How do you know when you need a rebuild?
fuzz
PostPosted: 15:49 - 26 Dec 2004    Post subject: How do you know when you need a rebuild? Reply with quote
What signs are there that tell you it's time for a rebuild on a 2t? I ask as the NSR is around it's 10,000 mile mark, but I know they can go up to twice that mileage before needing a rebuild. I'd like to find out before it pops on me. Praying
PostPosted: 16:41 - 26 Dec 2004    Post subject: Reply with quote
Mostly I would expect the small ends to last for 20k miles. Other than that, you would be looking at wear in the bore/rings which doesn't really cause them to go bang, they just go down on power.
Kye
PostPosted: 22:09 - 26 Dec 2004    Post subject: Reply with quote
I'm pretty sure its a new piston / rings every 8k on most 125cc strokers, and for the sake of a few hours labour, why risk your bike?
pipnet11
PostPosted: 00:53 - 27 Dec 2004    Post subject: Reply with quote
Shocked A good enough reason not to buy one!!
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
binge
Emo Kiddy
PostPosted: 16:53 - 27 Dec 2004    Post subject: Reply with quote
What about on a 70cc (tuned) scooter... When should I replace my piston ring...
Ive done about 600 miles on it now (since the rebuild)...
<|Binge|>
DM
PostPosted: 17:39 - 27 Dec 2004    Post subject: Reply with quote
Once you've done it a few times then the procedure only takes 1 1/2 rs or so. Also gives you an opportunity to check the condition of your conrod bearings, polish your ports and the like. Riding your bike afterwards and enjoying the renewed crispness is incredibly satisfying Smile. Mind you, some bikes and scooters have the engine tucked away pretty well and you'll be spending a lot of time cursing at the horrible placement of bolts and wondering what the engineers were thinking Confused!.
Kye
PostPosted: 18:40 - 27 Dec 2004    Post subject: Reply with quote
<|Binge|>
My old 70 did around 4.5k to a piston, that was totally thrashing it and not letting it warm up etc, but running on fully synthetic oil still.
600 miles is nothing, even the 24bhp race 70cc's do about 1000 miles to a piston (although most people change at 500 to be on the safe side)
cagiva gezzer
PostPosted: 18:47 - 27 Dec 2004    Post subject: Reply with quote
Any strange noises such as rattles indicate that something is getting worn and needs changing. Worn top ends also have poor starting, if changing the plug doesn't improve the starting its prob something to do with the rings/piston.
However, if you don't know what a good engine sounds and feels like, you're shafted as you've got nothing to compare it to.
I'm the sort of person who likes to stip engines and check everything. I've been the person who says "umm, sounds strange, i'll sort it next week..." and it cost me too much $$$.
As said, once you know what your upto its only 2hours max for a topend and less than a day for a full rebuild.
And yes, that nice crisp feeling is wonderful! Thumbs Up
PostPosted: 18:54 - 27 Dec 2004    Post subject: Reply with quote
Well my 350YPVS did 16k miles before it needed a rebore and that was tuned (professionally) off its nuts. It is essentially two 125s stuck together so I am not sure what they are doing to them these days if you only get 8k out of a piston and set of rings. Maybe a feature of plated barrells?
Git
PostPosted: 08:38 - 29 Dec 2004    Post subject: Reply with quote
You know when you need a rebuild when.
Arrow The bike just dies and sounds like a wet fart
Arrow You have an awesome firework display out the exhaust on motorway better than any carbon show
Arrow Little compression on starter
Arrow A scaffold pole has trouble moving the kick start
I got into the habit of changing the top every 10,000miles then at 30k new crank bearings and rods, never had a 2stroke let me down blow up wise, apart from my first lesson :mrgre
fuzz
PostPosted: 20:25 - 29 Dec 2004    Post subject: Reply with quote
The MOT needs renewing in a few months so I'll get them to do it first. It'll probably in the 11k-12k region by then, and they're less likely to find minor faults if I give them some work too. Cheers Thumbs Up
PostPosted: 11:37 - 30 Dec 2004    Post subject: Reply with quote
The NSR seems quite good on piston rings. The exhaust port has a bridge across the middle of it which will do a good job of supporting the rings and reducing wear. As such I would just do a compresson check and see if it is withing spec (142psi give or take 28psi).
Everything else I would just tend to wait until there is a problem (the whine of main bearings or the knock of the big end bearing).
The last post was made 21 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 15 - Page Size: 74.35 Kb
