All bike engineering/ fork re chroming?
BravoCharlie
PostPosted: 18:51 - 07 Jan 2014    Post subject: All bike engineering/ fork re chroming? Reply with quote
Good evening guys, looking for a bit of advice.
i bought a Honda VRX400 the other day in the knowledge that it needed some work done. the main thing is that the forks need attention (photo below) and i am unsure what the best option would be. it is a japanese import, and i can't find a replacement set anywhere.
someone recommended ABE to create new ones for me, as he had his done the other week and had a good turnaround (2 weeks) and - he claims - good value for money (£300).
i assume the other option is to have them hard chromed, but i have no idea where to send them to, and the rough costs etc, if anyone can advise?
here's the photo of the forks to give you an idea of what i'm working with: https://i1263.photobucket.com/albums/ii639/bravocharlie1/null_zps8f3018b9.jpg
thanks in advance Smile
Current: Kawasaki ZL600 Eliminator
Past: Suzuki GZ125, Kawasaki GT550, Kawasaki GPX600R, Honda vrx400,Kawasaki Zephyr 750, Suzuki SV650 K5
Dream as if you'll live forever, live as if you'll die today.
PostPosted: 18:58 - 07 Jan 2014    Post subject: Reply with quote
May struggle to rechrome that because of the corrosion on the OS fork leg.
BravoCharlie
PostPosted: 19:03 - 07 Jan 2014    Post subject: Reply with quote
well that's not good. not good at all Laughing
do you think it's at least worth sending off some photo's to chromers and see if they would be up to the task? or do you think they would just say 'yeah' for the sake of £££?
PostPosted: 19:05 - 07 Jan 2014    Post subject: Reply with quote
Looks like more rust than fork me. Razz
I would say send them off a photo, and let them know what it's being used for. Then they'd be able to advise.
Walloper
PostPosted: 19:10 - 07 Jan 2014    Post subject: Reply with quote
In order for a chromer to lay chrome on the rods have to be ground down to good metal. Then they can be built up and finally ground to the polished finish.
All chromed rods are ground to achieve a uniform surface.
I used to sell chrome rod and chroming service for a mob in RSA.
It is never impossible to do anything.
The mob I worked for would reverse engineer a job if the core was useless. Still cost less than a third of OEM prices. Smile
BravoCharlie
PostPosted: 19:24 - 07 Jan 2014    Post subject: Reply with quote
suppose it can't hurt to ask!
however, is there any reputable companies i could contact?
Walloper
PostPosted: 19:34 - 07 Jan 2014    Post subject: Reply with quote
I though I saw a chromer advertising on here.
PostPosted: 19:36 - 07 Jan 2014    Post subject: Reply with quote
"Has a budget to advertise online" <> "Reputable".
kramdra
PostPosted: 20:45 - 07 Jan 2014    Post subject: Re: All bike engineering/ fork re chroming? Reply with quote
Some people pay silly amounts of money to uprade forks and you want to rechrome those..? If the outside is that bad, what are the internal components going to be like?!?
Ebay some modern forks, 41mm diameter. Were my CBR600 forks not 43mm I would offer them to you for £300 Laughing
BravoCharlie
PostPosted: 20:56 - 07 Jan 2014    Post subject: Re: All bike engineering/ fork re chroming? Reply with quote
well, ideally i'd like new forks hence why i thought about ABE - i've never had to deal with forks before so i'm not even sure if £300 was good or bad...
also to be completely naive, would any 41mm forks fit?
kramdra
PostPosted: 21:34 - 07 Jan 2014    Post subject: Re: All bike engineering/ fork re chroming? Reply with quote
I assume £300 would only buy you a new pair of stantions - the chromed part, rather than brand new forks.
No, not any 41mm forks will fit, you will need to do some reseach. The main issue is brake caliper mountings. The lazy person in me would find a matching set of forks, caliper, wheel and disc from a common bike of a similar style.. also noting suspension travel, fork length and if it is also front wheel speedo drive.
But that way you get modern, shiny newish bits, rather than some polished turds.
I expect it would also cost less than £300.
BravoCharlie
PostPosted: 21:45 - 07 Jan 2014    Post subject: Reply with quote
the stanchions are the main problem as the forks seem to be alright themselves apart from needing seals. i was thinking if i found a 41mm stanchion it would possibly have fitted but i asked the question wrong, my bad.
i think you've got a point. i'll try and research into getting a new front end but it's finding a similar bike that'll be the problem!
thanks for the advice
PostPosted: 23:36 - 07 Jan 2014    Post subject: Reply with quote
There are a few places doing fork rechroming.
Over the years I have used 2 of them. HCP up in Notts, who I used many years ago. And Philpots down in Luton, who I have used recently (for the USD forks on a GSXR1100 and the normal forks on a GSXR50).
Rechroming basic forks was abotu £160 I think, if sent just the fork stanchions, more if you send them the whole forks and want them to strip and rebuild them.
Note that it might take a month or so to get them rechromed if they are busy.
PostPosted: 23:38 - 07 Jan 2014    Post subject: Reply with quote
I personally think you're going to struggle getting those forks apart with out damaging the fork legs. There seems to be a hell of a lot of corrosion around the dust seal. If the oil seal is similar, it could be well jammed in.
Even if you don't, as well as new seals, you'll probably land up needing new bushes as well and you're approaching the cost of a good, second hand set of forks.
Oddball bike though but I bet forks off something else would fit. 41mm diameter which is common with....
