Aprilia rs 125 Power Valve problem?
Leem123
PostPosted: 21:09 - 04 Jan 2014    Post subject: Aprilia rs 125 Power Valve problem? Reply with quote
Hello! I just recently bought a power valve blade, cable and housing. It's installed but I have a oribkem with it!]
It opens in first gear at 8k revs no problem. From 2nd gear onwards it won't open and I have to force it to go to 11k revs (I don't).
What could be the problem? I am thinking the Soleniod isn't strong enough to open it? :/
PostPosted: 21:48 - 04 Jan 2014    Post subject: Reply with quote
The bike shouldn't care about what gear it is in as far as the power valve goes. They can stick and fail to open, but I suspect you have cleaned it up thoroughly and I would normally expect that if it managed to open once it would manage it again immediately afterwards.
The valve control unit gets its rpm signal from one of the charging wires (ie, the AC wires from the stator to the regulator / rectifier unit).
Can you check if the valve is really not opening?
My guess would be that the valve is opening but is in place upside down, so not giving you full power (seen dealers do this, probably because the valve goes with the curve the opposite way up to the blanking plate).
Leem123
PostPosted: 21:53 - 04 Jan 2014    Post subject: Reply with quote
When I bought the bike the chamfered bit was facing up, but I read the manual and it said that the chamfered bit faces down (Curved bit down). It opens in first gear fine after second or third gear you have to rev it to 11k revs. I am sure you shouldn't have to do that as the Blade should open and let the fumes out and go straight to 11k revs.. Not sure though. How do you tell if its not really opening? as in first gear it opens fine? Goes from 8k to 11k really fast.
PostPosted: 22:16 - 04 Jan 2014    Post subject: Reply with quote
Sounds like you now have the valve the right way up (ie, the chamfered bit should be horizontal when in place).
The valve should open at just under 8000rpm. The power should pick up quickly at this point and it should rapidly rev to 11k. It only tries to open the valve for a short while (you will notice at night that the light dims a touch for a second or 2 while the valve tries to open, then brightens again whether the valve opened immediately or has still not opened)
If the valve is plane not opening you can check the cable while revving the engine hard while not moving (once the engine is warm).
As you use higher gears it will take longer to get from 8000rpm to 11000rpm (ie, in 1st that is from about 24mph to 40mph, in 2nd it is from about 35mph to 57mph). But it shouldn't instantly go from 8k to 11k (unless the clutch is slipping).
Leem123
PostPosted: 22:20 - 04 Jan 2014    Post subject: Reply with quote
It doesn't instantly go from 8k - 11k but I know it opens. I had it idle and reved it up to around 8k revs and you can see the solenoid pulling it open. Would the exhaust be full of crap? I haven't clean that yet nor have I looked at it. But the higher the gears I go the harder it takes to go to 11k revs. Maybe it's all clogged up?
Leem123
PostPosted: 22:22 - 04 Jan 2014    Post subject: Reply with quote
Also forgot to add that I don't have the proper Power Valve Gasket on it. I have High Temperature Gasket around it instead. It works for clutch casings ect.
PostPosted: 22:28 - 04 Jan 2014    Post subject: Reply with quote
Exhaust could be full of crap, but difficult to know and not the first thing I would suspect (and it it were that blocked up I suspect getting the valve blanking plate out would have been a hideously difficult job).
A leaking exhaust (including around the power valve gasket) might lose you a bit of power.
It is difficult to say much else. However the first thing to check with any RS125 is the compression.
Leem123
PostPosted: 22:30 - 04 Jan 2014    Post subject: Reply with quote
The new blade I bought was hard to fit in and had to push it in a few times to get it to move freely. Also just noticed that I am missing
the power valve shaft seal and o-ring, would that make much of a difference?
Number 5 and 6 on the diagram below.
https://www.pjme.co.uk/acatalog/Aprilia_Powervalve_Parts_.html#a2931#SID=772
PostPosted: 22:35 - 04 Jan 2014    Post subject: Reply with quote
I don't think those bits missing would result in an immediate problem.
However the blade must slide in and out pretty freely, and they will stick fairly rapidly. Might be worth whipping it out and giving it a thorough clean
Leem123
PostPosted: 22:39 - 04 Jan 2014    Post subject: Reply with quote
It moves freely now. I gave it a good clean but I don't understand why it would open in 1st gear easy and then 2nd gear+ not open? I will buy them bits along with the gasket when he has it in stock and see what happens. When I bought the bike the seal and o-ring were on it and the Power valve was fine, worked like a charm.
PostPosted: 22:43 - 04 Jan 2014    Post subject: Reply with quote
Need to confirm that it really doesn't open as you go up the gears.
Given it will probably take about twice as long to get from 8k to 11k in 2nd compared to 1st it could just be an illusion, possibly combined with power being a touch down.
Leem123
PostPosted: 22:45 - 04 Jan 2014    Post subject: Reply with quote
How will I test if it opens from 2nd gear onwards? Put it in second and hold the clutch on and rev it to around 8k revs and see if the solenoid can open it?
PostPosted: 22:47 - 04 Jan 2014    Post subject: Reply with quote
That would be the only way to do it, which could be a bit disastrous if you let go of the clutch. Any local dyno place you could run it up on?
