Chain and sprocket
darkhorizon
PostPosted: 13:52 - 04 Jan 2014    Post subject: Chain and sprocket Reply with quote
Do I buy OEM Honda or an 'uprated' spec kit? 2009 CBF600...
2009 CBF600 - London hack - stolen then recovered - still going!
2006 CG125 - Was SORN'd, now back on road - sold Nov '16
Musketeer
PostPosted: 15:48 - 04 Jan 2014    Post subject: Reply with quote
Original new Honda parts will be very likely more expensive than lighter/uprated Renthal sprockets and some decent chain.
Fizzer Thou
PostPosted: 17:17 - 04 Jan 2014    Post subject: Reply with quote
Agree with Renthal for the front sprocket and DID chain
https://www.bandcexpress.co.uk/shop/transmission/chains.htm
But for everyday use I have been suggesting SuperSprox rear for a few years
https://www.supersprox.com/eshop/
Always have a 'Plan B'
darkhorizon
PostPosted: 18:29 - 04 Jan 2014    Post subject: Reply with quote
What 'bout the rear sprocket? Or do they come in the DID kit?
martyn107
PostPosted: 21:44 - 04 Jan 2014    Post subject: Reply with quote
https://www.mandp.co.uk/productinfo/595969/Chains-and-Sprockets/Chain-and-Sprocket-Kits/DID
Any good?
darkhorizon
PostPosted: 20:10 - 07 Jan 2014    Post subject: Reply with quote
i'll let you know if I shred it... Cool
PostPosted: 20:20 - 07 Jan 2014    Post subject: Reply with quote
Not always the case.
For my 954 the OE kit is £135 (david silver spares), on bike HPS it comes out at £138. The BikeHPS kit uses an Ognibene (?) chain, and AFAM sprockets.
IIRC DID make the Honda chains, and the sprockets are from Honda. Not had an issue with a Honda OE C&S before, when I had my Honda 6 the OE C&S kit came out a fair bit cheaper as well.
I would also advise against using the Rental anodised alloy sprockets on the road. For race use where every gram matters, fair enough. On the road once you've worn through the anodising that's only a couple of microns thick, you'll munch the alloy underneath very quickly. Just go for some good quality steel sprockets IMO and before the grams.
Fizzer Thou
PostPosted: 23:03 - 07 Jan 2014    Post subject: Reply with quote
The SuperSprox rear sprocket was suggested as it has a hardened outer ring of steel teeth set onto an alloy carrier.Renthal do sell a version of the same type of sprocket as the SuperSprox,but it is a newish product and the SuperSprox is proven.
As for a Renthal alloy rear sprocket,I have had just such a sprocket on my R1 for over 25,000 miles now, and is showing little or no wear.The hard anodised finish does appear to be harder wearing than the clear finish that I have used on my KTM enduro racer for a few years,these lasting for around 4000 miles or so in all conditions.
AS for the chain - DID every time Thumbs Up
fatjames
PostPosted: 11:47 - 08 Jan 2014    Post subject: Reply with quote
I normally go for an X ring DID chain, any steel front sprocket and a renthal rear.
The frequency of your maintenance will be the thing that keeps them working for longer, which ever you buy.
I tend to get to get C+S from wemoto.
HTH
The last post was made 12 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 61.65 Kb
