sachs x road 125 Oil leak..
ross_1992
PostPosted: 08:37 - 02 Jan 2014    Post subject: sachs x road 125 Oil leak.. Reply with quote
Hi,
I currently own a sachs x road 125. Its mint and runs perfect but when on the stand it leaks from the clutch case..
Does anyone know what this will most likely be? and how much it will cost to fix permanently. It does not effect riding but its an issue i would like to solve.
Many Thanks
-Ross
PostPosted: 08:41 - 02 Jan 2014    Post subject: Reply with quote
Replace the gasket? Probably £5-10 and then about 20 minutes of your time.
ross_1992
PostPosted: 08:50 - 02 Jan 2014    Post subject: Reply with quote
Oh so its only a small job? cheers for your reply any how.
So is any leak on a bike expensive?
PostPosted: 08:57 - 02 Jan 2014    Post subject: Reply with quote
One from the sump can be a pain as it means you need to remove it, if its even removable.
Head gasket too, fuck that. But no, if your one is leaking a little from between 2 surfaces and one is removable, usually its a piece of cake.
ross_1992
PostPosted: 09:10 - 02 Jan 2014    Post subject: Reply with quote
What would you say is a better 125 out of the sachs-x 125 and the pulse adreniline 125?
PostPosted: 09:14 - 02 Jan 2014    Post subject: Reply with quote
Never ridden either, but I'd prefer the Sachs.
ross_1992
PostPosted: 09:29 - 02 Jan 2014    Post subject: Reply with quote
Whats the reason behind prefering sachs? the design?
PostPosted: 09:55 - 02 Jan 2014    Post subject: Reply with quote
The lack of Chinese.
Chinese bikes aren't too good. The Sachs are above them, but not as high up as the japanese bikes.
The last post was made 12 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 53.19 Kb
