BMW K1200R 2007, dies when put in gear.
Freddles91
PostPosted: 20:32 - 05 Jan 2014    Post subject: BMW K1200R 2007, dies when put in gear. Reply with quote
Hi there, I'm having a small niggle with my BMW.
Basically it will start in Neutral, then when I put it in gear the engine dies like I just turned the ignition off, (yes the kick stand was up). It will start whilst in gear and behave fine but if I start it in Neutral then put it in gear it does not, once it dies that way it won't even turn over unless I turn the ignition off and on again.
My initial thought was a bit of a dodgy kickstand kill switch and the bolt holding the gear lever/kickstand bits on were quite loose so I tightened them up but to no avail.
Has anybody else had a similar issue with these bikes? Would it be the killswitch?
Cheers in advance.
stu_m
PostPosted: 20:45 - 05 Jan 2014    Post subject: Reply with quote
if the side stand switch was lose it might need adjusting
temeluchus
PostPosted: 22:30 - 05 Jan 2014    Post subject: Reply with quote
it will probably also have a clutch switch to look at.
Walloper
PostPosted: 22:40 - 05 Jan 2014    Post subject: Reply with quote
My R1200GS fell over one day. (it was on gravel).
When sat for about 10mins to let any oil return to the sump I found it wouldn't start.
It was in neutral but still not start.
I found it would only start when the clutch lever was pulled in.
The dealer told me the switch on the gearbox was faulty (over the phone) So ordered me a new switch. I fitted the new switch and all was fine.
Look for it here.
https://realoem.com/bmw/showparts.do?model=0538&mospid=51589&btnr=23_1160&hg=23&fg=05
It will be a cnut to get to. Sad
Islander
PostPosted: 22:54 - 05 Jan 2014    Post subject: Reply with quote
Neutral switch, clutch switch or sidestand switch. Thumbs Up
The last post was made 12 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 43.15 Kb
