FZ750 Cuts Out When Idling & Trouble Starting
Motorhate
PostPosted: 23:14 - 09 Jan 2014    Post subject: FZ750 Cuts Out When Idling & Trouble Starting Reply with quote
My FZ750 has a problem when idling in traffic, its runs fine when moving but standing still I have to keep a slight rev on to prevent it from cutting out. It also has problems starting at times. I always need to pull the manual choke out and sometimes it seems to flood. Its had a custom Quil exhaust stuck on it and I'm wondering whether the carbs have been jetted properly or whether its just a case of changing the air/petrol mix. I'm not that mechanically minded so any help would be appreciated. Thumbs Up
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
PostPosted: 23:35 - 09 Jan 2014    Post subject: Reply with quote
How many miles has it done? I would suggest checking the carbs thoroughly, partly for punctured diaphragms but also for wear in the nozzles in the carbs, especially if it has had a jet kit fitted. The down draft carbs were known to wear the nozzles oval.
However this would cause it to be rich, which might explain the flooding but odd that you sometimes need the choke to start it.
Motorhate
PostPosted: 23:39 - 09 Jan 2014    Post subject: Reply with quote
Thanks Keith, I'm actually not sure of the mileage as its got the clocks from another bike, but I'd imagine its quite high. It always needs the choke out fully to start and after a while I take it down a couple of notches. Even after an 70-odd mile thunder down the M11 as soon as I was stuck in traffic it was struggling.
Its really responsive when riding and has some real poke in it, just makes me sound like a boy-racer when stuck at the lights and trying to stop the engine from dying.
I'll get the carbs checked as you mention. Thanks for the input.
PostPosted: 23:43 - 09 Jan 2014    Post subject: Reply with quote
It is worth a check, but it does seem a bit inconsistent as to whether it is rich or lean.
They are good bikes.
Always worth wondering if the valve need adjusting. But they normally close up with wear, and with mine it was OK when starting from cold but became a real bugger when warm.
jjdugen
PostPosted: 00:24 - 10 Jan 2014    Post subject: Reply with quote
One of these gave me a long run-around. Same thing, ran fine at revs, tick-over splutter and running on three.
The main jet block is a screw in affair with a detachable block to hold the jets. There is a fine rubber gasket between block and carb body. This can shrink or be damaged. It leads to all sorts of odd slow speed running.
Agree that the engine is surprisingly sprightly, pity about the chassis.
davebike
PostPosted: 09:14 - 10 Jan 2014    Post subject: Reply with quote
Yes one of those Yamaha with the Jet blocks
Carb rebuild time the weird O ring for the jet block is expensive but really needs replacing every few years now ethanol in common inn fuel
If a careful rebuild doesn't sort it off down the dyno to re jet
Dave
Dave
NC750Xdct + others at work !
[email protected]
temeluchus
PostPosted: 13:37 - 10 Jan 2014    Post subject: Reply with quote
Make sure the airbox is properly fitted and not leaking. Mine was an utter bastard unless the airbox was perfect.
Also check the carbs are clean and non leaky whilst you are loking at the airbox-one advantage of the downdraught engine is access to the carbs is very easy.
Nobby the Bastard
Harley Gaydar
PostPosted: 14:42 - 10 Jan 2014    Post subject: Reply with quote
You definately have a problem. Mine starts (hot or cold) without choke and doesn't cut out or splutter ever....
This doesn't sound like valves, that'll show up as difficulty starting when cold, and no ability to rev until warm, regardless of what you do with the choke.
Triumph Sprint ST 1050
Motorhate
PostPosted: 15:03 - 10 Jan 2014    Post subject: Reply with quote
Thanks for the replies fellas. Rode to to work this morning and the same thing. Stalled on Marylebone Road at the lights and caused a bit of a tailback before it started Embarassed Embarassed
Will get this seen to next week. As mentioned, there's obviously something not right at all with the carbs.
Robby
Dirty Old Man
PostPosted: 16:10 - 10 Jan 2014    Post subject: Reply with quote
I've had similar trouble recently with my XJ650. The XJ uses evil Hitachi carbs, I assume the FZ750 uses something more conventional.
Before pulling the carbs apart, check over the electrics. My problem was partially down to carbs (clogged mixture/idle system, unusual float heights, corrosion around the slides) but also down to corrosion on the earth points. Look where the coils are mounted on the frame and at the main earthing strap on the battery, take the connections apart and clean off any corrosion.
Mine would idle after that.
Nobby the Bastard
Harley Gaydar
PostPosted: 19:02 - 10 Jan 2014    Post subject: Reply with quote
FZs coils aren't earthed through the frame and are actually isolated from the frame with rubber mounts, so don't bother checking there. The two HT leads and the engine block make one circuit, and both of the small wires to the coils go directly to the Tdi.
There is a small possibility that the coils are breaking down when hot but this would present as a loss of power all the time.
I'd go with a carb issue.
temeluchus
PostPosted: 12:07 - 11 Jan 2014    Post subject: Reply with quote
I tend to find on mikunis on that vintage it's usually related to the float valve.
There are O-rings around the needle seat and the needles can wear.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:49 - 11 Jan 2014    Post subject: Reply with quote
Your best bet to diagnose is to find someone with an FZ local to you and swap over the carbs. If that sorts your issue, then your carbs are at fault.
Motorhate
PostPosted: 16:15 - 17 Jan 2014    Post subject: Reply with quote
Quick update on the bike. Took it to a garage who had a good look at the carbs etc. For starters they said one inlet rubber is letting air in so that is contributing but not the only problem. Air / petrol mix was completely wrong so they rectified that.
Basic upshot was that without dismantling the carbs it was difficult to say what the problem was. Questioned whether it was worth spending money on a bike that was so old and advised that any parts would be second-hand and without finding out the mileage on the original bike, was difficult to say how long they'd last. Also told me the wiring on the bike was a real hatchet job too. Said it would be an ideal project bike for someone with a lot of time and a garage, neither of which I have.
They got it running so as it will run on choke and start again if it cuts out. Still doesn't idle correctly when stationary but nowhere near as bad as before.
Fizzer Thou
PostPosted: 18:27 - 17 Jan 2014    Post subject: Reply with quote
I had a Yamaha R1 4XV in the workshop the other year with exactly the same problem as the OP.The carbs checked out okay but the inlet rubbers had definitely seen better times Thumbs Down
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture352.jpg
I sourced new ones direct from Fowlers of Bristol at £13 each (wemoto are charging £34 each for the same part) and the owner was amazed at the difference Twisted Evil
As for the carb jet holder seals,this link
https://www.wemoto.com/bikes/yamaha/fzr_1000_ex_up_3le/89-90/picture/carburettor_gasket_and_float_valve_kit/
shows the seal that shrinks with todays 10% ethanol unleaded petrol.This is another reason why I now run super unleaded in all of my bikes as it contains no ethanol.
Always have a 'Plan B'
Nobby the Bastard
Harley Gaydar
PostPosted: 21:00 - 17 Jan 2014    Post subject: Reply with quote
To check if the rubbers are the issue, wrap them in cling film. if the problem goes away, it's the rubbers...
By the way, Fowlers waited a week and a half to let me know that the throttle cable for my FZ is no longer available and they only told me becuase I rang them to ask where the fuck it was....
The last post was made 12 years, 283 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 93.58 Kb
