| koolio |
 koolio Spanner Monkey
| Az |
 Az World Chat Champion
 Posted: 04:17 - 02 Jan 2014 Post subject: |
According to this site the 10w40 has been discontinued, maybe the whole Shell SX4 line has been discontinued?
Edit: The only weight I found (15w20) for Shell SX4 was being sold by a company that specialises in oil and probably has old stock still lying around.
I still think the line is most likely discontinued, especially as shell don't list it on their own site anymore under the motorcycle oils they provide. |
| _Iain_ |
 _Iain_ Banned
 Posted: 09:50 - 02 Jan 2014 Post subject: |
What bike is it going in out of interest? ____________________ Please be aware that the above post may be full of complete nonsense.
| Robby |
 Robby Dirty Old Man
| koolio |
| P.addy |
 P.addy Red Rocket
| koolio |
| _Iain_ |
 _Iain_ Banned
 Posted: 17:40 - 02 Jan 2014 Post subject: |
You do realise getting the grade right is significantly more important than the brand of oil if you're worried about engine lifespan?  ____________________ Please be aware that the above post may be full of complete nonsense.
| Walloper |
 Walloper Super Spammer
 Posted: 17:45 - 02 Jan 2014 Post subject: |
| garth |
 garth World Chat Champion
| Northern Monkey |
 Northern Monkey World Chat Champion
| koolio |
| Walloper |
| koolio |
| Walloper |
| koolio |
| Kickstart |
 Kickstart The Oracle
| koolio |
| _Iain_ |
 _Iain_ Banned
 Posted: 00:57 - 03 Jan 2014 Post subject: |
Expensive fancy car oil is bad.
The cheapest, unbranded nasty shit wont do any harm. ____________________ Please be aware that the above post may be full of complete nonsense.
| Kickstart |
 Posted: 01:03 - 03 Jan 2014 Post subject: |
| koolio wrote: |
Well clearly not, because I've had clutch issues with the two bikes I've bought where both PO's thought it would be clever to dump cheap car oil in and then call it a "service" rather than a bloody headache. Motorcycle specific oils have existed and been used from the 60s for a purpose, that and oil in those days did not have the "energy conserving" additives we do today, which is what causes the clutch issue in bikes. |
It is only pretty recently that makers have specified bike specific oils, with many older (1990s and older) bikes just listing an basic SE or the like spec oil, let alone a 1970s XS650.
While some modern car oils do have friction modifiers (many don't, certainly not with the low spec mineral oil that you will likely get if you buy 15W40), if these are going to cause a problem it is with the clutch slipping rather than failing to disengage. Clutches not disengaging can happen with wet clutches, irrespective of the oil used. Probably more likely from a bike just left standing for quite a while(had it with my TZR250 a few weeks ago which hadn't been used for a while - with a bike oil).
If you want to use a motorcycle specific oil then that is up to you, but I would very much doubt any of the problems you have experienced are related to the use of car oil.
| koolio |
| P.addy |
 P.addy Red Rocket
 Posted: 00:02 - 04 Jan 2014 Post subject: |
LOL.
Any frigging mineral gash oil will be fine.
I've never used anything and I mean ANYTHING but 10w40 Morrisons or Tesco oil in ANY of my bikes, the exception is when either my dad or a shop had done it.
Have I ever had an issue with a clutch, nope.
Just bang some asda basic in there and stop crying about some bike thats older than the dinosaurs.  |
| Kickstart |
 Posted: 00:26 - 04 Jan 2014 Post subject: |
| koolio wrote: |
Sorry but in my experience this is flat out wrong, on my XS650 the clutch was not disengaging because the cheap mineral car oil literally stuck the clutch plates together, this was the case cold and improved slightly hot.
Plenty of people having the same problems on XS650 when they decide to stick cheap mineral car oil in, cured by putting motorcycle specific oil in.
As far as I know you can get away with using diesel engine oil in an older bike.
Even cheap car oils today have friction modifiers owing to emission standards, EPA etc. etc. that were not around decades ago. |
I very much doubt it is the use of car oil that causes an issue, and nothing new enough to care about EPA fuel economy rules (and hence the friction modifiers) is going to be using an ancient 15W40 spec oil (which are incredibly unlikely to be marked as energy conserving oils, which are the ones to avoid ), and a friction modifier is not going to stop a clutch disengaging (quite the opposite). Yamaha just give the option of a SAE 20W40 SE spec oil (ie, conventional low spec car oil).
Diesel oil is usable in many engines. Difference is just that diesel oils tend to have a higher detergent content to cope with the larger amount of rubbish generated in a diesel engine. One reason some use them as a flushing oil.
I have used car oil in many bikes with wet clutches and without having any issues. I have had a few bikes where the clutches have stuck when parked up for ages (early Aprilia AF1s would do it pretty much every morning, start engine, into gear and stall, then retry while holding the brakes and revving the engine and it would free off and then be fine afterwards), but none of these were one that had been using car oil.
Using the wrong weight engine oil is probably more likely to cause an issue (the Freccia we have specifies a 15W50 oil for the gearbox and using a 10W40 does tend to make it stick more when first started).
But ass said, feel free to use a bike oil. Not sure there really is a best as I doubt oil failure is common enough to be a major problem compared to most other factors. On an old bike with fairly wide clearances and a basic oil pump and filter system you are probably just best off changing the oil and filter regularly to remove the deposits floating in the oil.
| koolio |
 Posted: 10:08 - 04 Jan 2014 Post subject: |
| Quote: | I very much doubt it is the use of car oil that causes an issue, and nothing new enough to care about EPA fuel economy rules (and hence the friction modifiers) is going to be using an ancient 15W40 spec oil (which are incredibly unlikely to be marked as energy conserving oils, which are the ones to avoid ), and a friction modifier is not going to stop a clutch disengaging (quite the opposite). Yamaha just give the option of a SAE 20W40 SE spec oil (ie, conventional low spec car oil). |
I've bought several old bikes, of the two which had brand new car oil they both suffered from nearly identical clutch problems, I repeat totally cured by cleaning the plates and putting the correct motorcycle oil in. Note that cleaning the plates and putting the same car oil back in produced the same problem!
| Quote: |
Diesel oil is usable in many engines. Difference is just that diesel oils tend to have a higher detergent content to cope with the larger amount of rubbish generated in a diesel engine. One reason some use them as a flushing oil. |
Correct, but there are a host of owners using this stuff for years on XS650s, some people also race on diesel oil in the states.
| Quote: | On an old bike with fairly wide clearances and a basic oil pump and filter system you are probably just best off changing the oil and filter regularly to remove the deposits floating in the oil. |
Of course..
| Quote: | LOL.
Just bang some asda basic in there and stop crying about some bike thats older than the dinosaurs. Laughing |
Incorrect in my experience.
You can at best get away with using car oil imo. |
| P.addy |
 P.addy Red Rocket
The last post was made 12 years, 297 days ago. Instead of replying here, would creating a new thread be more useful? |
