| Sj.silent |
 Sj.silent L Plate Warrior
 Posted: 22:12 - 30 Dec 2013 Post subject: |
I have no idea. I'm just facinated.
Is there a reason you are going to a huge amount of effort to fit a peaky sportsbike engine into what is generally reckoned to be a bland and boring commuter bike frame?
Why an XJ6? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Az |
 Az World Chat Champion
| P.addy |
 P.addy Red Rocket
 Posted: 22:39 - 30 Dec 2013 Post subject: |
Dis aint Lego. I can't wait till he finds out this won't fit. |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 01:33 - 31 Dec 2013 Post subject: |
you'll have to do a bit of measuring,
dont use the vfr800 swing arm or a speed triple arm. they are pretty wide, i had to do quite alot of machining to get one to fit a zxr750 frame,
the stock xj600 uses a 130 rear wheel, so obviously is a narrow frame,
a vfr400 swing arm is the obvious choice,
front end is no bother compared to the rear,
press out the stem from a xj bottom clamp and press it into your donor forks triple clamps,
i think i used zx10r forks on my 7, but you are just going for looks, so what ever you find cheaply, i'd look for 400cc forks as they are normally a fair bit cheaper to buy than the bigger bikes,
good luck, your gunna need it ____________________ the humans are dead
I kick arse for the lord
| Nope. |
 Nope. World Chat Champion
| temeluchus |
 Posted: 09:31 - 31 Dec 2013 Post subject: |
Wether it will physically fit in the frame notwithstanding. I suspect the biggest hurdle to overcome on this project will be the chain alignment. The XJ motor is a very upright motor and the final drive shaft is unusually high up.
Getting the ZX6 motor in the frame is probably going to result in the final drive shaft being lower down than the swingarm pivot making it impossible to maintain an even chain tension as the suspension moves.
I'd be getting that engine mocked up in the frame before I even thought about doing anything else. If you achieve this, running gear will be childs-play. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| c_dug |
 c_dug Super Spammer
| MarJay |
 MarJay But it's British!
 Posted: 10:12 - 31 Dec 2013 Post subject: |
Either you're a mechanical genius and playing your cards very close to your chest, or you're a foolish dreamer who has no idea about Engineering.
Either way, allow me to assist you:
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=281234507354&clk_rvr_id=567485223713&item=281234507354&lgeo=1&clk_rvr_id=567485223713&vectorid=229508
{edit} Wait... you're embarking on a project without knowing if the swinging arm and forks will fit? I think my brain just glossed over that part... The swinging arm in the link above probably won't fit without machining, but most things can be made to fit. However, without ANY precedent to work out if something is possible it is a huge task to build a special like this. I'd personally start with a standard XJ6 and then try swapping the forks, then the swinging arm and try the engine last. But I have to say, you can't knock your ambition! {edit} ____________________ British beauty: Triumph Street Triple R; Loony stroker: KR1S; Track fun: GSXR750 L1; Commuter Missile: GSX-S1000F; Cheap project: CBR900RR FireBlade
| davebike |
 davebike World Chat Champion
 Posted: 10:58 - 31 Dec 2013 Post subject: |
Yes real hard job
I bet it will be a blast to insure
Dave ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| kestrel |
 kestrel Nearly there...
| sidewinder |
 sidewinder World Chat Champion
 Posted: 12:05 - 31 Dec 2013 Post subject: |
These guys do lots of divvy mods on here r1 front ends etc
https://www.xjrider.com/ |
| MarJay |
| chris-red |
| MarJay |
| kestrel |
| almostthere |
 almostthere Traffic Copper
 Posted: 20:13 - 31 Dec 2013 Post subject: xj |
can't see how you're gonna mount the engine there arent any lower engine mounts on that thing ____________________ Beer, It's the reason I get up every afternoon
www.mfairco.uk |
| Az |
 Posted: 22:29 - 01 Jan 2014 Post subject: |
After the OP saw negative comments, he got all butt sore and said he wasn't coming back to the forum
I'll keep u all updated anyway, just got off the phone with him and he said the frame arrives on friday.  |
| MarJay |
| Az |
| Az |
The last post was made 12 years, 296 days ago. Instead of replying here, would creating a new thread be more useful? |