Leem123
PostPosted: 22:52 - 04 Jan 2014    Post subject: Reply with quote
My dad has a dyno set I think. But I will buy the gasket, seal and o-ring before I do anything else and see how it goes. I will go out tomorrow and try it while in 2nd/3rd and see if the solenoid opens or not. And I will take it from there. Hopefully it's an easy fix. Smile
Leem123
PostPosted: 18:48 - 05 Jan 2014    Post subject: Reply with quote
I seen this posted on another thread, this is what I meant to say..
I have just put a power blade in my rs, however it didn't appear to be working as my rev range would stop at 8000. So i cleaned it out and i found my acceleration to be much better. However it did not increase the top end? How do i make my bike go faster top end as it currently can go about 80mph. Is it the exhaust?
That's exactly what's happening to me^
My bike did sieze a few months ago but I got a new piston and honed out the scrape that had been in my barrel. But around the same time the piston went my PV cable had broke so It was replaced and I got a blade and housing a few days ago to fix it fully.
PostPosted: 19:02 - 05 Jan 2014    Post subject: Reply with quote
The power valve working won't have much effect on low down power (depends on the blanking plates, early ones limited the bikes to 12hp and covered a bit more of the port - suspect you might gain 1~3hp at ~7500rpm fitting a power valve on those), where it will have a dramatic effect is after the power valve opens (above ~8000rpm).
Will the bike rev beyond 8k, even if making poor power, or does it refuse to go over that? Is the valve opening? Is it open at low revs (it should be open under 2500rpm)?
bikersupermot...
PostPosted: 19:10 - 05 Jan 2014    Post subject: Reply with quote
you Think?!?!?!
errrr - you would Know if he had a dyno - its a fkg huge contraption going deep down down into the garage floor, weighing tons and costing a huge amount of money!!!
its not something you ll find in his tool box!
example:-
https://www.google.com/search?hl=en&safe=active&biw=1243&bih=904&gbv=2&tbm=isch&sa=1&q=dynamometer&aq=f&aqi=g10&aql=&oq=#facrc=_&imgdii=_&imgrc=Hyr3ActgdQFXSM%3A%3BWv_bPhP1FuWF0M%3Bhttp%253A%252F%252Fwww.seriouswheels.com%252Fpics-2014%252Fklm%252F2014-mcchip-dkr-Mercedes-Benz-A45-AMG-Dynamometer-1-2560x1600.jpg%3Bhttp%253A%252F%252Fwww.seriouswheels.com%252F2014%252Fklm%252F2014-mcchip-dkr-Mercedes-Benz-A45-AMG-Dynamometer-1-2560x1600.html%3B2560%3B1600
tinybikes
Leem123
PostPosted: 19:54 - 05 Jan 2014    Post subject: Reply with quote
Ok! I just went out to the bike started it, let it warm up ect, the solenoid at default is down? when I rev to 2500 it goes up and stays like that untill the revs get to around 8000 once it hits 8000 revs or so the solenoid goes down untill the revs go to back to idle again.. Is that correct?
Leem123
PostPosted: 19:57 - 05 Jan 2014    Post subject: Reply with quote
it goes beyond 8k revs. Took it for a spin there too and sometimes when you hit 8k revs the bike goes to 11k quickly but there is no power? feels like there is a whole or something.. Might be because there isn't the proper gasket on it.
PostPosted: 20:03 - 05 Jan 2014    Post subject: Reply with quote
The valve should be open (so the solenoid should be pulling the cable to lift the valve) up to 2500rpm, then closed (solenoid relaxed, no tension on the cable) up to around 8000rpm (think 7750 on a standard RS125, but Aprilia used slightly different control units on different models to open the valve at slightly different rpm, and possible one of those is fitted - exact rpm is probably written on the control unit in white paint) when it opens again.
Reason it is open at low revs is so that when bimbling around town the valve gets regularly opened and closed, hopefully stopping it from getting stuck.
Leem123
PostPosted: 20:06 - 05 Jan 2014    Post subject: Reply with quote
So from what I have told you the solenoid and valve is working fine? Will I put it in second or so and rev to around 10k revs to see if the solenoid can keep the valve open up untill 10k revs?
PostPosted: 20:10 - 05 Jan 2014    Post subject: Reply with quote
It does sound like the valve is opening normally.
There is no reason I can think of that the valve would open in neutral and first, but not in 2nd (at least not on the older RS125s, not 100% certain with the last pointy shape ones but fairly sure they have no way to telling what gear they are in)
Leem123
PostPosted: 20:11 - 05 Jan 2014    Post subject: Reply with quote
Could it be the solenoid not keeping the valve open long enough?
PostPosted: 20:18 - 05 Jan 2014    Post subject: Reply with quote
Wouldn't think so. Although you have just made me think.
The solenoid allows more power to open the valve than it does to keep the valve open (as I described in more detail in an earlier post). I suppose it is technically possible that if the spring is stronger than standard it could open the valve initially but fail to allow enough power to keep it open.
However this should be obvious at idle.
Leem123
PostPosted: 20:26 - 05 Jan 2014    Post subject: Reply with quote
This stuff is confusing lol. I have bought the seal and o-ring for it. I will put that in when it comes, should be here during the week.. Also I have another question for you, when I sit in traffic for around 10-15 mins the bike heats away up and makes a crunching sound, once it happened I turned off the bike immediately and let it cool down. Once it had cooled down it was fine again. Would the crunching sound be the piston swelling up? :/
The last post was made 12 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.27 - MySQL Queries: 13 - Page Size: 143.74 Kb
