Suzuki AY50 Katana 2005 what sparkplug to use?
jayjaymozza
PostPosted: 11:15 - 03 Jan 2014    Post subject: Suzuki AY50 Katana 2005 what sparkplug to use? Reply with quote
Hi, I took my head off my scooter today as I've been having problems and noticed the spark plug that is in it seems short. The plug is a NGK C7HSA. I phoned my local motorcycle garage up and they said I need a CPR8E plug.
PostPosted: 11:52 - 03 Jan 2014    Post subject: Reply with quote
If its the AY50-A so 05 onwards you need a CPR8E.
If its the AY50-W K4 so <05 you want the BPR6HS.
Oh, and you want to make sure you get the right one.. one is a bit longer than the other and one is wider.
jayjaymozza
PostPosted: 11:56 - 03 Jan 2014    Post subject: Reply with quote
Thankyou
jayjaymozza
PostPosted: 12:21 - 03 Jan 2014    Post subject: Reply with quote
So the scooter has had the wrong plug in it all the time I've had it ... Could this be causing my problems ?
PostPosted: 12:48 - 03 Jan 2014    Post subject: Reply with quote
Yes. Check your plug though as one is thicker than the other.
jayjaymozza
PostPosted: 13:11 - 03 Jan 2014    Post subject: Reply with quote
Can someone send me a picture of how the sparkplug should sit in the head? I need a picture from the inside. Thanks
PostPosted: 13:58 - 03 Jan 2014    Post subject: Reply with quote
Would depend on model, year, exact engine...
Check if yours is a 04 or less or an 05 onwards using the VIN plate. Basically, buy both plugs, only 1 will fit. One is 10mm one is 14mm, measure yours and then go for that size plug in the models listed at the top of this page Thumbs Up
Fuck it, edit - CPR8E is the one you want given the spec of your old plug.
The last post was made 12 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 50.35 Kb
