knocking sound from front brake caliper
dave666
PostPosted: 00:44 - 05 Jan 2014    Post subject: knocking sound from front brake caliper Reply with quote
So Basically i tried to ride away with my disc lock on lol...
since then i can hear a knocking from one of my front brake calipers where the disc lock has whacked. I've taken it off and it all looks fine, nothing warped and then put it back on securely.
but it's still making a knocking sound. I can forcefully move the caliper by hand (only a little) by grabbing it from the bottom of the caliper and moving it upwards so there is still some play in it which is obviously vibrating as i ride. whenever i squeeze the front brake the noise stops.
Is there anything obvious i should be looking it?
poleposition
PostPosted: 00:58 - 05 Jan 2014    Post subject: Reply with quote
sounds to me like you have distorted the disc somewhere, It may look perfectly round and true, but I bet it isnt.
If you can get the front wheel up in the air so you can spin it then use some crayon held firmly against the fork or caliper and just touching the disc you should be able to spin the wheel and see where it is distorted (unless you have a DTI gauge which is even better)
Ride it like you stole it!
bladerunner
PostPosted: 01:15 - 05 Jan 2014    Post subject: Reply with quote
What bike is it? Sliding calliper or fixed? Same with the disk. Is it floating or solid? Either way sounds like...warped disk,does the brake lever pulse when you brake or calliper/disk mounting bolts need inspecting or there should be a mark left at the point where the disk lock hit the calliper and disk end where the lock was attached. It might have left a high spot where it locked up.
Doubt it would have done loads of damage as you would have been doing max a couple of mph...but needs checking further.
dave666
PostPosted: 01:39 - 05 Jan 2014    Post subject: Reply with quote
It's a 2001 hornet. i'm not sure if it's fixed or floating. Lever doesn't pulse at all, braking feels as normal.
I'll have a look tomorrow in the day light
Snorty
PostPosted: 06:34 - 05 Jan 2014    Post subject: Reply with quote
Sounds a lot like a warped disc.
I did similar on a bike. The knocking will be the caliper moving from left to right as it travels with the warped part of the disc.
If you watch the caliper while you're riding along (if you can see it) you will see it going from left to right and vice versa.
dave666
PostPosted: 10:06 - 05 Jan 2014    Post subject: Reply with quote
Is it a cause of a new disc then or can it be repaired?
TheCatSatOnTh...
PostPosted: 11:04 - 05 Jan 2014    Post subject: Reply with quote
If it is warped, then there are people out there who can straighten it. I'm considering these guys for my warped disc but haven't had the chance to even speak to them yet.
The last post was made 12 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 51.83 Kb
