Gasket change
CG Sam
PostPosted: 21:27 - 29 Dec 2013    Post subject: Gasket change Reply with quote
Hi, probably a bit of a noobish question, but my head gasket has been blowing and I'm going to change it tomorrow. My question is do you need to use a gasket sealant when you put a new head gasket on or do you just remove the old one and replace and reassemble?
Thanks,
Sam.
CG125, SV650S, CBR600F, GSXR600 SRAD
Nemo
PostPosted: 21:31 - 29 Dec 2013    Post subject: Reply with quote
Take it off, clean both surfaces, put new one on, bish bash bosh.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
CG Sam
PostPosted: 21:33 - 29 Dec 2013    Post subject: Reply with quote
Cheers, so need for any sealant?
Thanks,
Sam
MattWadz
PostPosted: 23:54 - 29 Dec 2013    Post subject: Reply with quote
depends on the type of gasket i think?
but ive never used any sealant as it can block up oil/water galleries, but i dont think youl have many of those in a CG125 head.
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
69chris
PostPosted: 00:00 - 30 Dec 2013    Post subject: Reply with quote
i only ever use a thin smear of grease on any gasket, unless the mating surfaces are really rough you shoudnt need owt else Smile
PostPosted: 10:38 - 30 Dec 2013    Post subject: Reply with quote
Most modern gaskets already have a thin coating of sealant.
Looking at the pictures, a CG125 head gasket is a coated fibre gasket with sealant already on it and a built-in, steel fire-ring.
https://cdn3.fast-serve.net/cdn/BrooksBarn/CG125-CYLINDER-HEAD-GASKET_700_600_3T9VE.jpg
This adds up to you wanting clean, smooth and de-greased mating surfaces. At most a TINY smear of grease on the fire-ring
CG Sam
PostPosted: 19:08 - 30 Dec 2013    Post subject: Reply with quote
Cheers for all the replies, change went smoothly and quite enjoyed doing the work myself.
Not sure what caused the problem but the metal ring was warped on it. Will see how it goes with the replacement part and research what caused it.
Thanks again for the advice,
Sam.
The last post was made 12 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 55.86 Kb
