(Slightly) broken switchgear - MOT fail?
fox
PostPosted: 15:07 - 06 Jan 2014    Post subject: (Slightly) broken switchgear - MOT fail? Reply with quote
My WR is up for MOT this Friday.
The left hand switchgear, which controls the lights is missing the thumb control. There is a little rounded screw in its place, which doesn't affect the actual operation of turning on the lights at all.
Would anyone know if this is a potential MOT failure?
Sold: 2003 satin black Yamaha R6
Current rides: 2006 blue Triumph Sprint ST 1050, 2003 Yamaha WR450F
PostPosted: 15:19 - 06 Jan 2014    Post subject: Reply with quote
Nope, that is fine.
fatjames
Guessing here, I think it would be ok. If it works and doesn't have a sharp edge or anything I can#t see it being a problem.
Can you make it look better than just a screw using some black insulating tape?
WD Forte
PostPosted: 15:24 - 06 Jan 2014    Post subject: Reply with quote
I dont see why as long as its as easy and positive to use as it was when the button was on there.
If its fiddly to use, a tester may fail it under the operation clause.
bikers smell of wee
fox
PostPosted: 15:25 - 06 Jan 2014    Post subject: Reply with quote
Cheers guys, gives me some peace of mind Smile
I guess I could blob a bit of bluetac over the tip of the screw, although I'd say there are far more dangerous bits sticking out that come as standard!
fox
PostPosted: 15:29 - 06 Jan 2014    Post subject: Reply with quote
I can still operate it fine even with thick winter gloves on, so unless I catch my tester on a really bad day, then hopefully he won't try and fail it for that!
Is it down to the discretion of the tester as to what he feels to be dangerous/ could cause injury?
WD Forte
Blu tack?
noooooo !
A blob of Fast setting epoxy over the screw head and touch it up after with a black marker pen will do ya Laughing
bikers smell of wee
fox
PostPosted: 15:31 - 06 Jan 2014    Post subject: Reply with quote
WD Forte wrote:
Blu tack?
noooooo !
Touche!
Good thinking batman! To the hardware shop I go Laughing
PostPosted: 15:38 - 06 Jan 2014    Post subject: Reply with quote
It only has to work and not be loose. As long as you can operate it with no issues, you should be all gravy.
Worst comes to worst, tape lights and everything switch gear related up Laughing
fox
PostPosted: 15:48 - 06 Jan 2014    Post subject: Reply with quote
The duck tape will already be out in force Laughing
mrdelmonti
PostPosted: 16:00 - 06 Jan 2014    Post subject: Reply with quote
Along the same lines, my starter button fell apart so I now have a small shaped piece of metal i put in the hole cable tied to the bars, any idea if that'll be a fail?
I'll replace it at some point Laughing
PostPosted: 16:04 - 06 Jan 2014    Post subject: Reply with quote
Is it insecure?
mrdelmonti
PostPosted: 16:09 - 06 Jan 2014    Post subject: Reply with quote
Well the metal I put in is cable tied and what is remaining of the switch is still in the original plastic housing so yeah its pretty secure.
PostPosted: 16:14 - 06 Jan 2014    Post subject: Reply with quote
Then an MOT place shouldn't give a hoot.
mrdelmonti
PostPosted: 16:16 - 06 Jan 2014    Post subject: Reply with quote
Good stuff, cheers Paddy "the god of bodge"
PostPosted: 16:18 - 06 Jan 2014    Post subject: Reply with quote
Laughing It works, don't it Wink
mentalboy
PostPosted: 16:19 - 06 Jan 2014    Post subject: Reply with quote
Paddy. wrote:
Nope, that is fine.
/thread
Make mine a Corona.
The last post was made 12 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 89.69 Kb
