Honda clutch casing bolts
Piercee100
PostPosted: 09:04 - 06 Jan 2014    Post subject: Honda clutch casing bolts Reply with quote
Hiya,
Been rebuilding my CD185 engine over Christmas and what I thought was going to be a quick job has turned into two weeks of blood sweat and tears.
Anyway, nearly finished but due to the seized side casing screws and heavy use of a good old fashioned impact driver I need some new screws / bolts for my side casings. Any idea where I can get them and what to look for?
A web search hasn't shown me much Confused
Rides: Honda H100a (Retired), VT500e (Sold), Kawasaki ZX400 (sold), Kawasaki GT550 (Sold), Suzuki Inazuma (Daily), Honda CD185t (Broken), LML Star 2t (Last run edition).
PostPosted: 09:42 - 06 Jan 2014    Post subject: Reply with quote
Various lengths of either M5 or M6 socket head capscrews.
If you have the originals still, you'll know what lengths you need. You can buy them in bags of 50 or 100 off screwfix or in bags of five for the same price on ebay.
Teflon-Mike
tl;dr
PostPosted: 13:36 - 06 Jan 2014    Post subject: Reply with quote
Arghmp!
CD185 you say?
WELL, the flange pattern is common accross the Benley series; BUT on the primary drive cover; first they ARE all M6 thread; but... there are variouse different lengths, as in three or four, depending on which position they go in, on which cover casting.
Bolts on the super-dream are different to on the 125T2 and again the CD200 6v.. THAT much I know.
On the Super-Dream, they are small hex, too; usual M6 are a 10mm AF hex; but the honda parts use a small 8mm AF flanged head, due to the clearances round the bosses. The CD200 had an assortment of whatever who-ever last put the thing on, while T2 seemed to have all Jap-X screw heads.
I tend to use standard allen heads; they have always fitted the cases I've had; and selected from assortment in the tubs; but I have had to grind a few to length.
Check CMSL... they some-times give the specs; else get a bit of long threaded rod, measure it; offer up the case, then screw it all the way in each hole and measure protruding, to get bolt length, then again without case to get required thread length (you dont really want more thread in the cast hole than you can get away with ideally)
I used to have a local iron monger who would sell by weight; so you told him how many of each bolt size you wanted and he'd pick them out the boxes than give a price on weight, as in a couple of quid, rather than 20/30p a bolt! Unfortunately they have closed down.. "Lack of Parkin' - evry 1 goes Screw-fix now, they 'av a car-park!"
Which is a real pitty; as screw-fix sell by the bag... and its 25 or 50 at a time, for £3-4 ish, which can get pricey if you only want one or two of each size!
In which case; you may want to check Dave Silvers Spares; they do the individual bolts, to Honda Pt-No, usually for probably 20/30p ish at a guess. Which for the dozen you want, could work out most economical still.
Best help I can give I'm afraid.
Piercee100
PostPosted: 14:12 - 06 Jan 2014    Post subject: Reply with quote
Actually that's not a bad idea. I do have the original bolts complete with mangled screw heads and I do have an old fashioned Iron monger near me (If as you say, he hasn't gone out of business) and I'll see if he can match them up to something.
Does it matter on the bolts used- high tensile or stainless?
Thanks Thumbs Up
The other Paul Rudd
PostPosted: 20:51 - 06 Jan 2014    Post subject: Reply with quote
High tensile bolts, no. Stainless, yes. Try and get zinc/nickel dipped or plated plain steel bolts, nickel plated would be better as that's probably what Honda used in the first place. I feel sure now I've said this the polymaths will be along soon to incorrectly rant about it for ten pages.
Teflon-Mike
tl;dr
PostPosted: 16:08 - 09 Jan 2014    Post subject: Reply with quote
Tensile.
Stainless is more brittle & if you have ever had to get a sheared one out of a blind hole you would NEVER stick a stainless steel screw into an ali casing. EVER!
Aff
PostPosted: 16:16 - 09 Jan 2014    Post subject: Reply with quote
Thanks Thumbs Up
If you post what spec bolts you need I'll see if I can get hold of them for you.
Electric Bike Project
DrSnoosnoo
PostPosted: 16:54 - 09 Jan 2014    Post subject: Reply with quote
Teflon-Mike wrote:
Tensile.
What happens?
LaurenceR46
PostPosted: 17:49 - 09 Jan 2014    Post subject: Reply with quote
I purchased some various sized bolts from ebay user kayfast1 for my R6 and they are great quality and work perfect. With a few washers the dimensions are the exact same as the Yamaha ones for a much better price and you got a load of spares.
Robby
Dirty Old Man
PostPosted: 18:25 - 09 Jan 2014    Post subject: Reply with quote
snoosnoo wrote:
Teflon-Mike wrote:
Tensile.
What happens?
You try to drill it out, the drill slips a lot, more hilarity ensues, and you buy a new crankcase.
DrSnoosnoo
PostPosted: 18:27 - 09 Jan 2014    Post subject: Reply with quote
I see! So what are the bolts made of in an ally case?
EDIT what I mean is, rather than stainless steel, what are tensile ones made from then?
Robby
Dirty Old Man
PostPosted: 18:58 - 09 Jan 2014    Post subject: Reply with quote
Mild steel, possibly with a zinc or cadmium coating for corrosion resistance.
Stainless is hard, brittle, and causes alloy to react (corrode more). Mild steel rusts, but gives you more warning before snapping and is easier to drill out.
DrSnoosnoo
PostPosted: 20:01 - 09 Jan 2014    Post subject: Reply with quote
I see, so could you not use stainless bolts with some copper grease? I am actually interested, not attempting to be a smart arse
Robby
Dirty Old Man
PostPosted: 21:37 - 09 Jan 2014    Post subject: Reply with quote
You could do that to try to get around the corrosion problems, but you're still stuck with it being too hard and brittle.
Also remember that even with copper grease, you're going to have metal on metal contact in places where the grease is scraped off by the threads.
DrSnoosnoo
PostPosted: 10:08 - 10 Jan 2014    Post subject: Reply with quote
Cheers for the info. I've been scouring screwfix and other places. I've read BZP .. is this a nickel/zinc coated thing? possibly better to use for ally cases?
Aff
PostPosted: 10:19 - 10 Jan 2014    Post subject: Reply with quote
BZP = Bright Zinc Plated
DrSnoosnoo
PostPosted: 11:54 - 10 Jan 2014    Post subject: Reply with quote
Learn something new every 2 days!
Piercee100
PostPosted: 20:32 - 10 Jan 2014    Post subject: Reply with quote
Update-
After finding bolts of the correct size from work (our workshops cut them to size for me) they're no bloody good! Can't get a socket or spanner over the head when placed in the casing's so had to buy genuine replacements cross head bolts from David Silver's came to over £11 with postage for 10 bolts, but atleast I know they'll fit!
Fubar 123
PostPosted: 20:56 - 10 Jan 2014    Post subject: Reply with quote
Would socket headed cap screws not fit ? BZP steel ?
The last post was made 12 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 106.24 Kb
