| MattWadz |
 MattWadz Trackday Trickster
 Posted: 21:51 - 02 Jan 2014 Post subject: Suzuki TSR125 very odd running problem |
Posting for a friend :
Suzuki TSR125 L reg
2 stroke
Liquid Cooled
6 speed
E/powervalves
the bike is a tsr125, on an L plate, just had a new piston kit but was still running crap before this. the bike is quite hard to start, and usually needs to have the throttle kept open a bit to start, once it does start the revs dont seem very responsive, it seems to rev a bit to slow and isnt 'crisp' as it should be?
Carb has been cleaned and inspected meticulously twice, reeds and reed block is fine, all gaskets are good, oil pump is working fine.
the carb settings are :
Needle : Middle slot (c clip)
mixture screw : 2 1/2 turns out
idle : wound all the way in and it still barely idles
Main jet is standard along with all the other jets, exhaust is also standard.
the bike will start more easily if the throttle needle is on the bottom notch allowing more fuel in, but still runs badly. tried various plugs all new and still no fix.
the bike has been fiddled with by some sort of 'chav' before and ive noticed that the intake manifold rubber has two pipe nipples coming out next to each other facing upwards, they both lead directly into the intake rubber but someone has cut a pipe and joined them together using the same pipe, if this is unplugged when the engine is running it automatically revs its bollocks off due to the increase of air.
anyone have any ideas?
Could this be a timing issue?
Thanks for reading my essay!
 ____________________ Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R |
| P.addy |
 P.addy Red Rocket
| MattWadz |
| MattWadz |
| misscrabstick |
 misscrabstick Crazy Courier
| misscrabstick |
| bladerunner |
 bladerunner World Chat Champion
| MattWadz |
 Posted: 00:14 - 03 Jan 2014 Post subject: |
So that pipe should be longer than t is ? It has been shortened because its kinked! Will make it leaner tomorrow and reply back
Thanks all!
| bladerunner |
| misscrabstick |
| evoboy |
 evoboy World Chat Champion
 Posted: 01:48 - 03 Jan 2014 Post subject: |
Is the exhaust coked up? Is the float height correct?
Have you checked the crank seals? Its been apart before so they may not have been installed correctly?
It does sound lean. Does it run any different on choke? ____________________ Suzuki GT250 x7------- Fazer 600------CB250RS------Aprilia Rally 70----- Bandit 600
APT Motorcycles |
| bladerunner |
The last post was made 12 years, 322 days ago. Instead of replying here, would creating a new thread be more useful? |
