Bolted Ground Anchors
-Matt-
PostPosted: 16:13 - 02 Jan 2014    Post subject: Bolted Ground Anchors Reply with quote
Anyone had experience using these. I've only ever used concreted in ones in the past but won't be able to here, so its a bolt down one or nothing Neutral
It uses expanding bolts with bearing to prevent drilling to attach to the ground, but it seems like it might be quite easily to rip up with a crowbar or something perhaps Question
https://www.pedparts.co.uk/c/products/RAW/mammoth-ground-anchor-sold-secure-gold-1489-p.jpg
PostPosted: 16:22 - 02 Jan 2014    Post subject: Reply with quote
What I'm doing when I get the house I'm looking at with a garage is getting 5 or 6 D locks and sinking 3 of them close together to make 1 big ring concreted in. Then do a 2nd on the other side Laughing 2 ground anchors.
Those ones, I'd expect a drill to bust the bolts.
-Matt-
PostPosted: 16:28 - 02 Jan 2014    Post subject: Reply with quote
Landlord won't allowing any digging of holes or concreting Evil or Very Mad
Will be ironic if this thing gets ripped up and damages the floor Rolling Eyes
Bubblin77
PostPosted: 16:38 - 02 Jan 2014    Post subject: Reply with quote
The trouble with all this security, ground bolts etc is the thieves will likely damage your bike trying to get then unlocked, bikes dropped, steering columns damaged, I'd personally prefer it if they just nick it and then never see it again.
I know you will have the hassle of insurance etc etc, but also don't want the hassle of having to fix my bike.
I know they can deter some thieves just by looking, so that may be worth a little.
Kawasaki Z800 (SOLD)
-Matt-
PostPosted: 16:44 - 02 Jan 2014    Post subject: Reply with quote
Yeah it is a bit of the gamble either way unfortunantely. If it was a cheaper bike i'd leave it be, its just the amount a claim for this [which i would have to claim on] will rocket up my insurance for the next few years will be quite severe I think. So i'd rather a slightly damaged, hopefully useable bike, than no bike/claims at the moment.
If I was living in the USA i'd just rig up some shotguns to the door Thinking but sadly I don't
Ol
PostPosted: 16:50 - 02 Jan 2014    Post subject: Reply with quote
i had a bolt down anchor a few years back used some massive rawl bolts / anchors with snap off nuts on the end (like below) the hex ends snap off at a set torque leaving just the dome'd end on so they cant be undone - seemed secure enough, and was an utter cnut to take out when i moved house so i think it would have stood up well if anyone tried to get it out
https://www.fhbrundle.co.uk/thumbs/thumbs9/180_180_ffffff_L1BhbmVzLzIzMDJTUC5qcGc-01/titled/galvanised-shear-nuts.jpg
-Matt-
PostPosted: 16:56 - 02 Jan 2014    Post subject: Reply with quote
How did you manage to remove it out of interest Laughing Landlords happy for a small bolt in one to be left for future tenants/owners luckily, so I should save myself some trouble there. Just doesn't want any digging or concreteing done in case it cracks the floor/ garage wall its being placed alongside Thumbs Down
PostPosted: 17:06 - 02 Jan 2014    Post subject: Reply with quote
For us that only have TPO insurance because anything else is a royal rip off and bound by billions of rules tighter than a nuns fufu, I'd rather they didn't nick it in the first place.
Landlord should be worried about the fact it might get dug out when they realise the bolts are stuck firm rather than being a fairly large sunken piece of hardened metal that won't get pulled up, ever Laughing
-Matt-
PostPosted: 17:23 - 02 Jan 2014    Post subject: Reply with quote
I think hes under the impression the garage won't ever be targetted and therefore its just me being paranoid installing the thing in the first place Laughing
He sees it as a benefit for selling/renting it out in the future though, so is happy to have it put in regardless Rolling Eyes
FergieinFranc...
PostPosted: 17:34 - 02 Jan 2014    Post subject: Reply with quote
Few years ago a bloke did just that in either Norfolk or Suffolk can't remerber which, out in the sticks anyway.
He had his bike stolen, ( H.D. I think ) he replaced it, got that nicked, replaced it again, this time he rigged a 12 gauge up to the shed door, scumbag goes back for the third time and gets his bollocks blown off.
I remember it being in MCN and the tabloids, it went to court and l think he got away with a suspended sentence.
Maybe one day we'll be allowed to protect our possessions in anway we think fit...chains, padlocks, 12 bore....
Prendre garde au temps entre le chien et le loup
You don't scare me....I've got a daughter...
PostPosted: 17:45 - 02 Jan 2014    Post subject: Reply with quote
Into solid concrete with four, M8 rowl bolts? Put it this way, If they came in a van and tried to pull your ground anchor up, you'd find the back axle of a van attached to it next morning.
-Matt-
PostPosted: 17:46 - 02 Jan 2014    Post subject: Reply with quote
Cheers, sounds adequate Shocked
andym
PostPosted: 18:37 - 02 Jan 2014    Post subject: Reply with quote
I just got one of the bars off a fence panel from the local scrappy, bent a U shape in the middle of it and cut a couple of notches out of a slab and put it under there.
Mind you, I've probably used it twice in almost a year, and it would only need a gentle tug to remove that and the slab..... but I only intended it to be a visual deterrent anyway
Northern Monkey
PostPosted: 19:18 - 02 Jan 2014    Post subject: Reply with quote
I've got the smaller 2 bolt version in my garage. The bolts pull the anchor in towards the concrete as you tighten them, no way you can get a crow bar under them.
