Right side indicators not working
TheManWithThe...
PostPosted: 17:06 - 09 Jan 2014    Post subject: Right side indicators not working Reply with quote
Hi guys
Riding home today, i noticed that all four of the indicators on my ER500 (2003) were totally dead, with not even the lights on the dash flashing.
Initially thought it was a blown fuse (which it was) so quickly swapped at the road side, only to find things weren't that simple.
The right hand side is still dead, with no light even on the dash. However, when i first push the switch to the right, both the headlight and neutral light dim momentarily, as if the switch is trying to draw power.
The left hand side works fine, but only when a couple of seconds have passed since activating the right side.
I've opened the headlight and given things a jiggle but nothing has changed.
Also listened for the clicking of the relay, but can't hear anything.
Also checked the bulbs and all fuses and they are fine.
The next plan of attack will be taking apart the switch gear and checking/cleaning the connections.
I have to ask, are switchboxes easy to dismantle? I don't want to pull it apart and have all sort of components fall out and not have a clue how they go back.
Any other suggestions or ideas of what to do next would be greatly appreciated.
Also, on a side note; i have recently fitted some R&G heated grips through a direct battery connection.
I can't imagine this causing an issue, but thought it was worth mentioning as a possibility.
Thanks
MBK Nitro 50, Sold. Kawasaki ER-5, Honda ST1100
"Anyone can jump a motorcycle! The trouble begins when you try to land it..."
davebike
PostPosted: 17:45 - 09 Jan 2014    Post subject: Reply with quote
Most lightly the switch give it a good squirt of switch cleaner and work it a bit
If no switch cleaner try WD40 or similar
Dave
Dave
NC750Xdct + others at work !
[email protected]
TheManWithThe...
PostPosted: 23:18 - 15 Jan 2014    Post subject: Reply with quote
Well, after the good old trick of leaving it be for a couple of days, and a good wiggle of the cables, they have started working again.
My guess would be a bit of moisture shorting a connection or something wriggling a bit lose.
Thanks for the reply anyway dave Thumbs Up
Nobby the Bastard
Harley Gaydar
PostPosted: 20:51 - 16 Jan 2014    Post subject: Reply with quote
Bad earth....
Triumph Sprint ST 1050
jamesrs250
PostPosted: 01:01 - 17 Jan 2014    Post subject: Reply with quote
most electrical problems on most motorcycles i find to be corrosion. clean the corrosion off with a wire brush and replace connectors
The last post was made 12 years, 269 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 43.9 Kb
