CBF125 Oil Capacity
JackDaniels
PostPosted: 10:50 - 08 Jan 2014    Post subject: CBF125 Oil Capacity Reply with quote
Hi guys,
My friend has dropped his cbf off with a litre of oil, spark plug and air filter, i have adjused and lubed chain, changed plug and drained the oil.
I have put a new washer on the sump plug but am unsure how much oil the engine takes, my ybr used to take 1 whole bottle is the cbf the same ?
Many thanks
Jack
THEORY TEST - PASSED! - 02-08-11 CBT Passed - 09-08-10 MOD 1 - 09-08-2011 - MOD 2 - 28-09-2011
2006 Yamaha JOGRR>2010 Yamaha Ybr>1995 Honda CB400 Superfour >2005 Honda hornet>1999 Suzuki Bandit 1200 > 2002 BMW R1150GS > 2013 Tiger Sport 1050 > 2007 GSXR 1000 > 2005 GS500E
PostPosted: 10:54 - 08 Jan 2014    Post subject: Reply with quote
They burn oil anyway, I'd chuck a litre in there.
Aff
PostPosted: 11:24 - 08 Jan 2014    Post subject: Reply with quote
Google says 1.1L.
Electric Bike Project
Shreeve
PostPosted: 12:18 - 08 Jan 2014    Post subject: Reply with quote
Manual says 900ml but i found that didn't quite hit the minimum level for some reason.
I tend to put 1L in.
Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Previous: Honda CBF 125 (2011), Suzuki GSXR750 K4
Walloper
PostPosted: 12:40 - 08 Jan 2014    Post subject: Re: CBF125 Oil Capacity Reply with quote
JackDaniels wrote:
Hi guys,
Many thanks
Jack
The filler cap is the level or there will be a sight glass.
Almost every animal that takes oil has a level mark. Shocked
If there is a stick on the fill plug stand the bike vertical (both wheels on the ground (or on the centre/paddock stand)
Fill with oil.
Stick cap/stick in fill hole but don't screw in.
Pull out and look for highest oil mark. It should be on the top mark and not under the lower mark.
Fill (in little cup fulls) to the top mark and run.
Then recheck and top up to top mark.
simonjb
PostPosted: 16:27 - 08 Jan 2014    Post subject: Reply with quote
Just put the recommended 1.1L in at first, run the engine over and warm it up a little. Make sure it's on it's centre stand on a level surface, once the engine is just warm (1-2 mins should be) turn it off and let the oil settle for another minute or so, then check the oil level again. Add more if it's not on the max mark on the dipstick.
Walloper
PostPosted: 16:49 - 08 Jan 2014    Post subject: Reply with quote
You don't normally check oil when it is warm.
Oil has to be checked BEFORE starting the engine so the levels are set for a COLD engine. The expansion involved is enough to mean the oil will be near the low level with cold oil if you set the level with a warm engine.
Some engines have a 'Running' level. Either Cold or Hot or both.
This is to allow the level to be monitored without shutting off the engine. Normally on static engines providing constant power.
But those engine are filled with oil to the cold level engine stopped then run up and checked to cold level engine running.
simonjb
PostPosted: 17:20 - 08 Jan 2014    Post subject: Reply with quote
I'm just going on the recommendations from the Haynes manuals. It recommends having the engine warmed up a little, then left to cool for a couple of minutes before checking the oil, in both the manual for the CBF 125 and the one for the Yamaha YBR 125.
Current Bike: 2008 Yamaha YBR 125
PostPosted: 17:33 - 08 Jan 2014    Post subject: Reply with quote
I'd just check it before starting. Only a turnip would say "i'll check the oil, but first, ima start my engine which may or may not have oil in it" Wink
The last post was made 12 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 61.63 Kb
