Rear brakes binding (appears to have fixed itself)
Fizzer Thou
PostPosted: 23:24 - 06 Jan 2014    Post subject: Reply with quote
The rear drum brake is normally a single leading shoe,so you should be able to rotate the back wheel backwards and it should free the brake off.But it would not take long to remove the back wheel,remove the shoe mounting plate and to clean out any accumulated brake dust and to remove,clean and grease the cam shaft where it goes through the backplate - after cleaning it of course.
Always have a 'Plan B'
1cyl
PostPosted: 23:27 - 06 Jan 2014    Post subject: Reply with quote
I once had a lever travel/play bolt wind itself out on me a bit. (if you have one that is?).
I soon found my rear disc to be a burning ring of fire!
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Fizzer Thou
PostPosted: 23:43 - 07 Jan 2014    Post subject: Reply with quote
It may well be that the brake linings are fine.But if the cam pivot shaft is dirty and corroded,it can easily keep the brake applied.The only way to check is to have it apart,which is an easy procedure.
Fizzer Thou
PostPosted: 23:53 - 10 Jan 2014    Post subject: Reply with quote
If you have not sorted out the back brake yet then yes,it is quite likely that the clutch friction material is worn.No other way to find out other than having the cover off and inspecting the plate thickness.
The last post was made 12 years, 278 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 67.05 Kb
