Honda cd 200 6v no spark at points
Loffty1
PostPosted: 12:03 - 01 Jan 2014    Post subject: Honda cd 200 6v no spark at points Reply with quote
Hi people. I'm new to the forum so plz be tame with me. I am in the middle of doing a complete cd 200 rebuild. I acquired this bike 18 months ago as a freebie and decided to completely rebuild it. I am now starting to get it back together and have come across a problem. First of it's the 6 v model with battery. I have got it completely wired back up and I have got no spark. I decided to check the points and there is no spark there either. Would this be to do with not having a battery on it. Does it need a battery on it to get a spark at the points. Or would it be to do with the coil. Sorry for the questions but have searched the internet and can't find anything. Hoping some body on here could give me the answer. Photos being taken so will post them on here. Do apologise if this is in the wrong area. Cheers loffty
Loffty1
PostPosted: 14:08 - 01 Jan 2014    Post subject: Reply with quote
Hi thanks for reply. Will it not make a spark even if I put a 6 volt battery charger on to the live and earth terminals. this is wot I have tried as do not have a battery yet but nothing.
bladerunner
PostPosted: 14:37 - 01 Jan 2014    Post subject: Reply with quote
Is the charger powering your lights etc? Most modern chargers don't apply current unless they detect a battery......bloody silly idea that as they won't charge a flat battery either!
Loffty1
PostPosted: 14:53 - 01 Jan 2014    Post subject: Reply with quote
Yes charger is powering the lights all be it dim and the horn works. But obviously when kick it over no spark. That's why I took the cover of to se if when I open the points it's sparks but nothing. That was with the battery charger connected and ignition switched on.
bladerunner
PostPosted: 15:19 - 01 Jan 2014    Post subject: Reply with quote
If your charger is pumping enough juice out to power the horn I expect you'd have enough for the ignition. I'd check to see if the low tension side of your ht coil is getting voltage and take it from there. Also ..and I'm casting my mind back to the early 80's here.....when you tested the points....it was with them in the closed position and you opened them to check for a spark yes? If so its a continuity test thru the system and ohm meter on the coils and check ignition switch is working and no kill switch earthing out etc....oh and the usual bit of fine wet and dry on the points face to remove any oxide.
Loffty1
PostPosted: 16:03 - 01 Jan 2014    Post subject: Reply with quote
Yes points were in the closed position and then when I opened them up nothing. No spark. Am I right in thinking the points take a feed from the coil ? Hence if no reading from coil no spark at points.
Loffty1
PostPosted: 16:12 - 01 Jan 2014    Post subject: Reply with quote
bladerunner
PostPosted: 16:43 - 01 Jan 2014    Post subject: Reply with quote
Again it may be better waiting from those who know better but most systems I used to work on had a battery + feed to the ht coil and would earth via the points to earth.....however my cd200 was CDI and the last points system bike I owned was an rd125 dx twin!!!!
Teflon-Mike
tl;dr
PostPosted: 16:51 - 01 Jan 2014    Post subject: Reply with quote
Have you replaced the condenser?
If not, do so.
Its an 'inert' component in the system; basically an electrolytic capacitor that's wires in parallel across the points, so that when the points open, the volts across the gap get 'soaked' into the capacitor, charging it up, rather than trying to 'arc' across the points gap.
When old, they break down, and can go closed circuit, effectively keeping the points 'closed' so no spark.
If you have replaced the points and or the condenser...
Go back and double triple check all the stoopid little terminal pillars, against the schematics in the book or on CMSL.
So many bits of the mechanically operated switch that is the points are 'live' carrying volts and easily earthed if a fibre washer is missing or a spade or ring connector made the wrong side of one!
Fif-faf-fiddly little fuggers, especially if you are working through a window in the bludy rotor... (on other engines)
WD Forte
PostPosted: 17:45 - 01 Jan 2014    Post subject: Reply with quote
I think the 6V CD200 is similar to the 6V CD185
so some searching on this may help you.
If it were mine, I'd consider upgrading it to 12v
this page may help
https://www.pakwheels.com/forums/d-i-y-projects/118480-upgrading-your-road-master-cd-200-185-twin-4
bikers smell of wee
Loffty1
PostPosted: 20:13 - 01 Jan 2014    Post subject: Reply with quote
Thanks for the info guys. Just been in and done a test on the coil. Got good reading from secondary but nothing out of the primary. Could this be the broblem. Ohm meter on the black and white cable and the other cable into the end of the ht lead. Nothing no readings!!
WD Forte
PostPosted: 21:44 - 01 Jan 2014    Post subject: Reply with quote
Good reading?
What? where? how?
That coil will have power in and power out to the points
I'd test the resistance between the power out and ground first
and with good points and condenser, expect the resistance to go high and very low as the motor turns and the points open and close
If it all looked OK I'd then do power on tests and track that.
Stuff like that
bikers smell of wee
Loffty1
PostPosted: 19:59 - 02 Jan 2014    Post subject: Reply with quote
Done a test as the manual says. On the coil. Secondary test ohm meter to the 2 ht leads that's in spec with the manual. Primary test as it say in the manual ohm meter one to the blk/ white cable if the coil and the other to the ht lead. no reading at all. Nothing is this a fault with the coil. I'm guessing that cause there no reading it's duff. And hence no spark at the points. Am I on the right track or am I way off. Electrics isn't my best understanding. Sad
Loffty1
PostPosted: 22:48 - 03 Jan 2014    Post subject: Reply with quote
Just an update. I have put new points on to day and hey presto now have a spark at points. And good sparke at the spark plugs. Now need to check ignition timing as it's struggling to start. Keep you all updated with the progress.
Loffty1
PostPosted: 22:41 - 06 Jan 2014    Post subject: Reply with quote
Hi a little up date. Started the cd tonight after a few mins kicking it over. Hasn't been started in 15 years. Engine sounds good after the rebuild. But runs a bit lumpy and spluttery. Need to double check the ignition timing.
bladerunner
PostPosted: 23:19 - 06 Jan 2014    Post subject: Reply with quote
Nice to hear you've got it fired up! Always a major milestone that! Mechanical advance unit and timing probs both worth checking as well as a bit of running just to let the motor settle again! Nice updates Smile
The last post was made 12 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 92.15 Kb
