| Yosh |
 Yosh Two Stroke Sniffer
 Posted: 12:26 - 07 Jan 2014 Post subject: |
First thing I'd check is for any signs of play in the headset bearings or wheel bearings and take action to remove it.
So stand astride the bike, hold the front brake fully on and push the handlebars back and forth. Any looseness or clunking and you probably need to tighten or replace the head bearings.
Get hold of the front wheel at either side of the rim and try to rock it from side to side with the steering held still. Look for any looseness or movement around the axle. Again, tighten/replace bearings if necessary.
If those are all ok, have a look at the brakes themselves. Check for play where they attach to the posts on the front fork. If there is play here, you MIGHT be able to tighten them up but they could just be worn and need replacing. A basic set of v-brakes are not expensive to buy.
Have a look at the pads. Are they in the right way round and fitted on the correct side because they are directional AND handed (usually have an arrow on them and an R/L mark but the longer end points towards the rear of the bike). The pads themselves also sit on a cup, it is possible to alter the angle at which they strike the rim by loosening the bolt slightly and re-angling it. I would have the rear edge of the pad touching marginally before the front edge.
It would be a mistake to assume the bike shop put the pads in the right way round, especially if it was Halfords. In fact, if it has suspension forks, it would be a mistake to assume they put the whole front end in the right way round.
If all else fails and checks out ok, replace the pads, they might just be shit. If they are the ones the bike came with, they ARE shit, bikes universally come with shit brake pads fitted from new. I personally like clark triple compound pads when I can find them.
https://www.wigglestatic.com/images/clarks-cps513-med.jpg ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Yosh |
 Posted: 16:52 - 07 Jan 2014 Post subject: |
Thanks Stink will check it out.  |
| Tungtvann |
 Tungtvann World Chat Champion
| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| Yosh |
| sickpup |
 sickpup Old Timer
The last post was made 12 years, 259 days ago. Instead of replying here, would creating a new thread be more useful? |
