what problems can a bad stator cause
jason3249
PostPosted: 14:58 - 29 Dec 2013    Post subject: what problems can a bad stator cause Reply with quote
Hi all just wondering what problems can a bad stator cause
Thanks all. Smile
WD Forte
PostPosted: 16:18 - 29 Dec 2013    Post subject: Reply with quote
Basically.
It wont/cant charge the battery.
This means the battery is the sole supplier of electrical power and
soon goes flat.
Occaisional stator testing is pretty quick and easy
and knowing how to do this realy helps as sometimes
it isnt the stator at fault, but a bad battery or connectors and wiring
While I'm rantin on....
there are stators and stators
A bike with CDI ignition may have a 2 part stator
where most of the windings generate power to the battery via the Rec/reg and have another part, say two coils that power the ignition
Sometimes it may be just the generating coils that fail, sometimes the CDI source coils.
If you know your bike, pinning down the culprit is pretty quick and easy.
bikers smell of wee
Islander
PostPosted: 16:28 - 29 Dec 2013    Post subject: Reply with quote
Yep, this. ^^
You can test the output using the AC ranges of a multimeter. Thumbs Up
WD Forte
PostPosted: 16:48 - 29 Dec 2013    Post subject: Reply with quote
Just had alook for some pics
Heres a typical 'charge only' Bike stator
https://thumbs1.ebaystatic.com/d/l225/m/mSYmZ-IMwSmIsXYCzhIySYA.jpg
The first test I do is measure the resistance between all pairs of the yellow wires.
You want to see very low resistance between any pair < 1 ohm
and very high resistance between any wire and the stator body
which is earth or ground.
You want to see megaohms or off the scale here.
Anything in between is often suspect in my experience
If you can disconnect the stator when the bike is running
you can measure the AC voltage between pairs at tickover
and may get around say 20VAC.
This voltage will rise to possibly approaching 100VAC when you rev it
on a healthy stator.
This all depends on the size of bike and stator of course.
Testing and recording your results when its all going well gives you
a reference point for later if it starts to play up.
bikers smell of wee
ZebraDriver
PostPosted: 18:12 - 29 Dec 2013    Post subject: Charging Faults Reply with quote
Came across this site the other day. It gives a very clear/concise description of how to find/identify charging faults
https://www.crowitis.com/images/fault_finding.pdf
If you can print stuff its probably worth printing it for the day when you do need it.......
ZD
jason3249
PostPosted: 19:41 - 29 Dec 2013    Post subject: Reply with quote
Can a bad stator cause back firing and out the carb spluttering and the bike wont run right rev bog etc
Smile
PostPosted: 19:51 - 29 Dec 2013    Post subject: Reply with quote
Possible, but probably not that likely. On some bikes the stator contains parts of the ignition system, on others little more than the charging circuits .
What bike is it?
ZebraDriver
PostPosted: 20:23 - 29 Dec 2013    Post subject: Reply with quote
A faulty reg/rect, allowing the charging voltage to climb beyond normal limits will cause the symptoms you list.
jason3249
PostPosted: 22:50 - 29 Dec 2013    Post subject: Reply with quote
It's only a pit bike I got yesterday I've changed the carb to a new one fresh fuel new plug new cdi
The only one I haven't dun is the voltage regulator
But I have tested the batt wires and I'm getting normal voltage and the batt is new
Another problem keep on getting engine what don't work but did know there was a problem as brought it as a non runner got it to this stage
So you think I should change the voltage regulator as there cheap are get one tomorrow and just to be save are get a stator
Just splutters bogs back fires and out the carb just looks like compressed air coming out but getting flames out the exhaust does idol if I turn the screw up so it has to run high and it will stall out and it keeps kicking back and it hurts my foot is feeling it
What else you think it mite be
RhynoCZ
PostPosted: 22:52 - 29 Dec 2013    Post subject: Reply with quote
I thought the opposite? When the part is done, it won't let through any power = not charging at all.
ZebraDriver
PostPosted: 23:17 - 29 Dec 2013    Post subject: Reply with quote
Nope. If it breaks down it can start to let more and more unregulated voltage through. When my reg/rect broke down recently I was measuring more than 18 volts across the battery. At that voltage things like the coil and ignition system start to malfunction, hence you can get shitty running, backfiring etc. It can also fry your battery
ZD
RhynoCZ
PostPosted: 23:51 - 29 Dec 2013    Post subject: Reply with quote
ZD
Isn't the rectifier just a diode that lets the current go only ''one way'', so it changes it from AC to DC? So when the diode is busted, it won't let anything through, just like if cut the wire.
I might be wrong, as always. Thinking
ZebraDriver
PostPosted: 00:23 - 30 Dec 2013    Post subject: Reply with quote
Yes, the rectifier is a device that converts AC into DC. The regulator is what holds the voltage output at a steady (suitable) level. On most modern bikes there is a combined rectifier/regulator (reg/rect). The individual component parts can break down so that you still get a DC output but it's not regulated to the correct voltage.
ZD
ZebraDriver
PostPosted: 00:33 - 30 Dec 2013    Post subject: Reply with quote
It gets more complicated than being a single diode. A lot of bikes have a three phase alternator and have a diode bank to convert this to DC for the bike to use. Rectified three phase is better because it provides a smoother DC. Because it uses a bank of diodes it is possible for one or more to break down, but not all of them, this can produce some strange electrical gremlins.
Having said all of the above if the OP's bike is a pit bike I would guess that it probable does not have a three phase alternator, more probably a single coil, with a second coil for the ignition circuit.
ZD
PostPosted: 18:22 - 30 Dec 2013    Post subject: Reply with quote
Regulator / rectifier units tend to be combined and can fail in a few ways. I have had them stop charging totally, and also had them send the voltage too high (which can fry other components). Never had one fail and give out AC instead.
As to the pit bike, I would like to see a wiring diagram for that particular bike. My guess is that the stator includes the charging circuits and the trigger for the ignition. Could be worth trying a timing light on it and checking that the timing is correct.
MartQ
PostPosted: 18:41 - 30 Dec 2013    Post subject: Reply with quote
A diode is capable of failing in two ways.
Most commonly, they go open circuit and therefore do not allow any current to pass at all.
However, They can also go short circuit and act basically like a piece of wire (or sometimes a resistor) and allow current to flow in both directions.
This can cause either no (or insufficient) charging, or indeed, overcharging.
jason3249
PostPosted: 14:30 - 01 Jan 2014    Post subject: Reply with quote
It was the stator its running now you can ride it but does keep bogging and dying out some times at hight speed
But does start well now and idols fine revs up just bogs some times and at mid range
What you think on that
Smile
MartQ
PostPosted: 14:36 - 01 Jan 2014    Post subject: Reply with quote
Could be a failing CDI unit or carb set up.
I would suspect the CDI though if you've been having electrical problems as one fault can quickly cause others further down the line.
jason3249
PostPosted: 19:30 - 01 Jan 2014    Post subject: Reply with quote
All ready tried a new cdi been playing with the carb but cant get it any better
gone try the needle settings
Put new gaskets on the inlet manifold
Have played with the carb does get a little better but cant get it bang on
Smile
The last post was made 12 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 100.66 Kb
