the same power as normal.
I'm thinking blockage somewhere but do not yet know the location of the fuel filter.
Any help would be really appreciated Smile
Kymco Pulsar 125 Suzuki GN 125 Kawasaki ZX400 Honda CBR400RR NC23
Walloper
PostPosted: 16:57 - 29 Dec 2013    Post subject: Reply with quote
Stab in Dark.
Is there Fuel in it?
Is it Petrol or Diesel? Laughing
Astandane
PostPosted: 16:59 - 29 Dec 2013    Post subject: Reply with quote
Yes plenty of fuel. Have tried with tap in both ON and RES position. No idea why there would be diesel in it.
69chris
PostPosted: 17:03 - 29 Dec 2013    Post subject: Reply with quote
as it happened after you turned a corner could it have 'tugged' the wiring around the headstock and partially pulled a connector apart or disturbed the throttle cable somehow ???
Astandane
PostPosted: 17:06 - 29 Dec 2013    Post subject: Reply with quote
Been turning corners all day! I don't think so and wouldn't explain poor idling.
Walloper
PostPosted: 17:08 - 29 Dec 2013    Post subject: Reply with quote
Cause some daft edjit possibly put it there.. Embarassed Very Happy
Astandane
PostPosted: 17:09 - 29 Dec 2013    Post subject: Reply with quote
Filled the tank with petrol before I left for home Crying or Very sad
Walloper
PostPosted: 17:12 - 29 Dec 2013    Post subject: Reply with quote
Wild Crack at it now...
The fuel cap vent has become blocked (as if by magic).
It would allow normal power until the fuel used produced a vacuum in the tank and that would slow fuel supply to the engine.
69chris
prob not but its always best to check the obvious/easy stuff 1st Wink
we'r talking about an old bike here so it'd be easier to just say it could be anything from rust in the tank grotting up the tank filter/ carbs to the coils breaking down,
good luck Thumbs Up
PostPosted: 17:15 - 29 Dec 2013    Post subject: Reply with quote
Do you have an "OFF" on the tap or a "PRI"
If PRI, try using that.
Alternatively, 200 miles today + 1 tank of fuel is amazing, sure you haven't refueled today.
Astandane
PostPosted: 17:17 - 29 Dec 2013    Post subject: Reply with quote
Hmm ok. What bothers me the most is that it just suddenly happened. Although at least it happened right outside my front door Very Happy
Astandane
PostPosted: 17:19 - 29 Dec 2013    Post subject: Reply with quote
good luck Thumbs Up
Yeah you're right I guess. It's actually looking really good for it's age and has on just now done 26,000.
Astandane
PostPosted: 17:20 - 29 Dec 2013    Post subject: Reply with quote
I will do so. And yes I topped up before I left start and end of journey.
doggone
PostPosted: 17:22 - 29 Dec 2013    Post subject: Reply with quote
Could it be running on two cylinders because one of the coils has gone?
All my bikes 'of that vintage' did that at least once.
Astandane
PostPosted: 17:23 - 29 Dec 2013    Post subject: Reply with quote
I wondered that, but I did experience a blip of full power as I was trundling down the lane at 15mph.
doggone
PostPosted: 17:25 - 29 Dec 2013    Post subject: Reply with quote
That's actually what made me suggest it, they often go in and out before failing totally, whereas other problems don't intermittently go away.
Astandane
Would age or mileage contribute more to this? Bike has only done 26,000.
Walloper
Here's another for you.
Two Triumph Sprint STs
One less than 4k on the way home one evening I noticed a loss of power. Topped up fuel tank but still the same. The fuel supply is via an electric valve under tank.
Second bike same problem but at 6k.
Dealer check determined failed Ignition coils on two cylinders of 1st bike and one on the 2nd bike.
Low mileage failures in areas that SHOULD be bullet proof with today's tech. I no longer own British Bikes. (apart from my two Trusty Auld Beezirz)
doggone
PostPosted: 17:26 - 29 Dec 2013    Post subject: Reply with quote
I had one go about 4000 miles.
When they go they go.
Astandane
Hmm to me the failure was complete and sudden apart this ONE brief blip. No other occurrences of it.
Astandane
PostPosted: 17:28 - 29 Dec 2013    Post subject: Reply with quote
I'm really in for a sleepless night then! I'm going to have run it down to my dealer tomorrow. If this is what has happened, would 2 mile max run be damaging to the engine?
doggone
PostPosted: 17:29 - 29 Dec 2013    Post subject: Reply with quote
Well don't rule coils out because it's an easy fix.
See what happens if you take the leads from one coil off.
It will either not run at all or make next to no difference.
Don't forget which one goes where. Laughing
Astandane
PostPosted: 17:31 - 29 Dec 2013    Post subject: Reply with quote
Your words 'easy fix' are pleasing to my eyes. Cutting through traffic and cruising along today while the weather was nice has been suddenly spoiled Neutral
Walloper
PostPosted: 17:33 - 29 Dec 2013    Post subject: Reply with quote
You can determine if the coils are fooked by a 'Cut Out Test'. With the engine at idle remove a plug connector to the coil or a plug cap if single coil.
A dead coil/plug/HT circuit will have no effect on the engine. A good coil/plug/HT circuit will result in the engine becoming very lumpy or a stall.
Process of elimination.
Running the bike with a dead cylinder means unburned fuel can run down into the oil. SO work out how much fuel to run two miles Divided by the No' of dead cylinders will let you know how much fuel you have in the dead cylinders. Most of the mixture will be blown out when on the exhaust stroke though so no MAJOR worry for a shot distance.
Astandane
PostPosted: 17:40 - 29 Dec 2013    Post subject: Reply with quote
I'm starting to think it is the coils then as those symptoms sound like what is happening. I remember a mechanic once saying "Welcome to the world of biking".
The last post was made 12 years, 325 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 4
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 128.37 Kb
