Brake Caliper / Copper Grease
Rogue_Shadow
PostPosted: 23:27 - 30 Dec 2013    Post subject: Brake Caliper / Copper Grease Reply with quote
Ello BCF
This would normally be a quick question for the almighty BCF search button, but it doesn't seem to of come off it's Holidays yet Rolling Eyes
Planning to clean/service/destroy my front and rear brake calipers on my SV. General winter maintenance & to get rid of the squeaking noise from the front pads.
I missed this step last year, so can anyone recommend a good copper grease for the BACK of the brake pads? Alot of people on SV650.org seem to believe this will stop the noise.
https://img.photobucket.com/albums/v669/gladey/SV650S/coppergreaseonpad.jpg
Also, are there any other caliper parts I should be greasing to make life easier? I usual clean the pin and rub it down with sandpaper, yet the picture above looks like it's been greased aswell Neutral
Any additional help is always appreciated Thumbs Up
Thank You
CaNsA
PostPosted: 23:28 - 30 Dec 2013    Post subject: Reply with quote
copaslip
Islander
PostPosted: 23:30 - 30 Dec 2013    Post subject: Reply with quote
Comma, Loctite, Carlube, Granville...
I bought a tub of copper grease from Halfords for a couple of quid. That's perfectly fine for putting it on the back of brake pads. It's also good for pad pins and caliper sliders.
Red rubber grease is good for pistons too.
Rogue_Shadow
PostPosted: 23:33 - 30 Dec 2013    Post subject: Reply with quote
You guys get off the forum FFS! Laughing
That's got to be a record for response Thumbs Up
Karma Karma Karma
PostPosted: 23:38 - 30 Dec 2013    Post subject: Reply with quote
Karma Karma Karma
By the way, don't put that much grease on the back of the pad. You just need a very light smear, not a thick dollop like that. If you dollop it on then it could melt and end up on the pad surface.
Rogue_Shadow
PostPosted: 23:53 - 30 Dec 2013    Post subject: Reply with quote
Cheers Marjay Thumbs Up
Was only planning to spread a thin layer on. Should I do the same with the pin?
Dreading what state the Calipers & pads are in given I've missed this last year Razz
serlant
PostPosted: 01:25 - 31 Dec 2013    Post subject: Reply with quote
secondly, I look at the coppaslip glob, and i look at the ring left by the piston, I hope he smeared the coppaslip around otherwise it won't even touch the piston.
I've never greased the back of pads and never had pad squeal Confused but pad pins always!
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
Rogue_Shadow
PostPosted: 02:39 - 31 Dec 2013    Post subject: Reply with quote
Thanks all
Thumbs Up Karma Thumbs Up
The last post was made 12 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 60.72 Kb
