Bogging down at higher RPM and backfiring
treeno
PostPosted: 14:47 - 07 Jan 2014    Post subject: Bogging down at higher RPM and backfiring Reply with quote
First post in here with the new (old) GPZ500. Laughing
Went for a quick blast with a pillion the other day, all of a sudden when we are nearly back home I notice that giving it more throttle is not doing anything, it was perfect before. Anyway now whenever I try and accelerate past around 6k I just have no power and it bogs. It will slowly pick up speed but nothing like it should. If I hold the throttle on it will sometimes just have a burst of power randomly that feels like it should.
Also, it's popping (backfiring/misfiring?) under engine braking quite a lot. It has always done this while I have had it (don't know if that is to do with the aftermarket exhaust) and has always been fine but now seems to be doing it a lot every time I engine brake. If I quickly bring the throttle on and then back down it will nearly always make a bang.
I'm at my university home and the garage and all the tools (I have some basic tools here) are 40 miles away in London so it would be hard to diagnose until I get there. Could it be clogged carbs or fuel line? Or buggered plug(s)?
Thanks!
Current ride: Ninja 500R
Robby
Dirty Old Man
PostPosted: 14:52 - 07 Jan 2014    Post subject: Reply with quote
Misbehaving at large throttle openings is unlikely to be a carb problem - if they were filthy enough to clog a main jet to the point of not running, all of the smaller bits handling idle and small openings would be totally gummed up.
Likewise I wouldn't expect an electrical problem. At high rpms the alternator is spinning faster and making more power, so a problem with a poor earth or weak battery is more likely to show at low engine speeds.
I would be looking for an air leak, particularly a split inlet rubber. You may need to wiggle the carbs around a bit to find it.
treeno
PostPosted: 14:58 - 07 Jan 2014    Post subject: Reply with quote
Thanks for the reply. I wouldn't say it was large throttle opening (should have been more clear about that). I usually have to twist the throttle whole lot more to get up to max revs (12k ish) from 6k. I don't know if this is relevant? Only thing that made me think carbs is that a lot of these get clogged up carbs. It's a notorious problem because they have no fuel filter fitted so a lot of people fit an in-line one just before the carb.
WULFSTAN
PostPosted: 01:28 - 08 Jan 2014    Post subject: Reply with quote
Tbh this sounds a lot like my gt 550 that had a really bad inlet air leak.
Your backside is better enough for you to run again, if need be – bristle up the courage of the cornered rat, put on a bold front, and to hell with them. Bluff my boy – bluff, shift and lie for the sake of your neck and the honour of Old England
PostPosted: 09:25 - 08 Jan 2014    Post subject: Reply with quote
Grab a can of wd40 and spray around the inlets while its running, think Robby is on to a winner with this one. Thumbs Up
DrSnoosnoo
PostPosted: 11:08 - 08 Jan 2014    Post subject: Reply with quote
I reckon an air leak too and agree with the point that if the main jets are clogged the smaller ones would be moreso?
treeno
PostPosted: 12:22 - 08 Jan 2014    Post subject: Reply with quote
Thanks guys. What exactly am I looking for? A change of engine speed/sound at idle when I do the spraying? Didn't seem to have much effect (although the idle is usually quite unstable when it's cold so it's hard to tell).
PostPosted: 12:24 - 08 Jan 2014    Post subject: Reply with quote
Get it warm then Laughing Warm enough to idle steady at 1300 or so rpm.
Give the bit between the engine and carbs a quick spray, if the revs change at all, bogs, increases etc then you have a leak there.
treeno
PostPosted: 12:31 - 08 Jan 2014    Post subject: Reply with quote
Fuck my neighbours are going to hate me. Laughing
treeno
PostPosted: 12:53 - 08 Jan 2014    Post subject: Reply with quote
Okay so got it warmed up, the spraying didn't seem to have any effect on the idle at all. One thing I did notice on the way back from my testing spot was that it seemed to perform much better when hot (unless that was a side effect of all the GT85 I had been spraying), bogging down less. Still lurchy and popping multiple times a second when off the throttle though.
treeno
PostPosted: 14:19 - 16 Jan 2014    Post subject: Reply with quote
Could this be the cause of my problems?!
https://i42.tinypic.com/rwta1f.jpg
PostPosted: 14:28 - 16 Jan 2014    Post subject: Reply with quote
Replace that lol
treeno
PostPosted: 14:31 - 16 Jan 2014    Post subject: Reply with quote
Paddy. wrote:
Replace that lol
Oh shit won't duct tape do? Very Happy
On a serious note though, is there any point ripping my carbs open like I was going to? Would the hole be the sole cause?
PostPosted: 14:36 - 16 Jan 2014    Post subject: Reply with quote
Could have sucked some of that into the carb... I'd pull em off and just make sure the bowls are clean and jets are clear.
treeno
PostPosted: 14:43 - 16 Jan 2014    Post subject: Reply with quote
Cheers Thumbs Up.
Robby
Dirty Old Man
PostPosted: 16:30 - 16 Jan 2014    Post subject: Reply with quote
The air filter bits won't get sucked into the bits of the carb that gum up - the bits will past right down the middle of the carb and end up in your engine, then come out the other side.
Sort the air filter, see how it behaves, don't pull the carbs apart just yet.
On a more general note, if you ask for help in the workshop the general idea is that you make sure the bike is otherwise serviceable first. It's extremely lazy to ask for help diagnosing a problem before even checking over the basics yourself.
treeno
PostPosted: 17:47 - 16 Jan 2014    Post subject: Reply with quote
The carbs had chunks of air filter in just about every crevice. I would have checked the air filter sooner but like I said I was away from home without my tools. I mainly wanted to get a general consensus on what the problem was to see if it would be okay to ride it home. Would you like a penny for your wasted bandwidth?
The last post was made 12 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 92.65 Kb