Honda CBR 600 (F) CBR 600 (F) XL 600 (Transalp) XL 600 (Transalp) CB 600 (Hornet) CB 600 (Hornet) CB 600 (Hornet Faired) CB 600 (Hornet Faired) NTV 600 (Revere) NTV 600 (Revere) CBF 600 (Naked) CBF 600 (Naked) CBF 600 (Faired) CBF 600 (Faired) CBF 600 (Faired ABS) CBF 600 (Faired ABS) CBF 600 (Naked ABS) CBF 600 (Naked ABS) XL 650 (Transalp) XL 650 (Transalp) FX 650 (Vigor) FX 650 (Vigor) NT 650 (Deauville) NT 650 (Deauville) NX 650 (Dominator) NX 650 (Dominator) NTV 650 (Revere) NTV 650 (Revere) VT 750 (Shadow) VT 750 (Shadow) CB 750 (Retro) CB 750 (Retro) VT 750 (Black Widow) VT 750 (Black Widow) VF 750 C VF 750 C VFR 750 VFR 750 VFR 800 VFR 800 PC 800 (Pacific Coast) PC 800 (Pacific Coast) CBR 1000 (F) CBR 1000 (F) VTR 1000 (Firestorm) VTR 1000 (Firestorm) ST 1100 (Pan Euro) ST 1100 (Pan Euro) ST 1100 (Pan Euro ABS) ST 1100 (Pan Euro ABS) VTX 1300 (S) VTX 1300 (S) GL 1500 (Goldwing) GL 1500 (Goldwing)
They all have the same diameter stanchions so they'd fit in the yokes, not necessarily compatible at the other end though and differing lengths.
PostPosted: 23:53 - 07 Jan 2014    Post subject: Reply with quote
Just looked on the ABE web site. They list the VRX400 on their 'price list' (which doesn't seem to have prices on it). However think they charge something like £160 for a pair of conventional forks
BravoCharlie
PostPosted: 23:58 - 07 Jan 2014    Post subject: Reply with quote
Thanks for the help guys, i'm currently looking through stinkwheels list to try and find something similar.
a quick question regarding the 'travel' on a forks.
according to the link below, the VRX has a front end travel of 104mm. am i basically looking for a set of 41mm with 104mm travel? or is it not as simple as that? i seriously underestimated finding forks when buying this bike, and i'd hate to give up as it's a bike i've been wanting to buy for well over a year!
https://www.motorbikespecs.net/index.dyn?flag=2&model_id=3643443&make=honda
PostPosted: 00:09 - 08 Jan 2014    Post subject: Reply with quote
Looking for more than that, although depends on whether you want to fit the forks or the whole front end.
If you want to fit the whole front when then you need to make sure the steering stem is similar, or you can possibly press the stem out of the current yokes and into the replacement ones. You then possibly land up with issues mounting the clocks, etc.
If you are swapping the whole forks you will need to make sure the travel isn't excessive (ie, don't want the front wheel hitting the engine) but that is probably not a major issue. Also want the spring rate and damping to be about right for the weight of the bike, etc. But bigger issues putting other forks into the existing yokes would be the side the brake caliper mounts on, the diameter of the brake disk that mount is set up for, the mounting hole spacing for the caliper, speedo drive compatibility, wheel spindle diameter, size of spacers between the wheel and the fork lowers, etc.
BravoCharlie
PostPosted: 00:16 - 08 Jan 2014    Post subject: Reply with quote
christ - this seems impossible at this point Laughing
thanks again guys, i really am grateful, albeit stumped!
PostPosted: 00:31 - 08 Jan 2014    Post subject: Reply with quote
Reason I put up that list is that quite a lot of Hondas are interchangeable.
For example, you can fit VTR firestorm forks into a VFR750 and retain the original yokes and front wheel but you do need to swap the callipers, spindle and mudguard.
Trouble is, you just need to know what fits what
PostPosted: 00:32 - 08 Jan 2014    Post subject: Reply with quote
If you have access to machining equipment and the skills to use it then it is likely that sorting spacers and brackets out is easy enough.
But for under £200 for a new pair of forks stanchions I wouldn't consider looking for other forks
BravoCharlie
PostPosted: 00:38 - 08 Jan 2014    Post subject: Reply with quote
the only reason i'm worried about the fork stanchions from ABE is i've had a PM warning me of some bad experiences from them.
^^ this is now my new worry, as i hadn't quite thought about that. i think i'm going to have to take the forks off and get all of this measured, as well as check the inside of them, to make sure i'll be fine to just replace the stanchions.
sigh! Laughing
PostPosted: 08:29 - 08 Jan 2014    Post subject: Reply with quote
Can you get some photos of your caliper bracket and a rough photo of the bike... I have some forks that might well work, they are from one of the bikes listed by Stinkwheel.
BravoCharlie
PostPosted: 11:42 - 08 Jan 2014    Post subject: Reply with quote
I'll get them taken in an hour or so mate
BravoCharlie
PostPosted: 13:38 - 08 Jan 2014    Post subject: Reply with quote
went out to blow the tyre up and find my cover, as the wind had blew it away Laughing
so grabbed some photo's for you:
https://i1263.photobucket.com/albums/ii639/bravocharlie1/null_zps53ce6f00.jpg
https://i1263.photobucket.com/albums/ii639/bravocharlie1/null_zpsad08303e.jpg
https://i1263.photobucket.com/albums/ii639/bravocharlie1/null_zps3432b361.jpg
https://i1263.photobucket.com/albums/ii639/bravocharlie1/null_zps0c29c1cb.jpg
https://i1263.photobucket.com/albums/ii639/bravocharlie1/null_zpse59ac714.jpg
hopefully these help you Paddy, and hopefully you have what i need Laughing
PostPosted: 13:48 - 08 Jan 2014    Post subject: Reply with quote
I shall have a look for you! Thumbs Up
The last post was made 12 years, 313 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 137.78 Kb