The quickest and easiest way to break one would be to use a grinder to cut through it. I don't think you could pull it away from the ground, it's totally solid.
If you are feeling paranoid, go for this one. It's sold secure rated for caravans, which is a higher level than bikes, and it's only a tenner more than the one you linked to
https://securityforbikes.com/proddetail.php?prod=TorcAnchor
make sure you use a good 16mm chain with a ground anchor. They are effective as a visual deterrent, as well as being difficult to cut
chickenstrip
PostPosted: 19:25 - 02 Jan 2014    Post subject: Reply with quote
Large heavy duty plant pot, fill with concrete/post ballast with U-lock or hoop of steel/whatever suitable thing you can find down the local scrappies poking out the top. Pretty flowers on top Laughing
Benjums
PostPosted: 19:29 - 02 Jan 2014    Post subject: Reply with quote
The other thing you can do is drill the holes and then put some concrete resin in the hole and push the bolt into that, you will never get the thing undone again though unless you grind the top of the bolts off. With the resin you stand more chance of pulling the floor up than just getting the bolts up. It's quite expensive though but compared to the bike and insurance it's nothing, just pop into your local builders merchants they should have some.
Northern Monkey
PostPosted: 19:46 - 02 Jan 2014    Post subject: Reply with quote
Because there is no way that a couple of people and a van could move a plant pot full of concrete Rolling Eyes
Walloper
PostPosted: 20:21 - 02 Jan 2014    Post subject: Re: Bolted Ground Anchors Reply with quote
The rock-bolts will hold tons of force. If fitted to 'sound' material. If it is shitty home-made concrete then they may not be as secure. Professionally mixed concrete which has been laid up to spec will be fine. There is concrete and there is concrete. Very Happy
Anyone who comes prepared to dig one of them out would love to find a bike without security.
I don't know what the reasoning is behind not securing for fear of damage. Shocked
pepperami
PostPosted: 20:22 - 02 Jan 2014    Post subject: Reply with quote
large plant-pot full of concrete chained to a relatively heavy bike = quiet an awkward thing to move and would cause them a lot of trouble/time = just what they don't need.
If bike thieves want your bike they`ll get it, but you can make it as hard as possible for them and make the security very visible to act as a deterrent.
binge
Emo Kiddy
PostPosted: 20:56 - 02 Jan 2014    Post subject: Reply with quote
My friend Aimee came and fitted my ground anchor (Civil engineer - Lovely girl).
Drilled a 20mm hole, about 200mm deep.
Filled it with some squirt in resin stuff (Two tubes, which come out of 1 nozzle)
Then pushed in this Hench threaded eyelet thing, screwed it around about 10 times, to fill all the threads in with resin.
Next morning, I am left with a 100mm dia, steel loop sticking up out of my garage floor, which aint coming back out easily.
Granted, an angle grinder would go through it eventually, so it can be 'removed'.
But in the event of theft, you'd get through the chains quicker than the anchor, so it's as tough as it needs to be.
My tool box is the most valuable thing in my garage (About £15k all in), so that's anchored down.
And then my angle grinder, is locked away INSIDE the tool box, for obvious reasons. Laughing
-Matt-
I was actually thinking more of the jamming a bar in the opening the chain loops through and prying it that way, but it sounds like theyre pretty immovable once installed properly in a good base so no worries there Smile
Will look into the resin havent heard of that before, thanks Benjums, and everyone elses suggestions Thumbs Up
chickenstrip
PostPosted: 21:13 - 02 Jan 2014    Post subject: Reply with quote
Saw it before you edited it Wink Laughing
Actually, it's not something I've tried myself, but have heard it suggested a couple of times. It's a possible alternative, for example, if you're lodging somewhere that you're not allowed to drill etc. Of course I'm aware that it won't suit everyone's circumstances, but may be of use to some. And I am of course talking about the kind of pot you maybe plant a small tree or large shrub in - not the pot from your kitchen window-sill!
It is only another way of making theft of a bike harder. I've heard of one case where the thieves went THROUGH a guy's brick wall to get his bike (others may have heard or witnessed even more extreme examples) - if they're that determined, nothing short of shooting will stop 'em.
Benjums
PostPosted: 21:25 - 02 Jan 2014    Post subject: Reply with quote
No problems mate, it's the same stuff binge is on about. Good luck with it, one piece of advice though if you use the resin wait until you have drilled all four holes and then use it, otherwise it will go off in the tube and you will be screwed.
PostPosted: 22:54 - 02 Jan 2014    Post subject: Reply with quote
There was someone on here years ago who locked their brand new, unridden bike to two ground anchors in a locked brick shed with a barred and bolted steel door.
They dismantled the entire thing, passed it all out through a 2ft x 2ft window and carried it away across a field. He was left with two wheels chained to ground anchors and a mass of fasteners scattered across the shed floor.
-Matt-
PostPosted: 22:57 - 02 Jan 2014    Post subject: Reply with quote
Can't help but laugh at that Laughing
Short of using land-mines and firearms nothings safe it seems. I would like to think my bikes not desirable enough to attract that much effort.
Did he have an alarm anywhere on the shed out of interest - i'd imagine thats one of the few situation you really would benefit from having some warning whats going on Shocked Seems silly to goto that level of protection without some warning device to alert you whats going on, must of taken at least a bit of time to dismantle all that!
The last post was made 12 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 135.76 Kb
