R1 caliper query
Banger
PostPosted: 19:50 - 03 Jan 2014    Post subject: R1 caliper query Reply with quote
I am hoping to swap the blue spot calipers on my 5JJ r1 with some gold spots from the later 5PW model.
Can anyone confirm these are a straight swap plz ?
Have tried hunting through google and using the search option on here.
Brick Wall
Cheers. Thumbs Up
You only get one lap of lifes track . . . . so make it a fast one !
Yamaha . . Keyboards to biking nirvana.
PostPosted: 19:52 - 03 Jan 2014    Post subject: Reply with quote
Same, diff colour.
Banger
PostPosted: 19:54 - 03 Jan 2014    Post subject: Reply with quote
Straight fit then. . . . Sweet.
The improved pots in the 5PW calipers are the draw . . that and I found some cheap. lol.
Thanks Paddy. Karma
PostPosted: 19:56 - 03 Jan 2014    Post subject: Reply with quote
They made no change other than to swap from SS to alloy in the pistons. You won't notice a difference at all, that and you'll need to flip your brake line 90 degrees Thumbs Up
Thanks Paddy. Karma
What's the difference in the piston design?
Just out of interest?
Banger
PostPosted: 19:59 - 03 Jan 2014    Post subject: Reply with quote
As Paddy says above. Different material used for the pots.
The Golds are generally rated as better calipers for this reason.
If I'm honest I just fancy a change, and it will mean I can swap the blue spots I have on it already with the ones on my T, cat that are in need of serious refurb.
PostPosted: 20:00 - 03 Jan 2014    Post subject: Reply with quote
I toyed with the idea on my old R1 as it was black/gold and the only reason I didn't spend £££ is because its something I wouldn't notice you know. Forks and brakes from a later model maybe, but not the calipers Thumbs Up
Only real calipers I've liked and would swap to are the Nissins from the 600RR I had, ballistic braking power.
PostPosted: 20:01 - 03 Jan 2014    Post subject: Reply with quote
Fair.
Consider ISR 6 pistons for maximum fappage. Cool
The last post was made 12 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 55.11 Kb
