Stage 6 dellorto 19mm phbhg help?
Dannykjm15909
PostPosted: 10:49 - 08 Jan 2014    Post subject: Stage 6 dellorto 19mm phbhg help? Reply with quote
Hi guys I've jus bought a stage 6 19mm carb phbg I also bought a intake / inletanofold system with reeds but it won't fit on to the carb there both stage 6 if that matters.
The inlet manifold stub on the carb is 25mm. I'm looking at a stage 6 carburetor manifold adapter which I hope will make it fit? But I'm not sure of the sizes it says.
The standard replacement is 23mm inlet diameter for carbs up to 21mm, but select sizes 30mm or 32mm for larger carbs. Any help appreciated thanks.
PostPosted: 10:51 - 08 Jan 2014    Post subject: Reply with quote
What is it for.
Dannykjm15909
PostPosted: 10:52 - 08 Jan 2014    Post subject: Reply with quote
Piaggio zip 2 stroke intake manifold system for the carb
I think a 30mm adapter will make a 25mm fit won't it ??
The last post was made 12 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.26 - MySQL Queries: 13 - Page Size: 34.54 Kb
